Diff drop and carrier bearing drop.
Discussion in 'Suspension' started by Joeshaker, Oct 24, 2016.
  1. Jul 2, 2019 at 11:34 AM
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    Please excuse my ignorance, but what is it exactly I need if I’m doing the 1.5” rear shackle?? Is the cb drop a must do?
  2. Jul 3, 2019 at 9:04 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I’d say yes and the guys at Ekstrom Design (Coachbuilder) can help confirm. I have one of their drops on my truck when I installed their 2” shackles
    15whtrd likes this.
  3. Jul 3, 2019 at 9:12 AM
    15whtrd
    15whtrd Mr. Blonde
    Same. I think it was a 3/4” spacer so if he is going with something that gives him an inch and a half of lift he might need a 1 inch spacer?
  4. Jul 3, 2019 at 9:17 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep, or close to it. My spacers are 1.25”
    15whtrd[QUOTED] likes this.
  5. Jul 3, 2019 at 9:20 AM
    15whtrd
    15whtrd Mr. Blonde
    OK I just went out and checked. I have the +2 coachbuilder shackles and it came with 3/4” spacers for the carrier bearing.
  6. Jul 3, 2019 at 9:23 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Maybe mine are different because of my lift
  7. Jul 3, 2019 at 9:34 AM
    15whtrd
    15whtrd Mr. Blonde
    He probably custom sized them according to any other factors about your lift.
  8. Jul 3, 2019 at 9:35 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I am pretty sure he did. He asked what all I have on there first. Either way rides perfectly
    Rica25 and 15whtrd[QUOTED] like this.
  9. Apr 24, 2020 at 4:31 PM
    LillDragun
    LillDragun New Member
    So, would a rear 1" shackle lift need a Carrier Bearing Drop kit spacer?
  10. Mar 7, 2022 at 8:28 AM
    Playfast12
    Playfast12 New Member
    Does anyone know the bolt size and thread size for the carrier bearing? I believe the bolt is a 14mm, not sure about the thread though.
  11. Mar 11, 2022 at 11:52 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    The head is 14mm. Bolt diameter should be 10mm, but I’m not positive on thread pitch. Likely 1.25. How thick of a spacer are you planning to install? I ask because the stock bolts are pretty long…. I just spaced my CB down 3/4” and the OEM bolts are plenty long. I’m pretty sure you could do up to an inch thick space with them…. I put a dab of red Loctite on the threads when reassembling.
    Playfast12[QUOTED] likes this.
  12. Mar 13, 2022 at 7:36 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    I’d swing into any decent hardware store and pick up some 1/2” plate washers. The ones I used are about 1.75” steel squares and 1/4” thick. 1/2” hole in the middle. I stacked three and put them between the carrier bearing housing and the crossmember that it bolts to.
    Use a jack or jack stand to loosely support the driveline and this will be easier than any other kid you’ve ever done.
  13. Feb 23, 2023 at 9:46 PM
    spetznaz
    spetznaz New Member
    Hello folks,
    i have a 2007 with about 260k miles on it.
    Roughly 2 years ago i replaced the driveshaft which was totally shot and did the OME lift at the same time. Ended up with about ~2-3in in of lift. Along with the diff drop i added spacer to the carrier bearing (about 1in but i will get under the truck and measure tomorrow). For the past few months i've been hearing a ding when i get going and few days ago found that the 2 yo carrier bearing is now shot, see the picture.
    Wondering if anyone has experienced this. The inner race is offset in the housing by about ~0.25in down.
    I see some folks here are running without the spacer at all, others are dialing it in by angle? Any recommendation? Do i need to add another 0.25in to my spacer to get this aligned properly?
  14. Mar 6, 2023 at 4:57 AM
    ceaven
    ceaven New Member
    Oklahoma
    2020 tundra TSS off-road
    All tundras and tacomas come with a 1 degree rear shim when you lift you will need to increase that shim angel to prevent vibration . I have already chased that rabbit . I increased from the 1degree to a 2 1/2 degree and vibration is gone . That was on a Tacoma but the tundra has one I just have not leveled mine yet to a 1.75 in the front only so I’m not sure that small level will cause vibration . Hope this helps
