Diff and T-case Fluid Change
Discussion in 'General Tundra Discussion' started by pvn.beluga, Mar 12, 2022.
  1. Mar 12, 2022 at 2:32 PM
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    Yes, I’ve searched the forums… and this question is definitely asked quite often.
    Who has recently done their changes and what did you guys use?
    I’m looking at Mobil1 75w-95 for both diffs and t-case.
    Does the t-case need a different type of gear oil or could I use the same as my diffs?
    nopsFU likes this.
  2. Mar 13, 2022 at 7:25 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    75-90w of your choice for the front and rear. Go with toyota 75w since it will be readily availableat your dealership within a day or two of ordering.
    I had ravenol 75w and just changed mine and it was much darker than I would have liked. I'm running HPL 75w now, and HPL 75w90 in the diffs.
    Alot of people run 75w90 in the transfer case, some have good results, some have problems. So I'd recommend the 75w.
    https://www.tundras.com/threads/transfer-case-fluid-after-59k-w-pics.102696/
    pvn.beluga[OP] likes this.
  3. Mar 13, 2022 at 7:35 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Tcase = 75w
    Ely010606 and pvn.beluga[OP] like this.
  4. Mar 16, 2022 at 6:37 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
  5. Mar 16, 2022 at 7:05 AM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Did front and rear differential with royal purple 75/90 have not done transfer case yet
  6. Mar 16, 2022 at 7:05 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Wasn't Royal Purple one of the worse gear oil to use?
  7. Mar 16, 2022 at 9:05 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    :eek2:
    Who conducted these tests, all the same source or scattered datasets?
  8. Mar 16, 2022 at 9:10 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Lol, I got this from another thread on here...
    14burrito[QUOTED] likes this.
  9. Mar 16, 2022 at 9:10 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
  10. Mar 16, 2022 at 10:17 AM
    14burrito
    2014 SR5 CM 4x4 5.7
  11. Mar 16, 2022 at 10:39 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    When I changed the tcase fluid on my Tacoma at 50k it looked like I poured it out of the bottle. For that reason I have not changed it in the Tundra. I probably will do it in a couple of months.
    AZBoatHauler likes this.
  12. Mar 16, 2022 at 10:46 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I saw a few guys running it a little longer than 30k. I'm reaching 30k, so I figured I'd just do the changes.
    14burrito likes this.
  13. Mar 16, 2022 at 10:52 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
  14. Mar 17, 2022 at 10:01 AM
    WVI
    WVI New Member
    @008 Tundra Limited
    Questions:
    For towing, what weightshould be in the differential?
    Are they actually a limited slip rear end or something else?
    I dont quite understand how these rear diffs work in 4x4. Do they need limited slip additive?
    Thanks.
  15. Mar 17, 2022 at 12:17 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Rear diffs don't work any different in 4wd versus 2wd. I am not sure what year they switched to brake actuated anti slip but it was at least 5 years ago. So you probably don't need the additive or fluid with built in additive.
    WVI[QUOTED] and 14burrito like this.
  16. Mar 17, 2022 at 12:59 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    From what I read, you only need LS if you are running an actual locker - not Tundras Auto LSD. But, doesn’t hurt if your gear oil has it.
  17. Mar 17, 2022 at 4:51 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Thanks much!
  18. Mar 19, 2022 at 9:12 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I bought Amsoil severe gear for the diffs and Ravenol for the TC. Going to drain and fill all three soon.
    Does anyone have crush washer part numbers handy for swapping diff fluid or TC fluid in a late 2nd gen? My truck is a ‘21. I’ve read that some of the plugs don’t even use washers. Trying to find where I read that…
    JLS in WA likes this.
  19. Mar 19, 2022 at 9:58 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  20. Mar 20, 2022 at 5:07 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
  21. Mar 20, 2022 at 12:37 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Sold by Blauparts though - so you're looking at additional shipping costs.
    WVI likes this.
  22. Mar 20, 2022 at 12:41 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Mine is due for this in a month too. I ordered Amsoil this time. I used to used it in my Ram 2500 I towed a lot with and had great luck with it.
    I know the 2nd Gen need crush washers.
    WVI and Terndrerrr[QUOTED] like this.
