Diesel swap
Discussion in 'Performance and Tuning' started by SalsaTheTundra, Jun 6, 2020.
  1. Jun 6, 2020 at 7:41 AM
    SalsaTheTundra
    SalsaTheTundra [OP] New Member
    jd
    Birmingham, Alabama
    2008 Salsa Tundra Double Cab SR5 5.7
    Ubar led headlights K&N filter +50HP
    So... I’ve been thinking. I plan on keeping my truck forever. and i’m thinking when the motor goes out that I wanna diesel swap it. Probably a Duramax with the new allison 10 speed. Will that fit with minor cramming?
    Brown Bear likes this.
  2. Jun 7, 2020 at 6:27 AM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Gonna take a while for the motor to "go out"...
    Toyotoholic, ARMYGREEN and Black Wolf like this.
  3. Jun 7, 2020 at 6:31 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Doubtful. You would have to meet all regulatory requirements related to a diesel- the swap would cost more than a new truck with a diesel. The added weight of all the component would be a huge hit on your payload as well.
    For reference- even trying to swap a 5.7 into a truck with 4.6 gasser is cost prohibitive. Much cheaper and better engineered to just get a truck with the engine you want.
    Black Wolf likes this.
  4. Jun 7, 2020 at 6:59 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    You talking a baby duramax (3.0) or one of the big ones (6.6)? Baby Duramax would be a maybe, I would think the trans area would be the bigger issue for size. Big one no way, there's a reason HD truck front ends are so huge, there'd be no more room in the Tundra front end for any other pieces beyond the engine.
  5. Jun 7, 2020 at 7:00 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It’s not my money, I say do it!
  6. Jun 7, 2020 at 7:02 AM
    The Isuzu Duramax motor is pretty compact. 30”x30”. The 5.7L looks wider than that.
    Here is what will get you:
    The 5.7 is 489 lbs, and the DM is 735 lbs.
    LML series DM is 397 hp/765 #tq. Your frame might not handle the torque. L5P might twist the frame with 445 hp/915#tq.
    Now you need the drivetrain to match the added weight and power. Allison 1000 is 330 lbs dry, and the AAM 11.5 axle will need to be customized to fit under your truck. Probably best to just order a custom axle from Strange Engineering, and get the wheel bolt pattern to match the front. The S-60 axle is pretty stout, and the last one cost me 2900.00 to my door.
    I’m not sure on the front axle components and how that would handle the added weight. I’m guessing...ok.
    Like others have said, I would just go get a GM truck with the Duramax. I did, and love it. 50k miles of pretty hard towing and my only complaint is tires. On my 3rd set already. Diesels eat tires.
  7. Jun 7, 2020 at 7:28 AM
    Shark Bait
    Shark Bait Not new anymore
    David
    2019 Platinum
  8. Jun 7, 2020 at 7:33 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I’ve dreamt of as well :)
    Maybe turbo 4bt though
  9. Jun 10, 2020 at 10:51 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
  10. Jun 10, 2020 at 11:04 PM
    TemujinNomad
    TemujinNomad New Member
  11. Jun 10, 2020 at 11:43 PM
    Wallygator
    Yeah if the motor ever goes out just put another 5.7 in it and be done with it for another 20 years.
    TX210Tundra likes this.
  12. Jun 11, 2020 at 1:03 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    And save yourself 35grand over the diesel conversion.
    Wallygator[QUOTED] likes this.
  13. Jun 11, 2020 at 6:21 AM
    belanger9
    Edmonton, AB
    A bunch
    That's a pretty big if, better drain the oil if you want it to happen any year soon.
  14. Jun 11, 2020 at 6:46 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    I think motor will outlast the body if you change oil and all the fluids regularly.
    Wallygator and TX210Tundra like this.
  15. Jun 18, 2020 at 3:37 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    With the right fab skills and a solid budget, I do think it is possible. I haven't personally measured or looked into this in depth, but would be a cool idea.
    Mountun Goat likes this.
  16. Jun 18, 2020 at 4:32 PM
    belanger9
    Edmonton, AB
    A bunch
    I just watched a Youtube video with them putting a Cummins (can't remember if it was a 12 or 24 valve) into a Mustang - it fits. So a V8 diesel into a Tundra should be a piece of cake.
  17. Jun 18, 2020 at 5:27 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Several years ago the performance division at General Motors made three copies of a V-16 engine that was essentially 2 LS-1 engines in one block. One went on a stand and toured the country, one went in the Cadillac "Sweet Sixteen" concept car and they put the third in a Chevy Tahoe.
    They had to stretch the front fenders and frame on the Tahoe 12 inches to fit it in.
    Where there's a will (and unlimited resources) there's a way.
    ZappBrannigan likes this.
