Diamondback Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by jeffw6236, Aug 7, 2017.
  1. Dec 19, 2024 at 6:16 AM
    #1141
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    LOL, my DB Cover makes a freakin racket with all the latches rattling and everytime over a speed bump with rear wheels, the whole system squeaks
  2. Dec 19, 2024 at 7:19 AM
    #1142
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Sounds like the latches and lock rods need to be tightened up so the gaskets are compressed. That will keep the cover from bouncing around over bumps.
    You might want to retorque the clamps as well as they can loosen.
    I have had a DB cover on 4 vehicles and never had squeaking and rattling.
    My current setup has my cover over a 1 ton suspension with 80 psi in the tires. It doesn't squeak over bumps.
    nasher75 likes this.
  3. Jan 14, 2025 at 3:35 AM
    #1143
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    I found a used Diamondback SE cover for $1000 in Boston so I drove over from Vermont last weekend. Here are the two pictures from the Marketplace ad.
    Here's the cover on my way home.
    My dash was lit up like a Christmas tree on the way home as the winter slush kept blocking all the front sensors.
    It will be a couple of months before it's warm enough out for me to get it mounted but I'm excited.
    Bergy24 likes this.
  4. Jan 14, 2025 at 4:20 AM
    #1144
    wysongdog
    wysongdog New Member
    Good snag
    Ausfahrt likes this.
  5. Jan 14, 2025 at 6:08 AM
    #1145
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Thanks for the reminder to check the clamps. They were very loose and needed to be tightened. However, all the latches still ratle no matter how I adjust them. Only hear it if I have the rear window down.
    SrgJigPog likes this.
  6. Jan 16, 2025 at 1:57 PM
    #1146
    sno1
    sno1 In search of quality
    In need of a new truck
  7. Jan 16, 2025 at 2:00 PM
    #1147
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Another rack option is the Yakima base camp rails that install directly onto the cover. And then you can add the overhaul he rack
  8. Jan 16, 2025 at 2:05 PM
    #1148
    sno1
    The problem with mounting to the cover is the cover can't be opened if anything is on the racks. I'd really like to be able to open the cover while the racks are loaded
  9. Jan 16, 2025 at 2:16 PM
    #1149
    shawn474
    MoCo, Maryland
    understood; just seeing if that was an option for you. I researched a lot before deciding to go that route. I have never had to open the cover even with rack loaded. Can access just by dropping the tailgate
    sno1[QUOTED] likes this.
  10. Jan 16, 2025 at 2:22 PM
    #1150
    sno1
    I could probably make do, and may go that route if it seems to be the best rack, but it would be much handier for me if the cover could open.
  11. Jan 17, 2025 at 12:09 PM
    #1151
    DiscardedDonut
    DiscardedDonut New Member
    2025 Silver Tundra 1794
    My Diamondback HD cover is scheduled to arrive this afternoon. At the moment I'm preparing for the shim installation by preemptively removing the plastic bed rail caps, but I'm having a difficult time. I recognize that the first time attempting this is terrifying and therefore I'm being more tentative than is necessary. However, I'm finding it challenging to access the grommets (or whatever you call them). The bed cleat-and-rails aren't exactly helping.
    Are there any additional tips or links to posts or external resources that might prove helpful?
    Thanks!
    Edit: Actually, I’m finding that applying a reasonable amount of brute force in the vertical direction is providing me with a decent result.
  12. Jan 17, 2025 at 1:39 PM
    #1152
    shawn474
    MoCo, Maryland
    I broke one or two when I did it. I ended up using a pry bar to gently lift and had a long pair of needle nose pliers I used to grip and squeeze the grommets to release. Make sure you reshape them before you try to reinstall
  13. Feb 9, 2025 at 11:10 AM
    #1153
    TRDProMTB
    TRDProMTB New Member
    2021 Tundra TRD Pro & 2025 Tundra 1794 Hybrid TRD OR
    What length Yakima HD bars are everyone using with the skyline feet? I originally bought 60 inch bars and using the adapter they seem too narrow and don’t look like they fit right.
  14. Feb 9, 2025 at 2:14 PM
    #1154
    shawn474
    MoCo, Maryland
    I am using the base camp rail system with the overhaul he clone from Amazon
  15. Mar 21, 2025 at 2:30 PM
    #1155
    veloaudio2
    veloaudio2 New Member
    Greensboro, NC
    2010 Tundra SR5 4x4
    3” lift, RCI sliders and skid plates, dual battery setup
    Edit: removed, sorry about that
  16. Mar 21, 2025 at 2:40 PM
    #1156
    shawn474
    MoCo, Maryland
    forum rules are strict about selling. Might want to try Facebook marketplace and listing location may help
  17. Mar 22, 2025 at 10:42 PM
    #1157
    mr_schiz
    mr_schiz New Member
    Caleb
    2020 TRD Sport Double Cab
    Fox 2.5 Resi's, 315/70R17 Toyo MT, Diamondback Switchback Tonneau
    Sorry to Bump an old post here but I have a Diamondback Switchback in smooth. This is the best picture I have of it but I can take more tomorrow. If anyone has any questions I'm open to answer any. Based on the other questions you cannot mount racks on top as it folds on itself and the hinges are made with just enough clearance so that it lays perfectly. I don't have things to strap on top and my use is typically 90% tonneau on but the other 10% is sometimes folding it forward and strapping it (it comes with cam buckle straps designed for this). It's only a few clamps with a 9/16 to remove it when I need full use of the bed. My only issue I've run into is when it's below freezing (like really below freezing) with there being no external locks or mechanisms the only way in is through the tailgate and the back portion of the cover weather stripping has frozen to the top of the tailgate.
    equin likes this.
  18. Mar 24, 2025 at 7:14 PM
    #1158
    Maxus
    Maxus New Member
    Keith
    Probably been asked, can't find in a search. Will a 15-21 Tundra Diamondback HD work on a 2025? Found one on marketplace local to me at a fair deal. Dimensionally from the website it looks like it will, but wanted to ask the braintrust.......Thanks!
  19. Apr 17, 2025 at 6:10 AM
    #1159
    Muddydog1996
    Muddydog1996 New Member
    South Carolina
    2021 CM SR5 Trail Edition Army Green
    Can anyone tell me if the underside of the DB SE extends below the bedrails which I measure at 20"? About to pull the trigger on one but I'm wondering if my kayak will fit under the cover and the upsweep of the bow of the boat really needs 20" at the cab side. Thanks for any measurements.
  20. Apr 17, 2025 at 2:03 PM
    #1160
    rheosibal
    rheosibal New Member
    2.5 Platinum OEM+
    Not sure if this info will still help you, but yes it will fit.
    I had a Diamondback SE Cover on my 2019 Crewmax and I just test fitted & sold it to someone with a 2023/24 (newer model) Crewmax 5.5' Bed. The dimensions are similar enough to provide full coverage, but you will need to make adjustments with the clamps and locking rails to fit the exact dimensions of the bed and whether or not someone has a bed rail.
    The cover on mine was bought specifically for a 2.5 Gen Crewmax, but I'm absolutely sure it will fit any Crewmax 5.5' bed (2007-Current).
    Hope this helps anyone else that's shopping around.
    Muddydog1996 likes this.
  21. Apr 17, 2025 at 2:45 PM
    #1161
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    2023 Tundra Hybrid Limited L TRD OR 4X4
    I have the DiamondBack SE on my 2023 Tundra. There are two items that hang below the top:
    - Shock and related support - 20.5" from the bed floor (see photo).
    - Lock cross bar - 19" from bed floor on the right side, which gains height towards the centre of the box (it's above the storage box towards the cab).
    Muddydog1996[QUOTED] likes this.
  22. Apr 17, 2025 at 8:33 PM
    #1162
    Muddydog1996
    South Carolina
    Thanks exactly what I was looking for. Ordered the SE today. Now we wait.
  23. Apr 18, 2025 at 12:02 PM
    #1163
    Maxus
    Maxus New Member
    Keith
    Thanks for the help! There's a ton of them on marketplace for everything else, but haven't seen very many for the Tundra, and even fewer (none) for the 3rd gen.
  24. Apr 18, 2025 at 12:54 PM
    #1164
    Cthulhu
    Installed an HD with low profile cab/rear glass guard and cross bin. Love these things.
    equin, Bergy24 and jeffw6236[OP] like this.
  25. Apr 29, 2025 at 3:29 PM
    #1165
    2016QuicksandPro
    2016QuicksandPro New Member
    Tom
    2016 Quicksand Tundra Double Cab TRD Pro
    Hello Forum,
    I've searched both the forum and the internet for an hour and haven't found the info, but sorry in advance if it's already out there somewhere.
    Can someone please respond with the length and width of their diamondback cover, specifically for a Double Cab 2.5 (2014 to 2021...).
    I believe it's square, but if it tapers, please send:
    - Front width
    - Rear width
    - Length
    Thank you in advance.
    Tom
  26. Apr 30, 2025 at 5:31 AM
    #1166
    Muddydog1996
    South Carolina
    My SE arrived in just 11 days from initial order. Met shipper at a local parking lot so he wouldn’t have to negotiate my dead end street.
    Install took 2:15hr with help for final adjustments from a neighbor.
    The need to install shims under the rail cover was a bit of a curve and added to the time. It went on easy from there with the most time spent moving it around to get positioned right and setting lock tension.
    She’s a bit tight right now but I understand the gaskets will compress in time.
    We both kept commenting what an ingenious design it is. Kudos to the engineers. I think I’m gonna like it.
    Ray D, drhntr and equin like this.
  27. May 16, 2025 at 6:07 AM
    #1167
    SrgJigPog
    SrgJigPog New Member
    '23 Tundra Limited Trd Off Road
    I have the same problem. Had it two years now and no matter what I do it makes a racket. Seems like the tailgate side handle makes the most noise. I’d prefer a cap and thought I’d give this a go to be able to use my back window but I think it’s gonna have to go and get a cap back. I can’t put the window down because I can’t handle the noise it makes lol.
    nasher75[QUOTED] likes this.
  28. May 19, 2025 at 6:20 AM
    #1168
    Muddydog1996
    South Carolina
    I hate to hear this. I missed this potential problem in reading through all the reviews.That would drive me nuts so hope it doesn't show up with mine. Have you contacted DB about it?
  29. May 19, 2025 at 6:42 AM
    #1169
    SrgJigPog
    I should have updated. I did reach out to diamondback on Friday. Explained to them my issue and the guy I spoke to offered some tips which helped with some of the noise but still the majority seemed to be the rear handle lock mechanism. He said he would send me a new lock set at no charge to me if I was willing to try and change them. I’m thinking just adding the spring on the rear lock may help as the lock near the cab has it and it makes much less noise!
    kudos to them, the customer support was great and I was on the phone less then 10 minutes. Free shipping way up to Canada was a plus too! Thanks diamondback.
  30. May 19, 2025 at 7:13 AM
    #1170
    Muddydog1996
    South Carolina
    Thanks for the update. Good to hear they are responsive. Hope they get yours sorted out.
