Diamondback Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by jeffw6236, Aug 7, 2017.
  1. Jan 9, 2021 at 3:50 PM
    #721
    SimpleMan
    SimpleMan New Member
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    Please update as things progress. I read every page of this thread and was ready to order until I got to your problem. I have the same caps and don't want to have the same problem. I am not going to order until you get this resolved.
  2. Jan 9, 2021 at 4:09 PM
    #722
    Willard
    Willard New Member
    2024 F250
    As it turns out, the replacement arrived yesterday and I installed it today. I don’t know if it will resolve the leaking issue, but it’s supposed to rain this coming week. I’ll post an update as soon as it does.
    Terndrerrr and SimpleMan[QUOTED] like this.
  3. Jan 12, 2021 at 5:41 PM
    #723
    Willard
    Willard New Member
    2024 F250
    It rained Sunday through Monday morning. I’m happy to report that the new cover didn’t leak at all.
    Diamondback sent an Estes freight truck to pick up the old one this afternoon.
    equin, Terndrerrr and SimpleMan like this.
  4. Jan 12, 2021 at 5:50 PM
    #724
    SimpleMan
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    Perfect. Thank you for the update.
  5. Jan 12, 2021 at 6:13 PM
    #725
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Can you tell what the difference is?
  6. Jan 12, 2021 at 6:49 PM
    #726
    Willard
    Willard New Member
    2024 F250
    Each panel has a gasket seal around the outside edge, which ends near the center panel. When you close the panels the edge of this seal butts up against a similar seal on the center support, all of which lay on the bed rails. It seems like there is a much tighter fit at all four corners of the center support between the seals.
    Terndrerrr[QUOTED] likes this.
  7. Jan 13, 2021 at 8:07 AM
    #727
    Hackasaw44
    Hackasaw44 New Member
    Rich
    Santa Rosa Beach, FL
    2014 Tundra Double Cab
    Du-Ha under seat storage
    Great thread guys! I'm expecting a DB 270 by mid February and can't wait to install it on my 2014 DC. I've been wondering if you added a gasket along the top of the cab rail. The side rail caps are slightly higher which leads me to think the panels will be compressed tighter on the sides leaving a gap along the cab. Also did you add a tail gate gasket? Again, great thread, great pictures.
  8. Jan 13, 2021 at 8:21 AM
    #728
    Willard
    Willard New Member
    2024 F250
    I have a spray in bedliner and did not add the included gasket on the cab rail. I have not had any leaking at the cab side despite the bed sides being slightly higher, both with my old cover (which leaked at the center support), and new cover. The seal on the cover is fairly thick and soft, so it fills the gaps. I also position it pretty far forward.
    I don't see any reason to add a gasket on the tailgate, either.
  9. Jan 13, 2021 at 8:35 AM
    #729
    Hackasaw44
    Rich
    Great, thanks. I have a spray I'm liner too. I can always add it later, if I get a leak.
  10. Jan 13, 2021 at 4:36 PM
    #730
    Willard
    Willard New Member
    2024 F250
    Also, make sure you check the four center panel clamps every few days for the first couple weeks when you install it. As the brand new seals compress on top of the bed rails you’ll find that the clamps need to be snugged up a little.
  11. Jan 14, 2021 at 8:34 AM
    #731
    Hackasaw44
    Rich
    Yes, thanks. I saw that suggested in a few of the installation videos. I should get delivery in a month or so. I can't wait get it on and start organizing my equipment. On occasion, I'll be hauling plywood or drywall on top and I'm concerned how the handles will get in the way. Not wanting to risk damaging them, I'm considering adding risers to support the load above the handles but not sure what is most practical. Considering DB round pipe accessory used for ATV ramps.
    to door
  12. Jan 14, 2021 at 9:24 AM
    #732
    Nueces
    Nueces New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    My DB also will arrive next month (it is fervently to be hoped). I think the easiest way to raise a flat load above the hinges, locks, etc, is 2 or 3 lengths of dimensional lumber, ie, 2x4s.
  13. Jan 14, 2021 at 10:24 AM
    #733
    Hackasaw44
    Rich
    Agree. And I won't have to drill any holes and risk leaks. Good idea for occasional use.
  14. Jan 16, 2021 at 8:34 PM
    #734
    SimpleMan
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    Pulled the trigger tonight on a bare aluminum HD with the Front Runner rack system for my RTT. I went back and forth on getting the black but decided the extra $320 for black was better spent on the rack system. Plus if I got the black I would then really want to do a complete chrome delete for the truck so the actual savings is quite a bit more considering what I would have spent for the black out. The bare aluminum should look good with my MGM Tundra. Ship date is estimated for February 25th. Time for patience.
  15. Jan 17, 2021 at 10:27 AM
    #735
    Hackasaw44
    Rich
    Know the feeling. I'm expecting delivery around Feb. 15. There's a lot I want to do once it's installed.
  16. Jan 17, 2021 at 10:43 AM
    #736
    Willard
    Willard New Member
    2024 F250
    We have had a couple more days of rain overnight, plus I did a fair bit of highway driving in the rain, and there hasn’t been any water making entry. The new cover has definitely resolved the leaking issue.
    belanger9 likes this.
  17. Jan 25, 2021 at 10:22 PM
    #737
    Toekneewin
    Toekneewin New Member
    Tony
    2020 Super White TRD Sport
    My wife got me the HD for Christmas. Installed and love it so far with the snow here in norcal. Only issue is the cab side panel sits at an upward angle. When I positioned the latch to make the panel sit lower (level), I couldn't get it to latch because there is no downward pressure on the passenger side. Anyone else have this problem or have a solution?
  18. Jan 26, 2021 at 5:17 AM
    #738
    Rubberdown
    Mine has the same problem. Let me know how you fix it because it pisses me off. I had to go stand on it to close it if I wanted it flat and that’s not gonna happen.
  19. Jan 26, 2021 at 5:21 AM
    #739
    Willard
    Willard New Member
    2024 F250
    Usually this means the center panel is too tight. Did you both install the shims on the underside of the bed rail caps?
  20. Jan 26, 2021 at 10:36 AM
    #740
    Hackasaw44
    Rich
    I haven't installed my 270 DB yet, but I've searched and researched installation videos and manuals to death. I agree the center panel may be tightened too much. I've seen videos of installations where the end product has the center panel weatherstripping compressed very tight and the cab panel is is locked slightly upright.
  21. Jan 26, 2021 at 3:08 PM
    #741
    Toekneewin
    Tony
    Yes, I've installed the spacers. I backed off the center clamps a bit with no luck. Don't want to back it off too much.
  22. Jan 26, 2021 at 4:17 PM
    #742
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    You don't need a bunch of pressure on the center clamps - mine backed completely off at one point and it stayed put. I know have them lightly clamped where they stay put even with a little twisting and then tape up the threads to ensure they don't back off again. There's still a slightly angle but that takes looking very closely to see it, passing by it's not noticeable.
  23. Jan 26, 2021 at 4:19 PM
    #743
    Rubberdown
    Yeah I have spacers and my clamps are so loose one is constantly falling off.
  24. Jan 29, 2021 at 2:43 PM
    #744
    SimpleMan
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    Delivered this morning, installed this afternoon. Took my son and I a bit to install the shims under the caps. Temperature is in the low 40's so took our time to not damage the clips removing the caps.
    THiWwRDi5OoBkT08YpxoXIDbr9c9b4Jv06jb-SxQ_99fe7cb5a58b4a9872bb6a683f8bb1361b69cb4a.jpg
    vxAQJyGNtcWU8mwsgwNu5PKvW762zPTRvvLHO3w9_b0fe3e63fc127c9c154f3b95d66a9982a2d5e691.jpg
    BobsYourUncle and equin like this.
  25. Jan 29, 2021 at 6:54 PM
    #745
    BobsYourUncle
    BobsYourUncle New Member
    2021 Super White Tundra TRD Pro
    Just got mine this afternoon.... going to try to get it installed this weekend if weather cooperates.
    equin likes this.
  26. Jan 30, 2021 at 1:20 PM
    #746
    BobsYourUncle
    Got it installed this afternoon.... Looks nice and went on fairly quickly. I will have to see how it does with the incoming weather here.
    Edit: And just in case others are wondering about my install:
    1) Yes, I did use the shims. No problems pulling the bedrail covers off (well, sore fingers, but no broken parts). They definitely felt stronger in the shim area and a bit "squishy" in the non-shimmed area when reinstalling.
    2) No, I do not have a spray in bedliner. I have a BedRug, but it has 0 impact on the install as it is simply up to the bedrails inside.
    3) At this time, I did not use the front (cab side edge) weatherstrip. The directions mentioned to have someone push down the front and back panels while adjusting the lock rod positioning brackets, so I did do that. I did not have a gap at the front (cab side) edge that I could see. It is a bit tough to close the panels at the moment but directions said it should settle in a few days. We will see how that goes.
    Hope that helps!
    equin, SimpleMan and rideandfly like this.
  27. Jan 30, 2021 at 4:33 PM
    #747
    SimpleMan
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    Took mine through an automated carwash today, no leaks!:yay:
    equin likes this.
  28. Jan 30, 2021 at 6:13 PM
    #748
    BobsYourUncle
    Good to hear!
  29. Jan 31, 2021 at 12:54 PM
    #749
    SimpleMan
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    Well, I spoke too soon. I do have water coming in on the right side from the rear cover. I will check my adjustments tomorrow but that same side of the cover doesn't close like the left side. When closing the cover the left side evenly mates to the bedside, the right side has to be pushed down about another 3/4 inch to get the latch to close.
  30. Feb 3, 2021 at 8:48 AM
    #750
    Hackasaw44
    Rich
    Both covers look great. Curious what you you found out about the leak. I read some DB reviews and occasionally a panel gets warped in the shipping process due to temperature variations. Seems like DB can coach you through a remedy or maybe replace the panel. Do your locking rods side into a tie down track or a rod bracket that installs into the end of the track? The brackets look sloped to compress the gasket when locked. Either way, if the panel is warped, you'd still need to press the corner down to engage the lock. Still waiting for my 270 delivery. Hack
