Diamondback Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by jeffw6236, Aug 7, 2017.
  1. Oct 29, 2019 at 4:05 AM
    #601
    Burdturger
    Burdturger New Member
    No rattles so far. I haven't made any Adjustments since i installed it. We had a good rain over the weekend and it did a nice job of keeping the bed dry.
    It's a quality product despite my criticisms. I think the extang solid fold (which in had on my tacoma) or even the backflip are probably more practical for what i need in a bed cover but I really like the durability and look of this cover. ( On a side note i have the DB se which is rated to hold 400 lbs and I googled weight capacity of the extang solid fold. While extang doesn't publish the number, I founds vender post that extang told them it was 500lbs but evenly distributed. If true I don't know how to feel about that. I thought i was paying double for the most durable product out there. Did I? Having both the DB is definitely put together better...)
    It does make it difficult to reach items bear the front toward the cab. I am now looking into a bedslide. Not sure i will go that route due to price and losing cargo space, but I like the idea of it.
  2. Oct 29, 2019 at 4:07 AM
    #602
    Burdturger
    How old is your DB? I feel like I read that the shims might be new in the last old year or two. I have the rail system. I believe the shims ultimately help with making a better seal
  3. Oct 29, 2019 at 4:42 AM
    #603
    2chains
    2chains New Member
    Southern Ablerta
    Appreciate the reply. I found a 2017 video on a DB Tundra and noticed a fair amount of rattle when they were opening/closing the panels. Wasn't sure what that was about then. I'm in the same boat I probably don't need that heavy duty cover although I need weather and theft protection and don't want noise from the cover especially when driving.
    Living in the cold wintery north I don't want to spend $800-$1500 dollars on another brand that will fall apart in 2-4 years. I'm am looking at $2500CDN for the DB so want to be certain what I'm getting into. (Hoping to catch a sale)
  4. Oct 29, 2019 at 6:20 AM
    #604
    Burdturger
    When I was looking for discounts, the best I could find was 10% off which is the same for military discount and the previous group buy discounts. I've read that DB doesn't really offer any discounts for black friday etc.
  5. Oct 29, 2019 at 6:28 AM
    #605
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    Well, their shipping is faster than advertised. I should get mine by the end of the week. I should get the truck to put it on some time next week... I was expecting the truck to come first. lol.
  6. Oct 29, 2019 at 12:49 PM
    #606
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Mine is almost a year old. I got it last November. I never had any rattles or leaks on mine since I put it on last year. I’ve also taken it off entirely and put it back on a few times since then. Interesting that they’re shipping them out with these shims.
  7. Oct 29, 2019 at 12:53 PM
    #607
    equin
    Ed
    DFW, TX
    Forgot to add that I live in Texas. It gets brutally hot for months at a time but we rarely get the type of freezing cold weather more common up north. Not sure if really cold weather might cause rattles or affect leak-proof seals, but at least the Texas heat hasn’t affected it yet.
  8. Oct 29, 2019 at 1:52 PM
    #608
    Burdturger
    i just noticed that i can see light along the cab side of the cover when looking into the bed. i know this isn't normal and it probably just needs to be adjusted.
    on another note, beside shims my kit also came with a roll of a rubber seal. it wasn't clear to me where this is supposed to go but i think along the tailgate. I didn't end up using it.
    equin likes this.
  9. Oct 29, 2019 at 1:55 PM
    #609
    Burdturger
    The blue line is a gap
  10. Oct 29, 2019 at 1:58 PM
    #610
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    The roll of seal is for that gap you see.
  11. Oct 29, 2019 at 2:16 PM
    #611
    equin
    Ed
    DFW, TX
    Yeah, if you see light, it just needs to be adjusted tighter. I thought the roll of strip was for the cab side. I put it on at first then removed it.
  12. Oct 29, 2019 at 6:46 PM
    #612
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    I had to put the roll seal on at the front, I had light coming through as well. I either had to go super tight and barely be able to close the front locks or use the seal. Now water only gets through where the bed front and side connect, cover is completely watertight.
    equin[QUOTED] likes this.
  13. Oct 29, 2019 at 6:51 PM
    #613
    belanger9
    Edmonton, AB
    A bunch
    No noise when driving. It rattles a touch when open, but once closed everything tightens up. I could see if you had weight on the cover the locks may get looser, but if you're carrying weight on the cover a lot I'd look at a sled deck more than a DB, those things are built for permanent weight up there with the legs straight down to the bed.
    Had my cover freeze a couple times already (just bought it this spring) and it's so much easier to open once that happens. Old covers I'd have to peel the rubber off the tailgate to get it open, this one just takes a couple hits to loosen up the ice then push up on the tie down anchors.
  14. Oct 31, 2019 at 10:03 AM
    #614
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Turn your bars they are up side down
  15. Oct 31, 2019 at 10:04 AM
    #615
    Part_time
    Oregon
    Look at the directions again
  16. Nov 3, 2019 at 3:20 AM
    #616
    Burdturger
    You are correct, I redid them and it is much tighter.
    Part_time[QUOTED] likes this.
  17. Nov 3, 2019 at 3:12 PM
    #617
    Burdturger
    Just another update, I adjusted the cover this weekend and fitment is better howevet it has developed a rattle during driving. Doesn't bother me too much but I can even hear it with all Windows closed. Not sure what changed that caused this and I'm not sure where the rattle is coming from. The topper is much tighter than it was before since I adjusted it however.
  18. Nov 4, 2019 at 5:38 AM
    #618
    Part_time
    Oregon
    Check to see if you retightend the bars you were working on with an Allen wrench
  19. Nov 4, 2019 at 7:04 AM
    #619
    jpod
    London Canada
    sigh. I hope my truck isn't delayed again. Should be here in the next few days (in theory.) I would be nice to be able to do something with that really big pallet of awesome taking up my garage... Especially as it's not getting any warmer and the gaskets on the cover aren't going to settle in properly if they're frozen.
  20. Nov 18, 2019 at 3:59 PM
    #620
    Hooks Blades and Bullets
    Hooks Blades and Bullets New Member
    2020 White Tundra SR5 XSP
    Husky Full Coverage Floorliners, Weathertech window visors, Diamondback HE
    I ordered my Diamondback HE with 13in CrossBin on Veterans day and it arrived 4 days later on the 15th. I was shocked about the shipping speed. I installed the bed cap shims first and proceeded to install the bulkhead weatherstrip prior to the actual cover (approx 25 min). The cover and crossbin took about an hour to get it setup and tweaked out before locking it down for the 24hr weatherstrip cure time. I'm stoked on the look and materials quality. As an active duty Marine we often laugh when something claims to be "military grade" or "military tough" because our gear is constantly breaking. I dont foresee this bedcover breaking anytime soon as it appears rock solid, maybe they engineers at DB should design some equipment for the DoD.
    :monocle:
    2chains, equin, Part_time and 5 others like this.
  21. Nov 18, 2019 at 9:18 PM
    #621
    FancyPants
    FancyPants Not my Husband’s truck
    Amber
    Oregon
    ‘19 SUPER WHITE Platinum Crewmax
    I’d be interested to know how you like the crossbin after some time of use. I have the HD cover and even with the 3rd step N fab bars, it’s still pretty difficult to access anything (with it being lifted) in that section of the truck so I’ve been considering it.
    jpod likes this.
  22. Nov 19, 2019 at 5:51 AM
    #622
    jpod
    London Canada
    Get a slide. Don't go in to get your stuff, have your stuff come to you...
    Burdturger likes this.
  23. Dec 25, 2019 at 6:48 PM
    #623
    2chains
    2chains New Member
    Southern Ablerta
    Lame inside pics, have a few other projects on the go while I have it in the garage for a change.
    equin and Burdturger like this.
  24. Dec 26, 2019 at 4:02 PM
    #624
    2chains
    2chains New Member
    Southern Ablerta
    Did you end up installing the light kit for the bed of your truck? Looking at Matt Gecko kit and wondering about the quality of it.
  25. Dec 27, 2019 at 12:59 AM
    #625
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    You guys convinced me: I ordered my DB SE in black. The automated response email gave me a two week wait. Would be great if they beat that!
  26. Dec 27, 2019 at 2:43 AM
    #626
    FancyPants
    Amber
    Oregon
    Did you see the one listed on PNW craigslist finds for only $300!? I tried to convince My bro to get it for his SR5. (I have the HD for my Crewmax). But he has a canopy.
  27. Dec 27, 2019 at 7:47 AM
    #627
    panicman
    Eric
    I did not! Is it still for sale?
  28. Dec 27, 2019 at 1:34 PM
    #628
    FancyPants
    Amber
    Oregon
  29. Dec 27, 2019 at 9:08 PM
    #629
    jpod
    London Canada
    Burdturger and 2chains like this.
  30. Dec 27, 2019 at 10:25 PM
    #630
    Part_time
    Oregon
    Has anyone purchased any of the chest inserts for the Diamond Back yet. If so what did you think about it worth it or not?20190913_185241.jpg
