Delete
Discussion in 'Recovery & Gear' started by Theonlyway, Jul 2, 2019.
  1. Jul 2, 2019 at 11:30 AM
    Theonlyway
    Theonlyway [OP] New Member
    User
    delete
  2. Jul 2, 2019 at 11:54 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Possibly. Positive terminal is way too close to the truck body, wrong group battery for your truck. If your hold down isn't tight...direct short to ground, same as putting a big wrench across the posts.
    You need one of these: https://www.amazon.com/dp/B01M0ARG3...al&sb-ci-m=limitedTimeDeal&sb-ci-a=B01M0ARG3X
    Theonlyway[OP] likes this.
  3. Jul 2, 2019 at 11:58 AM
    Theonlyway
    User
    Thanks for your response. These batteries are the group batteries that work with the genesis system.
    JohnLakeman[QUOTED] likes this.
  4. Jul 2, 2019 at 12:09 PM
    JohnLakeman
    Good thing the Genesis system provides you a spare battery. ;)
  5. Jul 2, 2019 at 12:09 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Blew the in line fuse? Direct short to the battery? Let us know? Good luck?
  6. Jul 2, 2019 at 12:14 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    You may have cracked something inside the battery, or the high current drain could have damaged a connection. Measure the voltage with the engine off, then measure it when you try to start it. If it measures 12 volts, but drops to near zero when you hit the starter, the battery's damaged. Next, jump start the truck and measure the voltage with the engine running. If it's less than 13 volts, you've damaged the alternator. A short like that can damage both quite easily.
    Theonlyway[OP] and JohnLakeman like this.
