Deeds/BAM Muffler Owners....A Resonator Question
Discussion in 'Performance and Tuning' started by SouthWestGA, Aug 28, 2020.
  1. Aug 28, 2020 at 11:51 PM
    SouthWestGA
    SouthWestGA [OP] New Member
    I put on my 10in BAM Exhaust
    The biggest I had was a 1.25in hole saw so I used that for the resonator
    I don’t think I have everything lined up exactly on the mark,as I didn’t see the video about the resonator install until afterwards.
    I plan on taking the rear tail pipe off and seeing what’s up sometime in the next few weeks And making sure everything is aligned. Hopefully i didn’t screw up too badly
    I still have a lot of low end drone and resonating in the cabin under engine load.
    For those of you who did no resonator at first,then installed the resonator,did you notice a huge difference?
    Im hoping that re aligning everything and getting a bigger hole quiets the drone down significantly. (And that i didn’t screw up my tailpipe too bad)
  2. Aug 29, 2020 at 3:12 PM
    SouthWestGA
    The wife just told me she hates my truck now. It wakes the kids up when i crank it up for work in the morning
  3. Aug 29, 2020 at 3:22 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Get the proper sized hole saw, I think it's a 2".
    Not sure how you are going to center it on the pipe already having a 1 1/4" hole in place.
    10" isn't that loud, certainly not loud enough to wake children just from starting the truck, unless they are sleeping in the back seat.
    I started with an 7" and swapped it for a 10".
    If all fails, you have 2 options;
    1. Ask Keith to swap your 10" for a 12" or even a 14". You just have to pay shipping for the new one and return of the old one. It cost me $180 when I swapped mine.
    2. Put your stock muffler back on, buy Keith's resonator hole cover and sell your BAM on the forum.
  4. Aug 29, 2020 at 3:25 PM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    The tailpipe resonator (with 2 inch hole) and properly aligned does make a difference with drone on the inside of the truck. The sound at the tailpipe will still be authoritative though.
    1lowlife likes this.
  5. Aug 29, 2020 at 3:39 PM
    SouthWestGA
    I plan on taking the rear tailpipe off and checking alignment/making the right hole sometime this week
    There are multiple options going forward
    I think it’s just an error on my part just trying to rush things while i had time without babies in the way
    it can be fixed either way
    i was mostly wanting input about how big a difference the resonator actually made
  6. Aug 29, 2020 at 4:25 PM
    AZ_Tundra1
    AZ_Tundra1 Gold member
    Phoenix, AZ
    2020 White Tundra SR5
    Bilstien 6112 front shocks set at 1.9"
    Can you post a video of how it sounds?
  7. Aug 29, 2020 at 4:34 PM
    SouthWestGA
    I guess i could get a video next week on one of my off days
  8. Aug 29, 2020 at 4:38 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    I don’t know if this will make sense, but from my experience there’s 2 elements to the sound - the burbly throaty v8 sound that is a mix of low and mid tones (and highs if you have a raspy exhaust, which the 10 inch is not) and a dominating deep frequency. The resonator gets rid of most of that dominating deep frequency without effecting the v8 sound too much. You’ll mostly notice it from inside the truck - not as much outside.
  9. Aug 29, 2020 at 4:45 PM
    marshall50w
    marshall50w New Member
    2011 Tundra Limited TRD Barcelona Red
    I bought the 8" and drove for a few weeks w/o resonator. A bit too much on my short commute...particularly cruising in the 22-2500 rpm range. I put the resonator on and it made a HUGE difference. Love it. I can now listen to music or a podcast w/o the overpowering drone. Truck still sounds way better than stock
  10. Aug 29, 2020 at 5:01 PM
    SouthWestGA
    Thanks for the input guys
    I’ll pay more attention to my rpm/speed and sound while on my short commute and see if i can narrow down anything specific drone wise
    I understand what you guys are saying about tones.
    I truly believe it’s my error with the Resonator that’s causing my excessive drone
    I don’t mind the outside sounds of the truck,as long as I’m not hearing the low droning inside
    I am still getting adjusted from having stock exhaust as well
    Thanks for everyone’s explanations and ideas
  11. Aug 30, 2020 at 5:17 AM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    If it wakes your kids up when you crank the truck, I don’t think the resonator is going to cancel that sound out. I have a 10” without the resonator. My kids and wife haven’t even noticed it while driving. May need a new wife.
  12. Aug 30, 2020 at 5:36 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I have what is probably the quietest BAMuffler system ever made, as expected it's still louder than stock even with a drone killing resonator that is 6" longer than Keith's standard resonator.
    Is your tail pipe full length, or has it been shortened?
  13. Aug 30, 2020 at 6:09 AM
    SouthWestGA
    It appears to be the stock one that cane on my 07 CrewMAX
    If I have the time this afternoon i plan on checking out the tail pipe and resonator
  14. Sep 8, 2020 at 7:14 AM
    SouthWestGA
    Well i took the tail pipe off and made the proper sized hole.
    it still drones like crazy. The echo is killing my head.
    I can deal with the louder exhaust tone coming from the tail pipe
    I can’t handle the drone inside the cab
  15. Sep 8, 2020 at 7:20 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Hmm...that's strange. Can you take pics? Also, not sure if it matters but does the resonator kinda point upwards?
    I have a 10", drove it for about a week or 2 without the resonator and then put it on, was definitely a difference I can tell and I don't have any crazy drone like yours but more of a nice hum while speeding up
  16. Sep 8, 2020 at 7:23 AM
    SouthWestGA
    Maybe I should call it a hum. I dunno.
    But whatever it is,it’s excessive and definitely not pleasant
    If I barely touch the gas pedal or idle it’s a nice even tone you can’t even hardly tell anything is different than stock
    If I’m in low gears or going up an incline then it sounds horrible to me inside the cab
    i tried to take a video of the sound but you can’t hear it on my phone. It just sounds like white background noise
  17. Sep 8, 2020 at 7:25 AM
    paradizecityz
    Richmond, TX
    Yeah, not everyone will like the same sound. For my wife and kids, they have no issues with the 10"
    It's possibly too loud for you then and maybe a larger one will suit your ears.
    If anything, call and talk to Keith, he should be able to help you out.
  18. Sep 8, 2020 at 7:32 AM
    SouthWestGA
    I’m sure it can be fixed
    But then I have to ship it there and back which equates to more $$$ being spent
    I think I’ll just be Selling it and going back to stock quietness
    To be clear,it’s not the tone out of the tailpipe that’s the issue
    It’s the reverb noise heard and felt in the cab that is the issue
  19. Sep 8, 2020 at 7:40 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Pointing up or down doesn't matter. When I ran his dual resonator setup on my TRD exhaust, the driver side pointed down. I used that resonator on the passenger side of my current 8 inch BAM, and it points down too - minimal to no drone.
    I think the purpose of pointing up is so condensation doesn't collect.
  20. Sep 8, 2020 at 7:52 AM
    SouthWestGA
    What do you hear inside the cab?
    That’s what I’m wanting to know
  21. Sep 8, 2020 at 7:54 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    To the OP - How many miles did you drive with the OEM exhaust?
  22. Sep 8, 2020 at 7:58 AM
    Rex Kramer
    Georgia
    I didn't do the best job installing my BAMuffler, and installing the resonator made matters worse. Keith mailed one of his blocking plates to me right away, I installed it but I wasn't happy with the sound. I finally crawled under the truck and discovered that none of my connections were tight, so I loosened, aligned and tightened all of the bolts... it sounded right but it droned. I reinstalled the resonator, this cut the drone but not enough. Since I cut 24" off my tail pipe for clearance, Keith sent me a brand new resonator that is 6" longer than standard. I installed the new resonator and all is well. If your tail pipe has not been cut, you probably won't need the longer resonator... I recommend that you inspect your installation, and maybe reset it. And yes the closed end of the resonator should be as high as possible for condensation drainage.
    GODZILLA likes this.
  23. Sep 8, 2020 at 7:59 AM
    SouthWestGA
    I have only had my 07 CM for a year and about 10k miles
  24. Sep 8, 2020 at 8:06 AM
    paradizecityz
    Richmond, TX
    It's just a hum, nothing crazy either. It's just a noise that tells me that I have something different than stock. Also, it's only around the 2000 RPM so unless you speed up real slow or in a gear that's in that area, it hums just for a bit
  25. Sep 8, 2020 at 8:06 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    I think the pre-2014 Tundras had a longer OEM muffler than the 2014+ models so they are very quiet. The 2014+ models have a hint of drone - even with the OEM muffler. But it's not over bearing or annoying. The BAM muffler sound would be a slightly deeper version of the 2014+ OEM (in terms of what you would hear), but since your reference point is a 2007 - you're going from near silence to a bit of drone.
    Rex Kramer likes this.
  26. Sep 8, 2020 at 8:08 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Agreed
  27. Sep 8, 2020 at 8:12 AM
    SouthWestGA
    I get that above 1,600rpm
    Anything below and it’s like it drops into a separate deep category
    like it has 2 stages
    Ill re check everything again sometime this week and see what Keith has to say
  28. Sep 8, 2020 at 8:15 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    This is a great example of why what someone else tells you makes no difference at all, everyone perceives things differently. My experience with the same system is exactly the opposite, I can hear my radio fine and easily have conversations without the resonator
  29. Sep 10, 2020 at 7:06 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I tend to agree with this.
    I was quite surprised at how much sound I get from my 2020 Crewmax... from both the tailpipe AND the engine compartment.
    I like the sound... and wouldnt want it any louder... but would like a better flowing, dual system if possible.
  30. Sep 10, 2020 at 7:17 AM
    The stock exhaust is pretty dialed in for the 5.7. If you get a larger pipe or duals you will actually lose the back pressure the engine needs, so you will take a hit to your low end torque. Per Keith, the Exhaust Guru. Just something to keep in mind.
