DECKED for First Gen Tundra!! The homemade edition
Discussion in '1st Gen Tundras (2000-2006)' started by 1stgentundradriver, Aug 30, 2021.
  1. Aug 30, 2021 at 11:25 PM
    1stgentundradriver
    1stgentundradriver [OP] Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Alright y’all!! I finally pounced. I have been wanting a Decked system for my First Gen Double cab Tundra ever since I got it. I had been begging Decked to make one for me. Greg Randolph from Decked helped me out a ton by giving me the best model to purchase (details on everything will be below). I decided not to buy a new one because I was going to have to cut it up anyways and that would void the warranty. Just this weekend I bought a Decked system for a 2009-2011 Ford truck (sku is DS2 I beleive) and both my parents and I got involved in cutting it to fit my truck as well as installing it. Here is what we did. I hope you enjoy the finished (almost) product as much as I do.
    Step one- I bolted together the two halves with the supplied bolts. I proceeded to cut off 7/8 of an inch on each side.
    Step two- I unbolted the two halves from each other and I put the drivers side into the bed of the truck. I trimmed about 3/4 of an inch to fit the tailgate bump.
    Step three- this was the most difficult part of the journey for me. My mom basically made a template of the bedside so that I could draw a line and trim. I had to trim off enough of the system to move it 3 inches closer so it was centered. This was a long and tedious process but it basically ruined the ammo cans in the back. I figured this would happen. I used a sawzall and a jigsaw for the cutting. It was scary cutting into a perfectly good decked drawer system but sometimes you gotta give it a little send.
    The trimmed edge-
    I basically had to butcher the rear ammo cans. I figured this would happen. But this is now what they look like.
    Step four- I needed to put a second set of tie down rings in the bed. I put these in the lower corner of the bed and pre drilled holes for them as well. This was a pain in the butt. I don’t have pictures of the finished product because the decked system blocks them. But these are the rings I used. I was able to use the front rings for the decked system 59D17705-E780-4FFC-8F25-70F6ABB96D4B.jpg
    The next step was to bolt the two sides together and tie it down. EF840CD8-8E0A-4A1A-91BD-F45F87B44433.jpg
    the last step would be to install the drawers and bolt the lower wheels in. I bought it already fully assembled basically so it was fairly straightforward once all the cuts were made and the tie downs were Installed and the deck was tied down to the bed.
    here is what I started with. Ford 3/4 ton drawers and a normal truck bed. 09F6168D-1E88-47EC-9C0A-0BA6FB0B97CB.jpg
    And here is the finished product- a good decked system with both drawers and both front ammo cans fully functioning!!!C0035EAA-CCBC-49A8-BEB4-E03CE15613AD.jpg
    Here is an update with the rear ammo can lids fitting on good. 87FD3AF5-40A4-4AB6-B058-9828802BB548.jpg
    I have been dreaming about this for awhile and it has been about a year long process between gathering information and actually buying this system off Craigslist and installing it in the truck. Couldn’t have done it without the help from my family.
    Only things left to do are to figure out a way to secure things like an ATV onto the deck and to finish the rear ammo can lids for a cleaner look. 95% done.
    Info needed- Decked system is from a 2009-2011 Super Duty Ford truck. I believe the SKU is DS2 on the decked website.
    There are some odds and ends here and there (measurements) that will vary on each system and truck that is installed so not everything is perfect…but definitely good enough for me.
    I would also like the part number for the screws that hold down the ruler that goes on the top. My decked system did not come with them. Prodding @decked for some freebies… :)
    Oh, and one more thing. My dad just bought a decked for his truck too :)
    jimf909, YotaBro, jjinri and 16 others like this.
  2. Aug 30, 2021 at 11:52 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Nice work bud! I hope it lives up to your expectations!
  3. Aug 30, 2021 at 11:52 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I hope it does too!
  4. Aug 31, 2021 at 3:20 AM
    thunder100
    thunder100 New Member
    MD
    Black 06 DC 4x4
    Looks sweet, never seen those before! What’s the weight capacity on the deck?
  5. Aug 31, 2021 at 6:36 AM
    You could use some of the stake pocket tie downs for a 4 wheeler since it's gonna be up higher. Gotta make sure to protect you back window from the 4 wheeler. A removable headache rack would be safest. Decked system looks amazing. Would love one of those.
  6. Aug 31, 2021 at 9:08 AM
    I feel like Decked should GIVE YOU the freebies after this helpful write-up which will undoubtedly lead to at least a couple of product sales.... :D
  7. Aug 31, 2021 at 9:11 AM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Weight capacity is supposed to be 2000 lbs and 200lbs per drawer.
  8. Aug 31, 2021 at 9:13 AM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Yeah I was going to do that since it’s probably the cheapest route for me. I’ve never seen a headache rack that quick released…maybe it’s time to make one?
  9. Aug 31, 2021 at 9:13 AM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Right??! That’d be super cool!
  10. Sep 25, 2021 at 11:31 AM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    A little update…I went to a screw specialty store in town and bought some screws for the decked ruler that goes on the back. I also ordered some core trax from decked as well. 53D2D0DF-8300-47F2-A8F5-F74907BC958E.jpg
    I’d say it’s just about complete!!
    SharkDog, YotaBro, KNABORES and 5 others like this.
  11. Sep 25, 2021 at 12:03 PM
    Blue Thunder
    Washington
    Very slick. Nice work. Glad everything thing still functions
  12. Sep 25, 2021 at 3:15 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Thanks!
    mcharfauros likes this.
  13. Sep 28, 2021 at 6:50 AM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    robabeatle, des2mtn and FrenchToasty like this.
  14. Sep 28, 2021 at 7:42 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    "my truck identifies as a prius" :rofl:
    :thumbsup:
  15. Sep 28, 2021 at 7:43 AM
  16. Sep 28, 2021 at 6:20 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I’ll be stopped at a light and I’ll look in my mirror and see somebody taking a picture of my rear end :benchpress:
  17. Sep 29, 2021 at 6:16 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Nice! is that a 300EX, or a later 400EX?
  18. Sep 29, 2021 at 6:51 AM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    It’s a later 400ex…if 2005 is considered later model:). They are great machines! We’ve got two of them. They’re great in the dunes, trails, and in the desert. Just a well rounded machine.
    lsaami[QUOTED] likes this.
  19. Sep 29, 2021 at 7:11 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    got it. I've got an early 400ex, the bugeye model without reverse.
  20. Sep 29, 2021 at 3:28 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Heck yeah! Sweet dude. The bugeye is so cool! At the dunes I’ve seen a couple guys running light cubes instead. Seems easier to mod the bugeye for better lighting than the other ones.
  21. Sep 29, 2021 at 7:32 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    1st gens and 400ex’s
    We must be the coolest guys in town.
  22. Sep 29, 2021 at 9:36 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    That’s exactly right. Any of you have any mods done to yours or are they stock?
    lsaami likes this.
  23. Sep 29, 2021 at 9:38 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Mines stock with aftermarket filter. Waiting on a carb rebuild kit.
    used to run a mx track south of houston, a 3/8 dirt oval, and little sahara, ok. 9D7C9A78-9A48-4FAF-A517-920C7B6289D4.jpg
  24. Sep 29, 2021 at 9:39 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Ended up having an issue with the decked core trax…I had a screw rip out of the system…not good!! I wasn’t overloading anything (just a quad) so I’m wondering what the issue was? Who knows. Kinda upsets me because the core trax alone were 120 dollars and had a combined 1000 pound pull out rating. Much overkill for a fourwheeler. And water leaks in where the screws hold the trax down. Not happy about that either.
  25. Sep 29, 2021 at 9:42 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    We love the dunes on the oregon coast. Close enough for us and beautiful. 24FC2301-924C-4398-97EA-A097DD2307F9.jpg
    Stock here except a -1 tooth in the front sprocket and a +3 tooth on the rear sprocket. Top speed isn’t used all that often for me but the gear change allows me to climb dunes in 3rd and downshift to 2nd.
    Lil Steve and Sirfive[QUOTED] like this.
  26. Sep 29, 2021 at 9:45 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Can you put a block of wood under the deck, that the screws run into? Or plastic, maybe glue em in to grab all the threads, but keep the hole blind?
  27. Sep 29, 2021 at 9:47 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Thinking about drilling through the steel tubes it is mounted to and bolting each one down. Then caulking around and inside of it. If that fails I’m ripping it all out and patching the holes with Jb weld. I’ll drill holes for different tie down mounts in my bed.
    Sirfive[QUOTED] likes this.
  28. Sep 29, 2021 at 9:49 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    If you watch the Install video the instructions say not to drill through both layers of steel. I for sure only drilled through one layer. It just confuses me why they leak. I bought the drawers because they don’t leak:angrygirl:
  29. Sep 29, 2021 at 9:49 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    My buddy with the rzr has those track things screwed to the floor of his trailer, pretty stout, and his straps are like 4” wide trucker straps.
  30. Sep 29, 2021 at 9:50 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I don’t get it! Whatever. Just my luck. I’ll figure it out sometime I guess. But if I can’t put the trash cans or the quad in the truck I can’t really use it as a truck.
