Deaver K37 vs U748. Pros and cons ?
Discussion in 'Suspension' started by TheBeast, Oct 31, 2017.
  1. Oct 18, 2019 at 9:23 PM
    #241
    longcat
    longcat New Member
    Jon
    DFW / Texas
    2024 Tundra 4x4 Hybrid CrewMax (Silver)
    Just happen to have a set in my garage I need to install....
    center bolt from leaf to leaf is right about 3". If you measure from one end of the bolt to the other it's about 3 1/2"
    Flyinryank and TheBeast[OP] like this.
  2. Oct 18, 2019 at 10:50 PM
    #242
    TheBeast [OP] The Beach
    perfect. thanks guys. :thumbsup::thumbsup:
  3. Mar 24, 2020 at 9:26 PM
    #243
    TurboGoKart
    TurboGoKart New Member
    Quick question, what is the difference between the U748 and U748L? The overload leafs? Is there a difference in haul weight, performance, etc?
    Flyinryank likes this.
  4. Mar 25, 2020 at 1:08 AM
    #244
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Good question :help:
  5. Apr 6, 2020 at 7:32 AM
    #245
    M C M
    M C M New Member
    The L designates that its for the left side.
    papasmurf, Flyinryank and Ace402 like this.
  6. Jul 5, 2020 at 8:44 AM
    #246
    Jackjack
    Jackjack New Member
    Jack
    White tundra
    Who did you get your set up through? MCM? Have you heard anything on the 3 inch deaver springs? Was thinking of getting this exact setup but might go with the 3 inch if I can get someone local to install. Corona Ca.
  7. Jul 5, 2020 at 9:51 AM
    #247
    Stewie
    Stewie New Member
    2016 Crew Max
    Yes, i bought everything from MCM. Being in Corona, you should go direct to Deaver or Atlas for the leafs. They can make them exactly for the weight that you’ll be carrying.
    edited to address the 3” leafs.... They would be preferable to any of the shelf leaf packs available for our trucks. SS Built is local to Corona I think and they could do the install. Or check out Steal Nutz.
    @Jackjack
    joonbug likes this.
  8. Jul 5, 2020 at 10:07 AM
    #248
    Stewie
    Stewie New Member
    2016 Crew Max
    You also need the mount kit for the 3” leafs. Get with @papasmurf
    papasmurf and joonbug like this.
  9. Jul 5, 2020 at 10:46 AM
    #249
    just go direct to Deaver. call them/email first to see if they have them in stock and make appointment. I went there last time when I swapped my K37s for the expo pack.
    shipping on leaf pack is killer.
  10. Sep 27, 2020 at 11:14 PM
    #250
    so_juanderful
    so_juanderful New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
    Just installed u748 today is it normal that the axle shifted slightly to towards the rear?
    406Michael and porkitt like this.
  11. Sep 28, 2020 at 1:25 PM
    #251
    nice setup. which shackles are you using ?
    yeah the axle shifting doesn't look too good. My wheel still centered post leaf pack install.
  12. Sep 28, 2020 at 2:04 PM
    #252
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I agree with @TheBeast - the axel shift does not look right. My wheels were centered after install too. Before installing I noticed that the center pin was not straight so I had to hit the leafs back so that the pin was vertical. Were the center pins lined up correctly in the leaf pack? This was before adjusting:
    TheBeast[OP] likes this.
  13. Sep 28, 2020 at 10:07 PM
    #253
    so_juanderful
    Honolulu, HI
    Camburg
  14. Sep 28, 2020 at 10:22 PM
    #254
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Stupid question, but is the front and back half of the leaf the same length?
  15. Oct 1, 2020 at 10:46 PM
    #255
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    It looks like your Ubolts are like 3/4” too short. From what I understand the bolt thread should extend past the nut the length of the nut for bolt strength because of Ubolt stretch. is the spring pack way taller than stock?
    Also are the camburg shackles long enough for those springs? Or Could the leafs possibly be installed backwards? Ive only done rear shackles on Tundras, full packs on Tacomas . But I've installed a lot of lifts on other brands of trucks and rock crawlers. Mine has 3” coachbuilder shackles and the wheel sits centered. The king bumpstop looks like it wont hit the plate centered.
  16. Oct 2, 2020 at 2:28 AM
    #256
    so_juanderful
    Honolulu, HI
    When I took that picture the u bolts weren’t entirely torqued. There was way more threads showing after torquing down.
    Camburg advertised that their shackles are specific for Deavers leafs.
    I thought it might be backwards but all the photos I’ve seen of Deavers the sticker is towards the front of the truck.
    I’ve messaged Deaver but no reply
    PeakIT[QUOTED] likes this.
  17. Oct 2, 2020 at 7:30 AM
    #257
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Ok let me clear some stuff up....
    1 - ubolts are ubolts, there is nothing special about them, they are certain lengths widths and sizes, but nothing more than that , you have the correct ones
    2- based on the stickers, you have them in the correct location. L is the driver side, R is the Passenger side.
    3 - while yes your axle looks like its back a bit, that's not going to hurt anything, your pinion angle is good, and when you cycle the suspension your rear axle actually travels in an arch, not straight up and down. So if you went full bump your wheels would be about an inch or more to the rear... so you shouldn't have any issues here.
    4 - your driveshaft collapses and extends, so no issues there
    So id say run it and see how the truck performs any weird noises. From there call Deaver talk to Scott and see what he says, but honestly, I think it's fine. I wouldn't get too hung up over it.
    Archive and so_juanderful like this.
  18. Oct 2, 2020 at 7:53 PM
    #258
    so_juanderful
    Honolulu, HI
    SDHQ just got back to me apparently I wasn’t paying attention to the double wrapped eyelet should be towards the front. Instead I was judging by the sticker, smh. Will flip it tomorrow.
  19. Oct 3, 2020 at 12:13 PM
    #259
    so_juanderful
    Honolulu, HI
    For those noobs like me, make sure to have the double wrapped eyelets facing towards the front. Big thanks to Brice at SDHQ for getting back to me ASAP.
    n0rth, Skew12, Talon7 and 10 others like this.
  20. Oct 3, 2020 at 12:26 PM
    #260
    much better
    Talon7, Chowdah and so_juanderful like this.
  21. Oct 3, 2020 at 12:35 PM
    #261
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Which bump kit is that?
  22. Oct 3, 2020 at 1:26 PM
    #262
    so_juanderful
    Honolulu, HI
    They are King 2.0 Bump Stop kit (20AB001-105). Bought through Toytec. They come with striking pad compatible with stock u-bolts. I got the ubolt flip kit with striking pad from Archive Garage.
  23. Oct 3, 2020 at 1:29 PM
    #263
    what size are the new tires ? at least 35 right ?
  24. Oct 3, 2020 at 1:50 PM
    #264
    so_juanderful
    Honolulu, HI
    Old were 295/70r18 Nitto Trail Grapplers. New ones are 37x12.50r17 BFG KM3.
    TheBeast[QUOTED][OP] likes this.
  25. Oct 5, 2020 at 7:30 AM
    #265
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Ah yup , that would do it. I should have mentioned, glad you got it sorted.
    so_juanderful[QUOTED] likes this.
  26. Jan 23, 2021 at 7:40 PM
    #266
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    I need some help here guys... I'm currently running the original (pre-Aluma) Toytec Boss kit on my '18 Crewmax with the Boss internal reservoir shocks (for now) and Toytec shackles set at 1.5" of lift. I'm in need of a spring setup that will yield the same lift that I currently have, but resist sagging when loading up the bed with dirtbikes or loaded with camping gear while towing my overland trailer. It is really amazing how the rear of these trucks sag with so little weight. I run unloaded most of the time.
    I'm thinking the U748 setup will fit my needs and help with the sag avoidance, can anyone confirm? Will they work with the Boss shocks and can I use my Toytec shackles, or should I get the MCM shackles? Do I need to buy the bushings that @M C M offers?
    I've also looked into the OME Dakar setup, but they say that adds 2.5" of lift, which is too much. It's all very confusing what works with what. Thanks for the input!
  27. Jan 23, 2021 at 7:44 PM
    #267
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Perfect rear springs are a unicorn. Either you need extra lift or extra stiffness to avoid sagging with load. The stiffness stinks in daily driving. Is offroading flex an issue for you?
    Jeff_1974 likes this.
  28. Jan 24, 2021 at 9:15 AM
    #268
    Hoologan
    Hoologan New Member
    California
    I would say travel is a secondary concern as I don’t do anything too crazy in terms of offroading.
  29. Jan 24, 2021 at 9:36 AM
    #269
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I’m currently looking into roadmaster active suspension. The reviews i am reading are that they prevent sag really well and possibly even add a slight lift
  30. Jan 24, 2021 at 10:03 AM
    #270
    13TundraRW
    13TundraRW New Member
    Kyle
    San Diego, CA
    2013 White Tundra CM RW
    MCM UCA, MCM Shackles, 2.5 ADS C/O, Durobumps Front, Deaver U748, 2.5 ADS Bypasses, Wheelers/Timbren bumps rear, SoftTop
    Even with U748 you will sag with 2 bikes and gear. If you are worried about sag while loaded and a decent ride empty you will want to look into air bags.
