Deaver K37 vs U748. Pros and cons ?
Discussion in 'Suspension' started by TheBeast, Oct 31, 2017.
  1. Jan 15, 2019 at 2:02 PM
    #211
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    I see. I’m just trying to find a combo while also getting new leaf packs from Deaver that will give me 1.5” of lift in the rear
  2. Mar 11, 2019 at 9:27 AM
    #212
    motod6
    motod6 New Member
    David
    2015 White TRD
    I got 3" + with U748 and TC shackles on a double cap. Hoping it settles a lot
  3. Mar 11, 2019 at 9:38 AM
    #213
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    Get MCM fab shackles
    Flyinryank and TheBeast[OP] like this.
  4. Mar 11, 2019 at 9:39 AM
    #214
    Tacotundra
    Vegas
    2022 Tundra
    Wow that's pretty high. It should settle some.
    TheBeast[OP] likes this.
  5. Mar 11, 2019 at 9:41 AM
    #215
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Can someone with k37’s or u748 measure how thick the spring pack is for me?
    Pinay likes this.
  6. Mar 11, 2019 at 10:05 AM
    #216
    motod6
    motod6 New Member
    David
    2015 White TRD
    Man I really hope so. Between the fox 2.5 lifting the front to the moon now the deavers doing the same, I'm a little concerned about all my angles. Not to mention looks like poo. Guess I'll take it to the dirt and hammer on it. Then after i'll loosen everything and tighten it all under its own weight. Hopefully goes down :fingerscrossed:
    Tacotundra[QUOTED] likes this.
  7. Mar 11, 2019 at 11:54 AM
    #217
    TheBeast [OP] The Beach
    it should settle
  8. Mar 11, 2019 at 12:14 PM
    #218
    M C M
    M C M New Member
    Our shackles are similar, it won't help him any.
  9. Apr 21, 2019 at 8:41 AM
    #219
    Yota100
    Yota100 New Member
    14 Tundra 4x4 97 T100 4x4
    14 Tundra 2.5 kings all around with remote reservoir and adjusters with 700# springs Total chaos bushing style control arms Camburg 1.5 inch lift shackles Coachbuilder polt bushings in leaf springs Bmc and front bumper trimmed 37x12.50x17 toyo MTs 17 inch Icon rebounds +25 offset 5% tint Winjet taillights True dual flowmaster super 40s ARB summit bumper Smittybuilt 12k winch White Knuckle Offroad sliders
    How are the u748s with towing occasionally I will be towing my drag car and possibly my t100 working on setting up my tundra right now
  10. Apr 21, 2019 at 9:13 AM
    #220
    motod6
    motod6 New Member
    David
    2015 White TRD
    I tow a xj Cherokee once in a while that squatted the rear with stock springs to the bumps. The u748s definitely aren't worse for me but I do throw in some timkens and spacers when towing. Works great. Just swap in superbumps when I'm not towing
    Yota100[QUOTED] likes this.
  11. Apr 21, 2019 at 9:19 AM
    #221
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    U748’s
    a_double likes this.
  12. Apr 21, 2019 at 10:27 AM
    #222
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Thats one hell of a steel sandwich!
    TheBeast[OP] and Pinay like this.
  13. Apr 21, 2019 at 10:28 AM
    #223
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  14. Apr 21, 2019 at 10:39 AM
    #224
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    What makes no sense to me...if my stock springs are flat. And the deavers are 1.5 inches taller than stock.
    Are the deavers flat too? They claim 1.5 inches of lift.
  15. Apr 21, 2019 at 11:03 AM
    #225
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  16. Apr 21, 2019 at 11:05 AM
    #226
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Hmm. My stock leaves are so flat i would probably get 2.5 out of deavers as well
    Pinay likes this.
  17. Apr 21, 2019 at 11:08 AM
    #227
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    My old Rough Country lift was 6” and the top of my roof was just a smidge under 7foot. Now I would say I’m about 76” which is not quite 6.5 foot.
    Fishin RGV-Trd Pro likes this.
  18. May 1, 2019 at 1:30 PM
    #228
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Anyone have experience with the u748 and coachbuilder +2s?
    Yotax109 and zachzap361 like this.
  19. Jul 2, 2019 at 8:48 AM
    #229
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    So i'm ready to make the move on K37's....i've currently got toytec shackles on the lower (middle) setting......can I run these, or no? I don't want more of a lift then I currently have...which is about .5-1" over stock...
    GiantsFanDan likes this.
  20. Jul 8, 2019 at 7:01 AM
    #230
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    K37s inherently have 2" lift over stock and your shackles on the lowest setting is 1" of lift, so you'll get more lift with k37s.
    HBdirtbag[QUOTED] likes this.
  21. Jul 8, 2019 at 7:06 AM
    #231
    I think you should be fine. You can also run the TC or MCM shackles designed for Deavers packs. They are a bit more low profile than Toytec or coachbuilder which are beefy pieces of metal :)
  22. Aug 29, 2019 at 5:18 AM
    #232
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
  23. Aug 29, 2019 at 5:27 AM
    #233
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    I’m interested in this also—sub’d.
    Thanks.
    zachzap361 likes this.
  24. Sep 18, 2019 at 9:43 PM
    #234
    Diverpaul
    Diverpaul TRD ROXX
    Paul
    2016 White Tundra TRD Pro
    Fab Four front/rear bumpers, Warn VR12S
    Can you do U748 on a Procomp 6" lift.
  25. Sep 18, 2019 at 10:04 PM
    #235
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You can, but there is no reason to. You want to get a 6 inch lift spring made so you don’t need blocks as well
  26. Sep 19, 2019 at 9:54 AM
    #236
    Diverpaul
    Diverpaul TRD ROXX
    Paul
    Does Deaver do that?
  27. Sep 19, 2019 at 9:55 AM
    #237
    GravityGear
    Aurora, CO
    They will make custom springs. You just need to call and tell them what you need.
  28. Sep 19, 2019 at 10:22 AM
    #238
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Which also helps you get a 35in spare under the back!!
    TheBeast[QUOTED][OP] likes this.
  29. Oct 18, 2019 at 8:42 PM
    #239
    can someone who owns a U748 leaf pack measure how thick it is at the middle ? thanks.
  30. Oct 18, 2019 at 9:00 PM
    #240
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    About 3”.
