Deaver K37 vs U748. Pros and cons ?
Discussion in 'Suspension' started by TheBeast, Oct 31, 2017.
  1. Dec 18, 2017 at 6:46 AM
    #91
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I have my Toytecs on the middle setting. I think they're awesome, got me the lift I wanted, and I think the new bushings helped improve the ride, but I'm also looking at going with some Deaver U748. I asked MCM Fab if I could run the Deavers with the Toytecs and still stay at about 1-1.5" lift where I'm at now. He said that would be possible if I set the Toytecs at the lowest setting, but I'm pretty sure there's not enough room above the shackle to do this. I already had to trim one of the bolts sticking down above the shackle. According to Toytec, they can only be used at the middle and top settings with Tundras. I'll probably end up having to use whatever shackle MCM sells with the Deavers (and a set of Deaver spec'd ADS bypasses :frusty:).
  2. Dec 18, 2017 at 6:49 AM
    #92
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Same
    Backslider[QUOTED] likes this.
  3. Dec 18, 2017 at 6:49 AM
    #93
    Backslider
    Backslider Thirsty...
    Tooele, UT
    That is my concern with the Toytec shackles as well. I read a post somewhere on this forum where someone was complaining of a squeaking noise from the bed of their truck after installing the Toytec shackles on the middle setting. He finally tracked it down to the top of the shackle rubbing against a bolt head. Based on his experience I don't think they'll work for me on the lowest setting.
    I shouldn't have gone on the top setting but wanted to see what it would look like - it ended up flattening my leaf springs very quickly. I'm also considering getting a refresher leaf and trying to add 1-1.5" and would just go back to the factory shackles. Either way would be fine. I don't tow often and when I do it's ~3500lbs.
  4. Dec 18, 2017 at 6:52 AM
    #94
    Eclipsed & Floating
    Voluptuous Whitey
    Mind if I piggy back your question? I’m also experiencing your pains
  5. Dec 18, 2017 at 6:54 AM
    #95
    Backslider
    Tooele, UT
    Not at all - hopefully we can figure it out. It's not critical but probably the next project I will tackle on the truck. I see my bed bouncing around like crazy and it feels like crap because of the flat springs.. Particularly on concrete highway - the change from slab to slab feels like I'm driving over millions of speedbumps. Is yours the same?
  6. Dec 18, 2017 at 6:54 AM
    #96
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I think I read the same post about the squeaking. I'm not sure if I had any squeaking, but there was definitely a little contact between the bolt and shackle.
    Don't worry too much about flattening your springs on the top setting. Mine are flat now on the middle setting. I rarely tow, but I do have a shell on 365 days a year that adds 200-300 lbs. @M C M suggested the U748 over the K37.
  7. Dec 18, 2017 at 6:59 AM
    #97
    Eclipsed & Floating
    Voluptuous Whitey
    Yes, and I’ve already swapped to a second set of OEM springs with an AAL
    UTTundra likes this.
  8. Dec 18, 2017 at 7:00 AM
    #98
    Eclipsed & Floating
    Voluptuous Whitey
    I don’t have a topper by I do have 350+ atalltimrs
    dcsleeper408 likes this.
  9. Dec 18, 2017 at 7:03 AM
    #99
    Backslider
    Tooele, UT
    There's a "yo momma" joke wandering around here somewhere..
    I'll be adding a bed rack eventually as well. Interestingly my ride is much nicer right now with 200-300lbs in the bed..
  10. Dec 18, 2017 at 7:03 AM
    #100
    Backslider
    Tooele, UT
    I just realized I've queued up another "yo momma" joke..
    Eclipsed & Floating likes this.
  11. Dec 18, 2017 at 7:03 AM
    #101
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    U748 are designed to handle extra weight better and ride nice.
    Then you want the U748 also. I have that setup works great.
  12. Dec 18, 2017 at 7:04 AM
    #102
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I sense a Deaver + ADS shock group buy in the future!
  13. Dec 18, 2017 at 7:04 AM
    #103
    Eclipsed & Floating
    Voluptuous Whitey
    Yep
    I was already saving my pennies :thumbsup:
    Tacotundra[QUOTED] likes this.
  14. Dec 18, 2017 at 7:05 AM
    #104
    Eclipsed & Floating
    Voluptuous Whitey
    If you pull it off I’m first on the list
  15. Dec 18, 2017 at 7:05 AM
    #105
    Tacotundra
    Vegas
    2022 Tundra
    You won' regret it!!
  16. Dec 18, 2017 at 7:06 AM
    #106
    Eclipsed & Floating
    Voluptuous Whitey
    The RTT And rack vs MOAB is what has killed mine
  17. Dec 18, 2017 at 7:06 AM
    #107
    Eclipsed & Floating
    Voluptuous Whitey
    That’s what I keep hearing
  18. Dec 18, 2017 at 7:12 AM
    #108
    Eclipsed & Floating
    Voluptuous Whitey
    Yo momma would be proud if you got some Deavers
  19. Dec 18, 2017 at 7:13 AM
    #109
    Tacotundra
    Vegas
    2022 Tundra
    @Backslider , @Almaboy and @TundraUTAH sounds like you guys all need the U748 ADS setup will work perfect for what you guys described. I went with it for when loaded with gear, dirtbikes or the occsional tow.
  20. Dec 18, 2017 at 7:15 AM
    #110
    Eclipsed & Floating
    Voluptuous Whitey
    @M C M
    How many do we need for Group Buy?
  21. Dec 18, 2017 at 11:10 AM
    #111
    TheBeast [OP] The Beach
  22. Dec 18, 2017 at 11:11 AM
    #112
    I'm in for the Deaver spec ADS bypass if group buy...love my K37s and MCM shackles. Great service from @M C M as well ;)
  23. Dec 18, 2017 at 11:27 AM
    #113
    MCM or Total Chaos shackles. A lot beefier that stock ones but still get 3/4 to 1". Best of both world imo.
    Sunnier, Tacotundra and dcsleeper408 like this.
  24. Feb 19, 2018 at 5:26 PM
    #114
    so_juanderful
    so_juanderful New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
    Is there any difference in lift height between the Deaver K37 and U748?
  25. Feb 19, 2018 at 5:48 PM
    #115
    avgasman
    avgasman New Member
    It never ends does it?
    My best guess from my recent buying experience is - no they are the same ride height unloaded. The extra ride height is tied to the extra length of the shackle.
    so_juanderful[QUOTED] likes this.
  26. Feb 19, 2018 at 6:19 PM
    #116
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Don’t want to derail this fun. But heseva pic of my 6 month old OME pack on stock shackles the right side looks like this and my left side looks a bit better but looks like it lost its archE0B3070E-9DCF-4914-9A79-FA7EE98FC259.jpg
  27. Feb 19, 2018 at 6:19 PM
    #117
    Theyfzman
    Pa
    08 TRD
    Look at the rear part of the pack behind the wheel
  28. Feb 19, 2018 at 7:15 PM
    #118
    same lift height.
  29. Feb 20, 2018 at 8:55 AM
    #119
    soarvet
    soarvet New Member
    2017 Silver Tundra Crewmax 4x4 XSP package
    I'd be down too for some u748's
  30. Jul 5, 2018 at 1:17 PM
    #120
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I know this is an older thread, but I wanted to give a shout-out to Matt MCM for his excellent support and knowledge with ADS and Deavers.
    2.5in ADS Resi Clickers in front (700lb spring) with MCM UCA
    2.5in ADS Bypass in back with extended travel to match to a set of Deaver U748 springs
    Took them out into the dirt (unloaded) and they were still in a whole different league than the stock setup I had before. Definitely not overly stiff.
    Lukie, Sunnier, Wrongside and 3 others like this.
