Dealership visit frequency?
Discussion in 'General Tundra Discussion' started by BTBAKER, Jun 25, 2018.
  1. Jun 26, 2018 at 5:20 PM
    #61
    12’ Tundra
    - 3 times replacing the drivers side seat belt guide. Not sure if something was wrong in manufacturing, but the seat belt would cut into the guide and almost into the interior panel. On the 3rd time, the dealership told me after that, the 400.00 job was on me, even though I was under 36k miles.
    I went home, put on my engineering hat and came up with a solution. Longer bolt purchased, shimmed guide out more. No more issues for 2.5 years.
    -Recall work done for AIP system.
    -Truck had a growling sound coming from the front end. I thought it started around ~60k miles. Around 68k miles it was obvious. I did a little of my own recon on the issue using the FIR gun at work (heat sesnsing). Both front bearings were cool after 20 miles of 75 mph. Pretty sure that wasn’t the issue. On my own research, the front differential, drivers side needle bearing was failing. Very common on Toyota’s with 4wd.
    Took truck into Toyota. We fought a little bit about having 6112 shocks on the lowest setting (.75” lift). They said it was definitely the front drivers side wheel bearing and it would be 1000+ to fix. I pulled out my Toyota Care card, handed him 75.00 and asked when it would be done.
    That was repaired, and did not fix issue. I called the Service center 3 blocks away from the dealership. I knew that it wasn’t test driven.
    Took truck back in. They offered the ECGS bushing fix, no warranty, 600.00, for Toyota’s shit design. I told them they can repair it under warranty. Then they said it would take some time.
    I went to the North Dealership and they ordered me a front differential (overnight) and had me completed the next day. 2400.00 was the bill, I gave them my Toyota Care card again and another 75.00 in cash.
    That’s about it. Sold the Tundra ~89k miles.
  2. Jun 26, 2018 at 6:46 PM
    #62
    What I posted is what I learned from him.
  3. Jun 26, 2018 at 7:15 PM
    #63
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Thanks. I’m not to concerned. I’m 100 percent confident my work is more thorough and by the book then the stoners they slap in their oil bays. If I had a guy that would take my truck in like you do I would probably go that route.
  4. Jun 26, 2018 at 7:21 PM
    #64
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Glad I about the Toyota Warranty. I think I have the 0 deductible but even at 75 bucks it will save me a grip if similar shit happens.
  5. Jun 26, 2018 at 7:23 PM
    #65
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    And Toyota says to retorque and grease the prop shaft. I know for a fact they don’t do that. I actually do. I’ve never had one that needed to be tightened though.
  6. Jun 26, 2018 at 7:25 PM
    #66
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    2014 w 36000 miles. Oil change every 10k miles that was the only purpose.
    geno0506 and BTBAKER[OP] like this.
  7. Jun 26, 2018 at 9:13 PM
    #67
    geno0506
    geno0506 New Member
    Michael
    Thats not bad, with my 5.7 FFV it's every 5000!
    Coolhardy[QUOTED] likes this.
  8. Jun 26, 2018 at 9:36 PM
    #68
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    I went to the dealer yesterday w 36000 miles for an oil change thinking its overdue. Was told its every 10k. Redused to take my money...
    geno0506[QUOTED] likes this.
  9. Jun 26, 2018 at 10:10 PM
    #69
    geno0506
    geno0506 New Member
    Michael
  10. Jun 26, 2018 at 10:13 PM
    #70
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Nope, i m guilty of supercharging it so its premium actually.
  11. Jun 26, 2018 at 10:13 PM
    #71
    geno0506
    geno0506 New Member
    Michael
    Cool, I sent a PM with a link!
  12. Jun 26, 2018 at 10:16 PM
    #72
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    I m old school when it comes to oil changes. Used to do it every 3000 miles and then changed to 5000.
    Have hard time digesting when dealer says, 10,000 miles.
  13. Jun 26, 2018 at 10:18 PM
    #73
    geno0506
    geno0506 New Member
    Michael
    I hear ya, that was me for years, then my wife and daughters Camry every 10,000, I was like what!
    But my 5.7 every 5,000!
  14. Jun 26, 2018 at 10:22 PM
    #74
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Agree. I have oil and filter sitting in the garage. I will just do it myself
  15. Jun 27, 2018 at 12:04 AM
    #75
    geno0506
    geno0506 New Member
    Michael
    Yeah, my ToyotaCare is runs out, Nov 14, 2018 or 25,000 miles, whichever comes first and I only have 13,000 on it!
    I'll at least try one DYI oil change myself and see if its worth it, I did feel a sense of pride when I did them myself years ago! :cheers:
  16. Jun 27, 2018 at 4:32 AM
    #76
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    2008 with the 4.7L
    134k miles (I bought it with 40k in 2011) - it was a leased vehicle that was well maintained.
    The only "issue" I had was the AIP stuff back in 2015, but it was replaced under warranty. Other than that, all my trips have been routine maintenance with oil changes, spark plugs, transmission flush, brakes, and the timing belt/water pump replacement for the 4.7L. The timing belt and water pump is scheduled to be serviced every 90k miles on them.
