Dead Rav4?
Discussion in 'Other Toyota Vehicles' started by Thattundradude, Dec 12, 2018.
  1. Dec 12, 2018 at 2:43 PM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    Hi all. Got a 2013 rav4 that wont start. It was starting up and driving just fine, gave it to a body shop and I have no idea what they did. When I went to check it out i tried starting and all it does is just crank crank crank. Theres no lights at all on the dashboard. Checked the fuse box saw that the alternator 120A fuse looked blown. Bought another one from advance auto and replaced it but still nothing.
  2. Dec 12, 2018 at 2:55 PM
    Thattundradude
    Platinum Tundra
    Lifted
    All other fuses are perfect. Body work
  3. Dec 12, 2018 at 3:04 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    If it happened at the body shop, they need to figure this one out.
  4. Dec 12, 2018 at 3:39 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Don't think its fuel
  5. Dec 12, 2018 at 3:42 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    15whtrd likes this.
  6. Dec 12, 2018 at 3:44 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah they can have it towed to the dealer for you. They ground something out to cause the alternator fuse to blow.
    Thattundradude[OP] likes this.
  7. Dec 12, 2018 at 3:56 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^. Or they didn't reconnect something. Get your head under the hood. Under the Rav. Flashlight. And look really really really close at at wires, hoses and connections. Make sure everything is connected. Nothing bobbing around flopping in the breeze.
  8. Dec 12, 2018 at 4:03 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    make them fix...as soon as you start mucking with it they will say you did it...
  9. Dec 13, 2018 at 4:24 AM
    Thattundradude
    Platinum Tundra
    Lifted
    Actually they said the car came like that. The negative terminal has a weird box type of thing on it and it has a cable going to the fuse box, could that terminal box be damaged?
  10. Dec 13, 2018 at 5:05 AM
    15whtrd
    15whtrd Mr. Blonde
    But it was fine when you dropped it off right? Maybe it has something to do with the security. Try another key. I’m assuming it’s a chipped key.
  11. Dec 13, 2018 at 5:30 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    ... and you're sure it's not the battery?
  12. Dec 13, 2018 at 6:01 AM
    Thattundradude
    Platinum Tundra
    Lifted
    Tried jumping the car just cranks and cranks amd cranks. No lights on the dash only thing that turns on is the map lights, clock and ac.
  13. Dec 13, 2018 at 6:09 AM
    ninjajay
    Spoolston, TX
    Sometimes a battery is so dead that no jumpstart will work. The fact that it cranks and accessories work sounds like a pretty good chance of battery degradation to me
    15whtrd likes this.
  14. Dec 13, 2018 at 6:10 AM
    Thattundradude
    Platinum Tundra
    Lifted
    I guess I'll give that a go
  15. Dec 13, 2018 at 6:12 AM
    15whtrd
    15whtrd Mr. Blonde
    I wonder if anyone knows. Do Toyotas put fusible links in the wiring? Maybe hidden in the leads to the battery? I know my uncle‘s Ford Explorer has one hit in the wiring. You cannot replace it without cutting the harness. Stupid
  16. Dec 13, 2018 at 6:12 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    What kind of body work ? And just so I have this right you drove it in the fixed it you drove it out of there and then this issue happened ? Did the do any welding ?
  17. Dec 13, 2018 at 6:15 AM
    15whtrd
    15whtrd Mr. Blonde
    He said the dashboard doesn’t light up other than the map lights. Either a fuse or something fried somehow. The fact that the alternator fuse blew has me concerned. I wonder if they tried to jump it and hooked it up backwards. Could’ve fried the ECM even.
  18. Dec 13, 2018 at 6:21 AM
    MiYota
    MiYota New Member
    evan
    2014 super white tundra
    Negative terminal goes to a ground and positive to the fuse boxe. Is your battery installed correctly?
  19. Dec 13, 2018 at 7:32 AM
    Thattundradude
    Platinum Tundra
    Lifted
    The car was towed there it needed the doors replaced. This picture is off Google but you can see theres a block type of thing on the negative terminal this also had a connection that was running to the fuse box
  20. Dec 13, 2018 at 7:36 AM
    Thattundradude
    Platinum Tundra
    Lifted
    I was going to give the ecu to a company that repairs them to check it out because I have no idea how to
  21. Dec 13, 2018 at 7:47 AM
    Thattundradude
    Platinum Tundra
    Lifted
    Found the part I was talking about. It's No 6 it's called a battery current sensor
  22. Dec 13, 2018 at 7:49 AM
    Thattundradude
    Platinum Tundra
    Lifted
  23. May 2, 2019 at 4:29 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Years ago my wife's escort had a fuel shutoff switch for accidents. I slammed the door hard enough one time to trip the switch. It cut off the fuel pump. Would crank and crank but no fuel or spark.
