dead battery
Discussion in 'New Member Introductions' started by retire 2017, Jan 21, 2017.
  1. Jan 21, 2017 at 9:47 AM
    retire 2017
    retire 2017 [OP] New Member
    2016 Tundra Platinum
    My 2016 Tundra has 3000 miles and sits in a heated garage. When it sits more than a week without starting the battery goes dead. Dealership claims battery is good and can't find problem. This has occurred 6 times in past 3 months. Any recommendations?
  2. Jan 21, 2017 at 9:48 AM
    Did you have the battery tested?
  3. Jan 21, 2017 at 9:50 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Take it to an auto parts store and have them do what Sean said, have them test it. Easy fix, probably a faulty battery.
  4. Jan 21, 2017 at 9:51 AM
    retire 2017
    Yes, by the dealership and they claim ok.
  5. Jan 21, 2017 at 9:55 AM
    take it to a second dealer or autozone
  6. Jan 21, 2017 at 9:59 AM
    retire 2017
    At dealership now trying to trouble shot. If they can't find a solution this time I will take it to Auto Parts as you recommend. I was told that the vehicle has a lot of "bells and whistles" and it needs to be started frequently as there are constant draws. I believe that is BS!!
    NewImprovedRon likes this.
  7. Jan 21, 2017 at 10:00 AM
    Doesn't make any sense
  8. Jan 21, 2017 at 10:06 AM
    retire 2017
    Agree-very frustrating. Pay top money for a Toyota and can't rely on it to start when left for more than a few days!!
    I will see what happens today.
  9. Jan 21, 2017 at 10:36 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No light under hood in 3rd gens neither.
    GNTundra likes this.
  10. Jan 21, 2017 at 11:21 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I had the same problem on my second gen (of course all my electrical mods don't help). Ended up getting a Northstar AGM battery. Seems to have solved it (jinx)
    A few things that are known or reported to draw constant power.
    - Remote start system
    - Factory alarm system / door lock receiver
    - AMP power-steps if you have them.
    - Headlights left in Auto mode (or so the rumor goes)
    - Lead-acid battery self-discharge.
    - Stereo memory
  11. Jan 21, 2017 at 11:52 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I have lots of aftermarket light, amp steps, remote start and other stuff on my truck and I've never had an issue with my stock battery. I think the dealer should give be able to figure the problem out. Keep in mind every new vehicle has lemon law rights as well. I wouldn't let the dealer give you any BS saying that's normal.
  12. Jan 21, 2017 at 12:33 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Mine dies after about 3 weeks. Also planning a Northstar upgrade, hoping for another group buy. I started a thread about this phantom drain problem last year. I wonder how our trucks compare in this regard to the other manufacturers?
  13. Jan 21, 2017 at 12:48 PM
    Mike Tread lightly.
    south carolina
    Tundra sits for one to two more months at time genius battery charger keeps mine in top shape. Uses 110 volt.
    Tacoma uses solar power to keep charged. 100 watt solar panel.
    Both systems work perfect.
