De-Chromed Exterior....Now The Interior
Discussion in 'General Tundra Discussion' started by TundraCoast, Apr 19, 2018.
  1. Apr 19, 2018 at 12:07 PM
    TundraCoast
    TundraCoast [OP] Member In Good Standing
    Ian
    California
    2017 1794 4x4
    On the way to de-chroming the interior. Door handles replaced with the satin-silver. Air-vent bezels are next, they will be textured black same as the vent slats. Satin-silver on the cup holder bezel.
    Anyone have the steering wheel badge vinyl wrapped? If so, post your thoughts, pics. I have seen the shift surround painted from a few other Tundra owners, not sure what route I'll go with that.
    For anyone interested, the swap is really easy. There are step-by-step door panel removal vids on YouTube (takes less than 5-10 min to pull off door panel). Once the door panel is off, there are 2 mechanical wires for the door lock and door handle release, they slide-out of a tongue & groove slot, 2 Phillips screws hold the handle onto the inside of the door panel, with those removed the handle assembly comes right out, swap and repeat the steps to put door panel back on.
    TIP: Have a stand placed at the door height under the door panel (old box or milk crate), once the door panel is free from the truck, you can rest the panel on that stand while you replace the door handle assembly. I found that the stand helped quite a bit.
    Comparison satin-silver vs chrome
    Monochromatic look much better IMO, matches the silver on door trim
  2. Apr 19, 2018 at 1:11 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Is this what you are talking about? It is wrapped.
  3. Apr 19, 2018 at 1:47 PM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    Where did you find the handles? I've got the same set up, and it kills me everytime I see all the mix match
  4. Apr 19, 2018 at 2:18 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    That’s weird mines already got the satin-silver interior door handles, thank goodness!
    Skippy likes this.
  5. Apr 19, 2018 at 2:22 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Where did u get the wrap?
  6. Apr 19, 2018 at 2:25 PM
    seniramsu
    Nate
    VA
    Amazon. It is the 3m 1080 wrap
  7. Apr 19, 2018 at 2:51 PM
    TundraCoast
    Ian
    California
    2017 1794 4x4
    Bought the handles online vendor, they are not OEM but I can't tell the difference from the stock chrome handles I removed. Bought a set of (4).
    If anyone is looking for a set of (4) oem chrome door handles, PM me.
    On the steering wheel, I wanted to de-chrome the Toyota badge, vinyl wrap seems like the best option since the badge is non-removable on the airbag pod.
  8. Apr 19, 2018 at 2:53 PM
    TundraCoast
    Ian
    California
    2017 1794 4x4
    I think on the Platinum & 1794 Toyota adds chrome handles to "make it upscale" they would be doing us a favor if they didn't.
    MaxMB, Pudge and Skippy like this.
  9. Apr 19, 2018 at 2:54 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Ahhhh! Yeah, I’m glad I choose my Limited rather than the platinum I was considering :hattip:
  10. Apr 19, 2018 at 2:54 PM
    TundraCoast
    Ian
    California
    2017 1794 4x4
    Google Tundra interior door handles, there are several vendors that sell handles.
  11. Apr 19, 2018 at 2:55 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Good job. Get rid of all that nasty chrome.
    Skippy likes this.
  12. Oct 11, 2018 at 2:41 AM
    rummy727
    rummy727 New Member
    I'm looking to dechrome around the air vents on my 14 but I can't find any videos on how to remove them. They look fragile! Any tips?
  13. Oct 12, 2018 at 11:11 AM
    TundraCoast
    Ian
    California
    2017 1794 4x4
    Blacked out the cup-holder bezel recently, trim rings around the air vents are next.
    Before
    After
  14. Oct 12, 2018 at 11:17 AM
    2018Tundra
    2018Tundra New Member
    2019 Super White Tundra SR5 CrewMax 5.7L 4x4 TRD OFF ROAD
    Looks much better!! What did you use?
  15. Oct 12, 2018 at 11:54 AM
    TundraCoast
    Ian
    California
    2017 1794 4x4
    Had a body shop paint it, they have done all my color match. They call the black "trim black". I had them prime and put several coast since that bezel is in an area where its subject to drink cups going in and out.
    I would imagine same could be completed with a sand/prep and several coats with a good spray-paint.
  16. Oct 12, 2018 at 1:22 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I replaced my chrome interior door handles with black, almost traded mt buddy for his silver, ended up selling my chrome so it worked out.
    I painted my cup holder trim black, as well as the shifter bezel and they came out great.
    I used some pre cut vinyl for my vent circles and they also came out pretty good.
    The steering wheel chrome badge is held on in a way it isn't easily removed and replaced. Something to do with the air bags I'm sure so I haven't messed with it. I used some rustoleum peel coat with it in place and it did not work well, I think good old fashioned plastidip will be next and I think it'll work just fine.
