DC truck owners: how do you mount your phone?
Discussion in 'Off-Topic Discussion' started by Eclipsed & Floating, Nov 24, 2017.
  1. Nov 24, 2017 at 11:39 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I don't pay more than $20 for a hair cut. I don't understand the money spent on crap that women buy
    Black Wolf and joonbug[QUOTED] like this.
  2. Nov 24, 2017 at 11:46 PM
    TorinWallace
    TorinWallace Yota Addict
    2020 TRD Pro, DoubleCab, Army Green.
    CB Shim + Shackles | 305/70r18 KO2's | 18" Method NV's | Firestone Airbags | Tow Mirrors | Marlon Sleddeck | Spyder smoked taillights.
  3. Nov 25, 2017 at 12:59 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Well that was fast for this thread to go sideways...
    That’s my truck Mark.
    So the mob armor has a thick magnetic plate you double stick tape to wherever you please(preferably a flat clean surface). It’s really strong with the phone holder attached to it. I would do the holder. Unless you want to run a mag-plate behind your case.
    There is another way if you want to do it clean. You can attach a strong earth magnet behind the plastic trim and with the mob armor rubber guard you can still catch a good pull. There was another member on here that did it that way. Forgot who but he had a pretty clean setup.
    If you like to run a mag-plate behind the case you can opt for a cheaper clutchit. It’s fairly strong. Very maneuverable. And qi charger safe-or similar. Just be careful if you use any strong magnets this way. I seen some stories of it tweaking people’s gps and other functions.
    Another great mount to look into is RAM mounts. They got some cool systems. If you have a driver side grab handle I seen folks run a ball screw and phone mount there. Scary but they trust that mount to leave there phone next to the window.
  4. Nov 25, 2017 at 5:38 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    dcsleeper408 likes this.
  5. Nov 25, 2017 at 5:48 AM
    ToyotaTundraMike
    2015 Tundra
    The easiest/cheapest solution is Scosche magnetic mounts.
    www.scosche.com
    I use the surface mount and it has held up over 2 years so far and still holds strong.
    New ones are supposed to be even better.
  6. Nov 25, 2017 at 6:09 AM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    https://www.amazon.com/dp/B0721D4NPP?ref=yo_pop_ma_swf
    Stuck it to the dashboard. Works perfectly. Doesn't move a bit. Perfect placement for using Google Maps on phone too.
    I tried using a vent-mount as I had on my previous vehicle. No good because our vents rotate 360*
  7. Nov 25, 2017 at 8:27 AM
    4x4_Angel
    Bree
    Funky Town, Texas
  8. Nov 25, 2017 at 10:25 AM
    birdman076
    Chuck
    Montana
    Only certain things are nice pink this is not one of them. :yay:
    TRD-tv and 4x4_Angel[QUOTED] like this.
  9. Nov 25, 2017 at 10:32 AM
    4x4_Angel
    Bree
    Funky Town, Texas
  10. Nov 25, 2017 at 10:37 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    I’ve got pro clips in every car. Best mounts I’ve found to date
    BlueBottle[QUOTED] likes this.
  11. Nov 25, 2017 at 10:46 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I have a pro clip for my Garmin on the left side of the radio but I wonder if the same mount would work for the right side too?
  12. Nov 25, 2017 at 10:55 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    You has good taste Brutha...
    HBdirtbag[QUOTED] likes this.
  13. Nov 25, 2017 at 11:03 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
  14. Nov 25, 2017 at 11:08 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Under $20 on Amazon. Be sure to get one with at least a 12" reach. The Texas sun ruins one every couple of years, but they're cheap and easy to replace.
  15. Nov 25, 2017 at 11:17 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Magnetic part for the mount from pro clip. For the phone check Amazon. Search phone case magnet
  16. Nov 25, 2017 at 11:55 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Proclip. I bought everything from proclip.
  17. Nov 25, 2017 at 1:00 PM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Lol, looks like the inside of my hmmv.
    dcsleeper408[QUOTED] likes this.
  18. Nov 25, 2017 at 1:23 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I use these too - what's nice about this solution is if you buy a 2 or 4-pack of bases you can carry one with your travel gear and mount your phone in rental cars. You can also buy a magnetic stand for your desk or night stand.
    I do use the vent to mount mine - you need to turn the vents so that they run horizontally and use the clip on the bottom vent. This prevents the vents from rotating.
  19. Nov 25, 2017 at 2:43 PM
    #49
    Holy crap that's nice.
  20. Nov 25, 2017 at 3:12 PM
    #50
    I have the vent clip magnetic one too. Problem is, is with the heater. That’ll make your phone warm enough to shut down if you’re in winter like we are at times.
  21. Nov 25, 2017 at 3:12 PM
    #51
    I remember USMC haircuts being a buck fifty. My ex would spend $250 + on shoes. Won't mention perfume.... All on my dime. Don't do joint bank accounts.. Just saying. Emphasis on EX.
  22. Nov 25, 2017 at 3:14 PM
    #52
    4x4_Angel
    Bree
    Funky Town, Texas
    Yeah I'm divorced....my ex is like your ex. and he still has me on his account been divorced for almost 2 years
    TundraTss and Black Wolf[QUOTED] like this.
  23. Nov 25, 2017 at 3:17 PM
    #53
    I don't use my phone for anything while driving. It's hard to dial a number with that metal ringy dingy rotory dial.
  24. Nov 25, 2017 at 3:21 PM
    #54
    I used to tell my X that Whale oil is used to make Chanel and most high end perfume.. Shit just rub rotting whale fat under your arm pits...Good to go. Except.... Attracts Polar Bears..unless you're hunting them...hoo..weeeeeee.
  25. Nov 25, 2017 at 3:34 PM
    #55
    4x4_Angel
    Bree
    Funky Town, Texas
  26. Nov 25, 2017 at 3:49 PM
    #56
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    The mount on the bottom in this pic is for my phone.
  27. Nov 25, 2017 at 3:53 PM
    #57
    Problem is half rotted whale fat is quite the delicacy in some northern AK villages... Don't ask how I know. What sucked...hard booze is prohibited in the villages up there. Used shaving cream to get the taste out of my mouth...Who knew???? Apparently rotteded whale blubber is popular in Iceland too.. Never been there... Seems to beget hot blondes with great complexions there........Back on topic....I don't cell phone and drive. Love hate relationship with cell phones.
    4x4_Angel[QUOTED] likes this.
  28. Nov 25, 2017 at 4:51 PM
    #58
    Backslider
    Tooele, UT
    It's true, in the summer it's great though with the A.C. on your phone at all times.
    T-Rex266[QUOTED] likes this.
  29. Nov 25, 2017 at 4:56 PM
    #59
    Lol that’s what I told myself. I do enjoy how it’s stealthy and blends in too :thumbsup:
  30. Nov 25, 2017 at 8:37 PM
    #60
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
