DC Fold Down Rear Seats
Discussion in '2nd Gen Tundras (2007-2013)' started by JMB, Aug 4, 2014.
Which do you prefer?
  1. Cut
    37 vote(s)
    48.7%
  2. Bend
    32 vote(s)
    42.1%
  3. Tastes Great
    16 vote(s)
    21.1%
  4. Less Filling
    9 vote(s)
    11.8%
Multiple votes are allowed.
  1. Mar 15, 2019 at 9:02 AM
    #91
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    I used a regular household hammer in the 1st picture. Yes, they easily bend down, I just hit each one 3x to the correct bend.
    I loosenly bolted the smaller back seat (right side) to make sure that I have the right bend and made adjustments. Once I got the right bend, I used those hoops as a reference to bend down the hoops of the larger seat.
    I hope this helps. Let me know if you have any other question.
  2. Mar 15, 2019 at 1:37 PM
    #92
    BigDaddy74
    BigDaddy74 New Member
    Barry
    Kaufman, Texas
    2012 Spruce Green Tundra 4.6L Double Cab/Lifted, Pavement "Princess"...But she's pretty!!
    20" Rims...33" Tires...Nerf bars...Pro Comp Nitro 3 Inch Leveling/Lift Kit...still working
    Awesome, thanx for the tips...I plan on attempting this weekend or next...I will post how it goes
    Mountun Goat and 15whtrd like this.
  3. Mar 15, 2019 at 1:38 PM
    #93
    15whtrd
    15whtrd Mr. Blonde
    Had I even thought about the hammer trick that’s the way I probably would’ve gone. I ended up cutting mine and it works fine too.
    Mountun Goat and Taco-Blender like this.
  4. Mar 29, 2019 at 1:03 PM
    #94
    motocrossman99
    motocrossman99 New Member
    Josh
    2019 Barcelona Tundra SR5
    does cutting the brackets introduce any safety concerns or does it still have enough to catch/hold when in the upright position if you were to get into an accident or anything?
    Mountun Goat likes this.
  5. Mar 29, 2019 at 1:07 PM
    #95
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    I was concerned about that a little but the seat belts are not attached to the seat rather the back panel so I can't see why it would. I ended up just hammering the hooks down a little bit instead of cutting, I cannot get the seat to move forward one bit and I gave it a pretty good couple pulls.
  6. Mar 29, 2019 at 1:08 PM
    #96
    motocrossman99
    Josh
    ok i will probably do this mod then i was just concerned as my 7 yr old daughter and 1 yr old son will be back there.
  7. Mar 29, 2019 at 1:08 PM
    #97
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    If you just cut off about an inch (all that's needed), it doesn't budge when it's engaged in the hook, and you still have to lift up the seat bottom in order for the back seat to rise about two or three inches or so to disconnect from the hooks.
    So, yes, there's plenty to still catch & hold onto the hook.
  8. Mar 29, 2019 at 2:12 PM
    #98
    JMB
    JMB [OP] Not new, just a little old.
    Chesapeake, VA
    2013 Super White Tundra DC
    No. The part that you cut off has essentially zero stress when the bracket is loaded. If you're very concerned, I would avoid bending the clips. They have exceeded yield strength and are therefore comprised for further loading. Probably not significantly, but still, since you asked.
  9. Aug 14, 2019 at 4:15 PM
    #99
    Yoda the Tundra
    Yoda the Tundra New Member
    JC
    Western Montana
    2015 Blue Tundra TSS
    LED Fog Lights Trailer brake Controller - more info will be added later Rear Air bags - "Load Lifter 5000 ULTIMATE" Air Springs w/ Jounce [REAR] Air Lift WirelessAir Compressor - 2nd Generation w/ EZ-MOUNT & Cell Phone APP (Control Two Springs Independently) Weathertech Floor mats - a must Black nameplate Grille Assembly installation time maybe 15 minutes Towing Mirrors installation time 30minutes Steel wheels :) for a winter set of tires. LED interior cab lights Removed rusting chrome tube running boards and replaced them with black full length running boards
    Why did you end up trimming your factory ones? Also is there a way to contact the guy selling these?
  10. Aug 14, 2019 at 5:01 PM
    #100
    15whtrd
    15whtrd Mr. Blonde
    The factory ones are rubber tipped so I figured it might help with rattling. Nothing wrong with the other ones.
  11. Aug 18, 2019 at 1:26 PM
    #101
    james33440
    james33440 New Member
    James
    2010 Tundra Double Cab
    Magnaflow Exhaust
    I did this but just used a hammer to bend the hooks. Worked like a charm.
    Also, I was surprised as to how much room was back there. I may decide to move the seat forward a few instead of raising it and out subs behind the seat.
    RideorDie and Pbear1454 like this.
  12. Sep 14, 2019 at 11:11 AM
    #102
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    Thanks to all for the inspiration and tips.
    Thought it would be cumbersome but to my surprise to was straightforward with the hammer approach
  13. Sep 14, 2019 at 12:27 PM
    #103
    Rubberdown
    I don’t know why anyone does it differently. It’s so much easier.
    Pbear1454 likes this.
  14. Sep 14, 2019 at 1:46 PM
    #104
    james33440
    James
    Magnaflow Exhaust
    Yes. Very convenient
  15. Sep 17, 2019 at 3:27 AM
    #105
    melcoeb
    melcoeb New Member
    for those who used the hammer approach, how much approximately did you bend it down? an inch?
  16. Sep 17, 2019 at 3:52 AM
    #106
    james33440
    James
    Magnaflow Exhaust
    I think I did about that. Just do a little and trial and error. If you do it too much I’d assume you wouldn’t be able to lock it over the hooks.
    I can post a pic when I get off work in a few hours to give you an idea.
  17. Sep 17, 2019 at 7:29 AM
    #107
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    Just pound on it until it's almost 45 degrees down I would say
  18. Sep 23, 2019 at 5:30 PM
    #108
    2011Tundra_RW
    2011Tundra_RW New Member
    people are talking about having extra brackets but Toyota doesn't sell then individually that i can find. so dose anyone know where you can get a set of them?
  19. Sep 23, 2019 at 6:20 PM
    #109
    You can get some off a wrecked DC. Check Craigslist or a junk yard.
  20. Sep 30, 2019 at 11:34 AM
    #110
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    @Rubberdown You’re a genius. Did this on the new truck yesterday. Bending the loops was waaay easier than when I cut the hooks on the first truck. Thanks bud. And btw, your ADS shocks are in Texas now. :thumbsup:
    Trooper2 likes this.
  21. Sep 30, 2019 at 11:55 AM
    #111
    Rubberdown
    Oooooooooo man. I’m all tingly waiting on them.
    Also thanks for recognizing my genius. I tell everyone I’m a genius but no one believes me. Probably has something to do with them watching me.
    Trooper2, Gabrielo93 and joonbug like this.
  22. Oct 16, 2019 at 7:58 AM
    #112
    JCtheOtherOne
    JCtheOtherOne New Member
    Jack
    Outside of Philly
    2011 White Tundra TRD- Philly
    All just wanted to share my experience. I did have to pop off the seats with the socket set, of course i used my impact gun for it. There are 6 screws. Once out, i lifted up, pulled forward and the back rest folded down. I then put the screws that held dow the seat back in. I measured 1” and cut off the latch on a angle. I used a sawzall for this so i didn’t have to remove the metal latch (I’m lazy). Then while here i can just test it also in case i need to shave it down some. It’s rough but it works. I might take a metal file to it to kill the rough surface. Boom done in about 20mins.
    Mountun Goat and Trooper2 like this.
  23. Oct 16, 2019 at 8:10 AM
    #113
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Ha! After bending the hooks, I realized it tilted the seats too much and the headrest was hitting the back window and interfering with the sliding window. So I bent the loops back up and cut off the hooks on the passenger side.
  24. Oct 16, 2019 at 8:24 AM
    #114
    Rubberdown
    ohhhh... I am ghetto. Never had the sliding window.
    Mountun Goat and Gabrielo93 like this.
  25. Oct 16, 2019 at 8:31 AM
    #115
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Same kinda, just used the Vibrasaw with hooks in place, went through like butter.
  26. Feb 6, 2020 at 2:37 PM
    #116
    tglyder
    tglyder Wise & Heimer
    NW Oregon
    Silver 2010
    Oh, I know what's cookin there... Exactly what I was thinking to store back there, flat tools. One 12 gauge and one 30/30.
    Where did you find those hooks, I'd like to get some.
  27. Feb 23, 2020 at 1:35 PM
    #117
    ldhn1uec
    ldhn1uec New Member
    Lou
    19 Tundra DC limited
    Great mod. Has anyone covered the seatbacks like the tacoma?
  28. Mar 2, 2020 at 8:48 PM
    #118
    2020TNtundra
    2020TNtundra New Member
    So we just need now some type of hard plastic to cover the back seat to make a storage area like I had on my F250, to set stuff on without messing up the rear seat cushions.
    TomC843 likes this.
  29. Apr 18, 2020 at 3:07 PM
    #119
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Yea a little late to the PARTY but finally did this mod on my 18’ SR DC today
    Harder to get the seat up and off of brackets then I thought and pain in the ass to get screws out hooks on seat back (did not want to cut in place and having shavings everywhere)- impact gun with swivel is key !
    Used air-die- grinder to cut & shape hooks
    Reinstalled everything and HAPPY to say all works as described!!
    But now that I have done it and I see what little room is back there I have no idea what the hell I'm going to put back there
    From some of the photos I’ve seen looks like 2ndgen might have more room the 3rd :notsure:
    On a positive note -might now be able to do sound proofing without removing whole seat now?
    THX @JMB for write up !!
    TomC843, Mountun Goat and JMB[OP] like this.
  30. Apr 19, 2020 at 4:20 PM
    #120
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Attaching the swivel to an extension then to a drill made it easier.
