Dc camper same size as ac?
Discussion in '1st Gen Tundras (2000-2006)' started by IEsurfer, Sep 8, 2020.
  1. Sep 8, 2020 at 3:03 AM
    IEsurfer
    IEsurfer [OP] New Member
    jimbo
    Socal
    2005 tundra 4x4
    pardon my ignorance but if they state the access cab camper is 6.5 feet would it fit the double cab as well?
  2. Sep 8, 2020 at 4:31 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The AC truck beds are slightly longer, less than an inch if I remember right but the DC bed sides are about 3 inches higher if that makes a difference.
    FrenchToasty likes this.
  3. Sep 8, 2020 at 5:49 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My camper shell was made for a double cab but fits my A/C. Mostly. It's slightly wider and there is a gap in the front so it leaks a little. I've been able to make it work. If you don't want a single drop of water in, I would avoid it. I used a piece of pipe insulation to fill the gap in the front.
    I circled the areas where the gap is. None of these are visible from the outside. My shell is an ARE V Series.
    IEsurfer[QUOTED][OP] likes this.
