dash warning lights
Discussion in '2nd Gen Tundras (2007-2013)' started by jmh103181, Feb 21, 2015.
  1. Feb 21, 2015 at 5:46 PM
    jmh103181
    jmh103181 [OP] New Member
    jason
    2010 tundra rock warrior
    nfab pre runner bumper
    has anyone had or heard of this i got in my truck today turned it on the check engine light traction control light and my 4lo light all came on and the 4lo was flashing the entire time. truck wasn't even in four wheel drive
  2. Feb 21, 2015 at 8:06 PM
    Sounds like the recall..call Ur dealership (or any Toyota one) and provide them with the vin
    My last Tundra (2012) had the same...only at 3am, negative temps, and snowing..
  3. Feb 22, 2015 at 3:30 AM
    jmh103181
    jason
    ok thanks appointment scheduled for monday. it was snowing at the time and had been negative temps the majority of the week prior.
    T-Rex266 likes this.
  4. Mar 7, 2015 at 9:15 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Update?
  5. Apr 13, 2016 at 10:48 AM
    shadrja
    shadrja New Member
    07 Tundra 4x4
    Had this happen. Cause was low level in coolant fluid (will also cause heater to not blow hot). Cleared codes using Oreilly code machine (temporary fix). Ultimately water pump is leaking. Needs 100k service anyway.
  6. Sep 2, 2018 at 9:09 AM
    mcfarlandmike
    mcfarlandmike New Member
    I just purchased a 2007 Tundra yesterday drove great from dealership got up this morning and all the dash warning lights came on and stayed on the traction light stayed on check engine light also and 4 Lo light is flashing and it will not go above 50 mph so it is parked till I can figure this out. Any Ideas
  7. Sep 2, 2018 at 9:38 AM
    mcfarlandmike
    I don't have one I am going over to a buddies He has one I'll get back to you
    NewImprovedRon likes this.
