Dash Switches - 2nd and 3rd Gen Tundra
Discussion in 'Lighting' started by csuviper, Jan 30, 2014.
  1. Oct 19, 2016 at 7:43 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Still look good and clean.
  2. Oct 26, 2016 at 2:17 PM
    jay131866
    jay131866 New Member
    How did these turn out? Easy install? Any problems with it since you put them in?
  3. Oct 26, 2016 at 3:35 PM
    jay131866
    Cool I just ordered one to hook up my fog lights. They should fit the 2016 model correct? All the reviews on Amazon were for the 2011 year but I'm assuming the switch size didnt change after 2014?
  4. Oct 26, 2016 at 3:44 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    FYI: cruiserheads.com offers a custom etching service. They will create a switch for you using the image, label and led color of your choice. I had them make me a "Kneel" switch for my airbags and it came out great. They charged about $30. Just ordered another one from them to drop the tailgate.
    GNTundra likes this.
  5. Oct 26, 2016 at 5:02 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Ask @Roman if he sells that panel.
    Roman likes this.
  6. Oct 26, 2016 at 6:27 PM
    jay131866
    Cool that looks like the same exact layout as mine and ill prob put it in the same spot as you did. I also have 2 blanks to the right of my steering wheel but makes more sense where you have it. Thanks for posting the pic!
    NewImprovedRon likes this.
  7. Dec 28, 2016 at 8:14 PM
    LibertySand
    LibertySand IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    Great thread. Also saw that SDHQ sells switches for us too. Seeing this thread changed my mind from a custom switch cluster face for the ash tray to the stock locations.
  8. Feb 20, 2019 at 8:46 PM
    cannonfodder___23rd
    cannonfodder___23rd New Member
    2012 White DC Rock Warrior
    Where does one find info on this or any other MOD similar to this (5 button cover)?? I do not know the name of item but have been looking, I promise!
    goffredo likes this.
  9. Mar 14, 2019 at 7:52 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Here's where I put mine. Took some doing but I'm happy overall.
    WillTunBlack20 likes this.
  10. May 2, 2019 at 5:33 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Are you guys taking apart the dash to install the switches? Or just cutting out th blanks and reaching under the dash to run the wires?
  11. May 3, 2019 at 6:06 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    To get the blanks out, it is pretty easy to pop out the dash panel piece and squeeze the tabs on the blank from behind. I guess to answer your question, I removed the dash panel pieces. The one under the steering wheel has two bolts and several push tabs that release after removing the bolts. All of the pieces in the console area just pull out.
    xtyfighterx[QUOTED] likes this.
  12. May 3, 2019 at 6:22 AM
    xtyfighterx
    Ty
    North Idaho
    Thanks so those blanks push out they aren’t cut out?
  13. May 3, 2019 at 7:07 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Some of them have tabs on the sides, some have the tabs on the top and bottom. If you take a small thin flat head screw driver, you could pop them out. It's so easy to remove the dash panel/ trim part to gain access to the back and jsut pop them out that doing it that way is really THE way to go about it.
    In post #42 above, see the empty hole to the left of the USB/ AUX switch? That was a switch blank before I removed the blank. THe Toyota style switches just pop in from the front and use tabs to lock into place. From the rear, releasing the tabs will let the switch jsut push out to the front. Same for the switch blanks.
    Same picture in #42, the three switch pod- I did have to cut out a hole for the pod to mount into, there was no switch blank there.
    Post #36 above, the blank to the right of the LED switch- I believe that is a Toyota OEM blank too. Pulling the dash panel off should let you jsut release the tabs and pop out the blank.
    Honestly, take 10 minutes and a 10mm socket and remove the panel below the steering wheel and it should become self explanatory.
  14. May 3, 2019 at 7:43 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    So easy even Arkansans can do it.......
  15. May 3, 2019 at 8:14 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Before I posted my last reply, I made sure to list my location....
  16. May 3, 2019 at 3:30 PM
    xtyfighterx
    Ty
    North Idaho
    I have a generic light bar harness that car with a switch I gotta figure out how to wire in a new switch that will fit the blanks.
    This is the switch I have it has three wires going to it.
  17. Dec 11, 2019 at 11:34 AM
    FredB32
    FredB32 New Member
    2011 TRD RW
    So, how are these holding up after a few years? I need to wire in my front cam and possibly LED DRLs...looks like the pricing is about the same between that site and Amazon currently.
    Also, search function FTW :D
  18. Dec 11, 2019 at 12:28 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Still look like new!
  19. Dec 12, 2019 at 7:44 AM
    #49
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Mine too. I had them on the last three Tundras. Once I got he wiring figured out, never had a single issue with any of the 15 or so I've purchased.
    FredB32[QUOTED] likes this.
  20. Dec 17, 2019 at 2:50 PM
    #50
    Rengawt
    Rengawt New Member
    Tanner
    2010 Tundra Crewmax 4x4 Platinum
    Has anyone found a switch that is a good match to the oem switches led color on a 2nd Gen? Just looking online the closest I have seen would maybe be a red switch from CH4x4. I'd prefer to have them match as close to the oem switches as possible for a clean look.
  21. Dec 17, 2019 at 3:55 PM
    #51
    FredB32
    FredB32 New Member
    2011 TRD RW
    Wouldn't the amber ones work?
  22. Dec 29, 2019 at 10:02 AM
    #52
    NVTundra
    NVTundra New Member
    Northern NV
    2024 Blue Print SR5
    Wheels and tires. For now...
    I just recently stumbled across these guys and just ordered the hood mount ditch light brackets for mine. They carry limited stuff for tundras but more for the 3rd gens. I’m gonna order this switch here in a few and once I get more accessories ect, I’ll probably order the switches through these guys. I’m trying to find light and mounting options that aren’t going to break the bank.
  23. Jan 17, 2021 at 10:56 AM
    #53
    Black_Panda
    Black_Panda New Member
    07 black tundra limited
    I know this is an old thread but was curious, could I run two sets of light pods from one switch? I just put an nfab bumper on my truck and I have a light bar and two pairs of light pods to go on either side of the light bar. Ideally I'd like to put in the switches, but don't have three blanks next to each other. I've clicked on other links for Amazon switches but it just takes me to Amazon search, not a specific switch, I hope this one isn't the same. I know it's "tall" but if it'll work, I'll make it fit.
    https://www.amazon.com/dp/B08B5VMW66/ref=cm_sw_r_cp_awdb_imm_t1_EBhbGbTZJSKJQ
  24. Jan 17, 2021 at 10:59 AM
    #54
    Yes it will work.
    Welcome from NY.
  25. Jan 18, 2021 at 8:19 AM
    #55
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    Yes you can run multiple lights off one switch, just be sure to wire the lights to a relay and then the relay to the switch.
