Dash side panel
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hoff, Jul 11, 2020.
  1. Jul 11, 2020 at 3:36 PM
    Hoff
    Hoff [OP] New Member
    2021 TRD OFF ROAD CREWMAX
    I need advice on how to remove this dash side panel. I’m almost certain it just snaps in place. I’d hate to break it. 7F6A34A6-0B0F-4C65-A742-860ADB826B05.jpg
  2. Jul 11, 2020 at 4:05 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Just snaps on. Use plastic trim removal tool
    Hoff[OP] likes this.
  3. Jul 11, 2020 at 4:08 PM
    AZTundra
    Paul
    Phoenix, AZ
    You can use your hands to pop it off. Really easy job. You can also pull the molding to get a better grasp of it if needed. The molding just pulls off and presses back on too if that helps you.
  4. Jul 11, 2020 at 4:21 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Remove the kick panel then just pull that exposed piece from the bottom. It’s just clipped in.
  5. Jul 12, 2020 at 2:21 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    I believe on my truck this is where the factory remote start is mounted. That's what the other persons/pics bolts should be. Mines a 2014 1794.
    Hoff[QUOTED][OP] likes this.
  6. Jul 12, 2020 at 2:26 PM
    Seafury
    Agent K
    SC Low Country
    Also the proper way to remove the side panels, is to gently pry the front edge that faces the rear of the vehicle, then once that pops out, pull slightly rearward. The front of the truck edge of the panel has tabs that slide into the dash. Super simple.
    BTW this panel really gives you access to nothing, except the above mentioned factory remote start module mounted on the passenger side. Might be dash bolts in there or something, but that's probably for major dash removal anyway.
