Dash replacement speakers - Infinity REF-3032's fit?
Discussion in 'Audio & Video' started by RB1, Dec 1, 2018.
  1. Dec 1, 2018 at 7:40 PM
    RB1
    RB1 [OP] New Member
    2018 Tundra Sport DoubleCab 5.7
    Anyone replaced the speakers in the R & L dash?
    I have 2018 Tundra DC, non-JBL ... already have replaced F doors with Infinity REF-6530cx, R doors with REF-5030cx + Rock Fos sub ... I also do have the OEM dash speakers wired with the doors ... the whole thing sounds great but I'd think the weak point would be the OEM dash speakers. I was considering these ...
    https://www.infinityspeakers.com/speakers/REFERENCE+3032CFX.html
    Whatcha think?
  2. Feb 15, 2019 at 8:01 PM
    taymcmillen
    taymcmillen New Member
    Did you end up swapping out the dash speakers? I was looking at the same Infinity's. If my research is correct (for my 2008 JBL) the dash are 2ohm and these are 3ohm so might be less volume overall. I'm also slightly worried on the fit but figured I could squeeze them in.
  3. Feb 15, 2019 at 8:56 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I just installed these as part of the tech12volts dash speaker group buy. They wire up easily, sound great but are definitely a bit quieter. The sound is much more clear and crisp though. One if the factory bolts fits but you need to use a self tapping screw into the plastic for the second mounting screw, very simple and I did it with a stubby screwdriver because its tight working near the windshield
  4. Feb 16, 2019 at 6:33 AM
    taymcmillen
    Thanks for the info. Looks like you just cut the speaker off the harness and wired it up that way. I was thinking about doing that also, didn't know if I had to use the capacitors that came with it. Just ordered mine
  5. Feb 16, 2019 at 7:43 AM
    Pudge
    CT
    Some say they have a pop noise when starting the truck with the capacitors on. I didn't install the caps but I will when I have time, I didnt even realize they were un the box lol. And yes just cut the wire off the old speaker and wire them to that, the green wire is + and black is -
