Dash rattle
Discussion in '1st Gen Tundras (2000-2006)' started by kidked888, Feb 6, 2021.
  1. Feb 6, 2021 at 5:16 PM
    kidked888
    kidked888 [OP] New Member
    Kansas
    2004 Tundra Double Cab 2WD
    Only comes intermittently when driving. Sounds like it’s either coming from the glove box or just underneath. Hard to tell exactly where. Banging on the dash hasn’t helped any. Sounds like something is loose but only makes the rattling noise on an on consistent basis. Anyone else had this problem and fixed it?
    2004 DC 2WD
  2. Feb 6, 2021 at 5:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    A lot of us put backer rod between the dash, and the windshield for tension.
    Link
    You may need to play with the sizes of the backer rod/closed cell foam. I know when I had my OEM windshield I used ½. I had my windshield replaced and used ⅜.
    There are a lot of weird noises that come from the dash. I think if I had a do-over I'd try something like this.
    Link.
  3. Feb 6, 2021 at 5:25 PM
    Professional Hand Model
    Hand Protectors
    Remove your Glove Box and start feeling around jiggling stuff in there.
  4. Feb 6, 2021 at 5:25 PM
    kidked888
    Kansas
    Exactly what I am thinking I’m gonna have to do, trying to find instructions to remove glovebox now.
  5. Feb 6, 2021 at 5:28 PM
    Hand Protectors
    Remove two bottom screws. Drop Box gentle down and squeeze the sides to wedge out. Bottom bracket has two nubs that lock in place so watch those for tricks. Do not over tighten screws when putting back or you’ll strip plastique.
    kidked888[QUOTED][OP] likes this.
  6. Feb 7, 2021 at 7:47 AM
    The change in my ashtray rattles sometimes, I just give it a jiggle and it settles down. That's probably not helpful.
    FirstGenVol, Jack McCarthy and abcinv like this.
  7. Feb 7, 2021 at 12:39 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Make sure it's not an ice scraper in the door pocket rattling at seemingly random times. DAMHIK. :)
  8. Feb 7, 2021 at 12:56 PM
    kidked888
    Kansas
    That was the rattling noise from last week, but got that one already fixed!
  9. Feb 7, 2021 at 1:31 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Actually if you don’t push the ashtray completely in it will rattle around and make you think it’s a dash rattle. Even if it’s out 1/4” it can do that on mine but my shocks are completely gone so maybe that just exacerbates it now that I think about it.
  10. Feb 7, 2021 at 1:35 PM
    Anohibian
    Anohibian New Member
    Anchorage, AK
    2018 Inferno Crewmax
    Had this on my wife’s 06. I finally ran it down removing the head unit and found a loose screw that attached the dash itself. Wish I had photos to show you. Took me two months to track down.
  11. Feb 7, 2021 at 4:25 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    My passenger airbags has rattled like crazy since the recall service.
    jerryallday and abcinv like this.
  12. Feb 7, 2021 at 4:41 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    I had a dash rattle off and on for years. The backer rod fix mentioned above worked well but only for a while. It would eventually come back when the rod compressed. Mine was always worse when weather was cold. I narrowed the location down while having passenger push down on different spots on the dash while it was doing it. It was center of dash slightly towards passenger side. I took out the stereo (pretty easy to do) and added sticky foam tape to a few spots back up in the area we pin pointed. Used the thick stuff home depot sells for doors and windows. Hasn't made a sound since.
    Usually pretty easy to fix a rattle, just have to find it first...
    Bmktw2 likes this.
  13. Feb 7, 2021 at 10:38 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Mine did that too after I got it back from the stealership. I just banged on the passenger side dash and it went away.
  14. Oct 12, 2024 at 1:43 PM
    Sherbethead
    Sherbethead New Member
    03 Access Cab Limited V8 4X4
    I have pretty dash rattle in about the same area you mentioned. How thick of foam tape did you use? Did you apply it directly on the dash facing downwards around where they clip in? When I push down on the dash the rattling stops so I’m wondering how to be combat this.
  15. Oct 12, 2024 at 2:15 PM
    shifty` We call it “riding the gravy train”
    Use the 3/8 backer rod @Tundra2 linked above. It’s what most other people have used with good success.
    G_unit3000 likes this.
  16. Oct 12, 2024 at 4:15 PM
    Sherbethead
    I’m going to try that, thanks a bunch
  17. Oct 12, 2024 at 4:39 PM
    Jack McCarthy
    Bill
    North of Boston
    It’s either the backer rod or rip apart the dash and grease those pink phallic things up against the firewall like someone did here.
    I wouldn’t recommend taking apart the dash unless you feel confident you can put it back together correctly.
  18. Oct 12, 2024 at 8:05 PM
    Sherbethead
    Gonna try the foam backer rod first. I think if it’s tight enough it should fix it. Yeah I wasn’t trying to remove the whole dash if I don’t have to. Always a chance I might break some clips etc or make it worse than before.
  19. Oct 13, 2024 at 7:46 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    My dash rattle is back, it always comes back... Especially in the fall with return of cold weather. Current temporary fix is stuffing a pen cap down between the dash and the window. It'll work until I get around to new backer rod and maybe another go at from behind the stereo.
  20. Oct 22, 2024 at 10:56 AM
    Sherbethead
    I ended up trying a 1/2” backer rod and it didn’t help much. I was installing a new stereo so had the head unit out and noticed there was an obvious small gap and play between where the dash sits down (right underneath where you’d stuff a backer rod). I stuffed some 1/4” foam tape between the gaps and I think it’s helping.
    shifty` likes this.
