Dash phone mounts, which do you like best?
Discussion in '3rd Gen Tundras (2022+)' started by BLCKBIRD, Nov 23, 2023.
  1. Apr 5, 2024 at 5:29 PM
    #61
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    lol ha ha . I just meant I got some bulletpoint stuff wireless charger, some mounts, got the Amazon dash piece, the mount you posted above, the esr wireless and power grip one.. I’m going to just try out all sorts of stuff to see what I like.
  2. Apr 6, 2024 at 1:10 AM
    #62
    wing-2
    wing-2 New Member
    I went with Bulletpoint. I am happy with it apart from the fact that the ball size is different from RAM. I installed a RAM ball on the mesh plate in case I want to add something else later.
  3. Apr 7, 2024 at 8:27 PM
    #63
    LunarNick
    LunarNick New Member
    Nick
    2024 Limited Tundra
    Just ordered this supports ram mounts
    cartage1 likes this.
  4. Jul 3, 2024 at 4:34 PM
    #64
    bigdomer
    bigdomer New Member
    Anyone in this thread able to help me identify the correct Bulletpoint arm length for a 24 Tundra with the large screen? I understand that the one that ships with the kit is the 10cm arm. That seems too short. Are you guys running the 13cm or 20cm arms? Thanks.
  5. Jul 31, 2024 at 3:47 AM
    #65
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Has anyone installed a Proclip mount on the passenger side of the dash for the Passenger?
  6. Nov 2, 2024 at 4:30 PM
    #66
    RadixRyder
    RadixRyder New Member
    Anon
    2023 Tundra TRD Pro
    Just ordered this same thing. Looks like a solid build.
  7. Nov 3, 2024 at 6:40 AM
    #67
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
  8. Nov 8, 2024 at 2:09 AM
    #68
    Bergy24
    Bergy24 New Member
    20% off Pro Clip Right Now
  9. Nov 8, 2024 at 6:17 AM
    #69
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Bullet is my go to. I like how I can quickly remove it. Only use it for my TT back up cam and levelmatepro.
  10. Nov 8, 2024 at 7:32 AM
    #70
    Esoto787
    Esoto787 New Member
    Just installed a Bulletpoint on mine with wireless charging cradle. Works great. Good design. Quality product.
  11. Nov 8, 2024 at 7:55 AM
    #71
    BlackNBlu
    BlackNBlu Cranks Nickelback in Target order pickup lane
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Another user of the AMZ knock-off (Same design as Bulletpoint and ICS Fab) here: https://www.amazon.com/dp/B0C5RJFZZQ#customerReviews
    Same setup as @Texas Two Step back on post#28. Dual ESR magsafe style chargers so wifey has her own on a road trip.
    A couple 90 degree USB-C adapters cleaned up cord routing quite a bit.
    Cords goes straight back parallel to the arm instead of down first.
    Very happy with it. Solid.
  12. Nov 9, 2024 at 4:03 PM
    #72
    RadixRyder
    Anon
    2023 Tundra TRD Pro
    Just installed the BulletPoint mount with MagSafe plate and it is pro level quality. Highly recommend.
    TundraDan723 likes this.
  13. Nov 9, 2024 at 4:35 PM
    #73
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Is there a mount where the mag safe wire goes through the arm
