Dash light for climate fan?
Discussion in '1st Gen Tundras (2000-2006)' started by markshoreline, Dec 1, 2018.
  1. Dec 1, 2018 at 4:39 PM
    markshoreline
    markshoreline [OP] New Member
    Mark
    Whidbey Island, WA
    2006 Tundra TRD 75k miles
    Front trailer hitch, tonneau cover
    Anyone know how to replace the bulb for the climate fan?
  2. Dec 1, 2018 at 4:41 PM
    Professional Hand Model
    Hand Protectors
    Just did all of mine today on the control panel. Check pics over on What Did You do Today. Posting soon.
  3. Dec 1, 2018 at 5:13 PM
    Casper421
    In the woods
    06 DC
  4. Dec 1, 2018 at 5:27 PM
    Hand Protectors
    3 screws behing control knobs and two up behind vents. Takes 2 minutes to remove.
    Black Wolf likes this.
  5. Dec 1, 2018 at 5:33 PM
    Hand Protectors
    The larger bulb (avail at auto store) is 194. I did not reinstall the green rubber. The smaller bulb (not spec’d on manual) is T5 ordered online (auto stores do not carry these in LED). They can be used at the step light and glove box locations as well. I’ll have a few extra and do some lights behind the instument cluster, as the will work there too.
  6. Dec 1, 2018 at 5:40 PM
    Hand Protectors
    Those bulbs will come out of those twist lock bases. You’ll reuse those bases. 1/4 turn with needle nose pliers and pull out base from backside of panel. Then with your fingers remove the bulb from twist base. I can see my panel gauges again.
  7. Dec 1, 2018 at 5:46 PM
    Hand Protectors
    I did all my bulbs at one time. They still worked, but had black burns on the glass which diminished the brightness significantly. Went ahead and did all and do not regret it. Those green rubbers were faded too which did not help the brighness.
    Filthyphil likes this.
  8. Dec 20, 2019 at 10:38 AM
    2005ToyotaTundra
    2005ToyotaTundra New Member
    Anyone know where to order the green caps for the bulbs Or what an acceptable replacement item would be?
    Thanks in advance
    PS
    If I go with LED Bulbs, does the dimming function still work correctly?
    Whothefat likes this.
