Dash creak/squeak/rattle
Discussion in '2.5 Gen Tundras (2014-2021)' started by MikeyMTBs, Dec 1, 2017.
  1. Jan 4, 2021 at 9:16 AM
    #211
    Camprunner
    Camprunner New Member
    2018 trd sport
    None
    Winnipeg, man so cold there was does not creak? Lol!
  2. Jan 4, 2021 at 9:30 AM
    #212
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    That explains why it gets cold enough for you to notice the dash squeak. Also our terrible roads.
    My advice? Don't worry about it. Apparently all the Tundras do it. It goes away in the spring when it warms up.
    And yes, I agree with you when you say you won't get back what you paid for it, especially within a year of buying it. Depreciation DOES still hit these trucks, especially from new, despite what people around here say,. That depreciation diminishes over time, though, relative to other brands.
  3. Jan 4, 2021 at 9:34 AM
    #213
    PinnacleX
    PinnacleX New Member
    Bart
    2020 TRD Off Road
    That conversation is insignificant im just trying to figure out my rattles mostly the one where the center speaker is
  4. Jan 4, 2021 at 9:36 AM
    #214
    Camprunner
    2018 trd sport
    None
    That is correct. I just gambled and tried it. No issues with that squeaking and chirping since then.
  5. Jan 4, 2021 at 9:38 AM
    #215
    GreatBigAbyss
    Well, if you figure it out, please let me know. If it's an easy enough fix, I'll give it a go.
    FYI, what was tried at my dealer was to replace the wiper cowl (that plastic bit between the hood and the windshield), and also removing and resealing the windshield. None of that helped.
    If it turns out to be a wire under the central speaker grille rubbing, well, that should be easy enough to fix, I guess.
  6. Dec 6, 2021 at 12:08 PM
    #216
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Holy shit. This fixed my issue. I have been going insane ripping apart everything
  7. Sep 6, 2022 at 2:40 PM
    #217
    PasteyC
    PasteyC New Member
    I discovered a rattle under my passenger side dash this weekend. Just tore the dash apart and found a loose bolt just behind the glove box. Problem solved.
    mav7021234 likes this.
  8. Dec 8, 2023 at 9:30 AM
    #218
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    My clicking sound is in a Sequoia but I think the Seq is exactly the same as a Tundra to the B pillar. So, 2019 Seq SR5 my daughter bought last week, 67k miles. We isolated the click on the test drive to the plastic area below the touchscreen stack and AC control, around the USB port,. I pressed my thumb and finger on either side of the USB multiple times, with pressure the click went away, released pressure the click was back.
    Used car dealer mechanic drove it, confirmed the click, confirmed the USB area was the source. OK, so service guy told me just now he ordered a trim part that covers the USB port (didn't have the PN for it), said Toy dealer told him the part is on national backorder. My initial thought was I'd shove a wood toothpick tip (or two) in to tighten it up rather than waiting and let a non-Toyota guy possibly cause more damage hamhanding it. Thoughts?
  9. Dec 9, 2023 at 1:52 PM
    #219
    Acedude
    Acedude New Member
    Colorado Plateau
    If anybody in future has that super annoying click noise from the center lower dash, I called Groove Toyota, parts guy says the part is called "Integration Panel" PN 84013c530. It covers the center/lower dash area below the touchscreen assembly including the HVAC controls. It has four separate clips that hold it in place, $290 for the panel, clips are additional cost. I think the lower left corner clip came loose causing the plastic on plastic clicking noise.
  10. Dec 9, 2024 at 10:50 AM
    #220
    72GTS
    72GTS New Member
    Ontario, Canada
    2021 MGM Tundra DC TRD Sport Premium
    Thank you for this post. I had a very annoying creaked or popping sound only in cold weather with my truck. It sounded like the sound was coming from the dash or lower windshield but was actually these tabs on the top of the windshield. I was able to remove the overhead console, the sun visors and the a-pillar trim to acess the tabs. I bent them away from the windshield and no more noise.
    Ruggybuggy[QUOTED] likes this.
  11. Dec 9, 2024 at 2:05 PM
    #221
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Glad it worked for you. You could swear it was from the dash and it shows you can’t always trust your ears.
    72GTS[QUOTED] likes this.
