Dark dash in daylight
Discussion in 'General Tundra Discussion' started by rockjockey, Oct 27, 2016.
  1. Oct 27, 2016 at 8:35 PM
    rockjockey
    rockjockey [OP] Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    Anyone else find that the main instument cluster is hard to read during the day? So much easier to see if I turn the headlight switch to the first position (front side lights and tail lights on) but it also dims the center dash screen. Can I use Techstream to change the dash light settings?
  2. Oct 27, 2016 at 8:50 PM
    TheBeast The Beach
    you should have a luminosity adjuster one the side. I have one on the gen 2 Tundra
  3. Oct 27, 2016 at 8:54 PM
    rockjockey
    Spring, TX
    D'oh! Maybe I should read the manual ....
    ColoradoTJ and TheBeast like this.
  4. Oct 27, 2016 at 8:55 PM
    TheBeast The Beach
    on 2014+ I believe you adjust the lights by turning the trip odometer counterclockwise
    rockjockey[OP] likes this.
  5. Oct 27, 2016 at 9:14 PM
    rockjockey
    Spring, TX
    Well, that's intuitive! No wonder I couldn't find it. Again, maybe I should read the manual ...
  6. Oct 27, 2016 at 9:22 PM
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Switched from 16 Taco
    Welcome to 3rd gen:). Dash light comes on only with side markers and low/high beam.
  7. Oct 27, 2016 at 9:22 PM
  8. Oct 27, 2016 at 9:27 PM
    rockjockey
    Spring, TX
    Just went and tried using the odometer knob. It does brighten and dim the little screen in the center of the dash cluster when the lights are off but does nothing for the gauges themselves unless the light switch is on. Any other ideas anyone?
  9. Oct 27, 2016 at 9:32 PM
    rockjockey
    Spring, TX
    4RNR - I'd like to like your post but I don't, like, like my lights!
  10. Oct 27, 2016 at 9:35 PM
    Jus saw u from Spring I'm off 290 n BW8 us Htown Tundra s shud start a club few others here on this site from Htown
  11. Oct 28, 2016 at 6:30 AM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    I actually opened a case with Toyota about this and their "Product Specialist" agreed with the problem BUT wanted me to have it documented by the Servicing Dealer. They did NOT test this scenario.
    In another words, you can live with it OR turn on your lights and deal with the dimmed center console.
  12. Oct 28, 2016 at 7:19 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    You could tape a flashlight to your steering wheel....
    TheBeast and NewImprovedRon like this.
  13. Oct 28, 2016 at 8:36 AM
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Yup
  14. Oct 28, 2016 at 10:57 AM
    TheBeast The Beach
    those gen 3 are way too complicated... :p:help::laser:
  15. Oct 28, 2016 at 6:51 PM
    rockjockey
    Spring, TX
    Hey, that solves part of the problem. Thanks! I'll give it a try in the morning ...
    NewImprovedRon likes this.
