Dan's Mid Travel Overlander Build
Discussion in '2.5 Gen Builds (2014-2021)' started by GiantsFanDan, Apr 12, 2018.
  1. May 19, 2018 at 7:09 AM
    #121
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    I like where this is going...
    Everyone seems to love those STT pros. And those wheels should look great.
    GiantsFanDan[OP] and Erichudgins like this.
  2. May 19, 2018 at 7:36 AM
    #122
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  3. May 19, 2018 at 7:45 AM
    #123
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Love my STT Pros in 295/70/18. They killed my gas mileage for sure, but they have earned more than their keep on muddy roads that my old KO2s would have been useless on. They look awesome as well.
  4. May 19, 2018 at 7:48 AM
    #124
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Any reason for the 295s over the 305s?
    GiantsFanDan[OP] likes this.
  5. May 19, 2018 at 7:55 AM
    #125
    UTTundra
    UTTundra New Member
    Lou
    Utah
    305/70? I went with 295s mainly because I knew it was already gonna be close without doing a BMC. I also got a great deal on the 295s (about $235 a piece).
    zcarpenter92 likes this.
  6. May 19, 2018 at 9:23 AM
    #126
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
  7. May 19, 2018 at 10:15 AM
    #127
    GiantsFanDan
    GiantsFanDan [OP] New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Drilling required doesn't seem so bad after the Peligreen pin stripping
  8. May 19, 2018 at 10:16 AM
    #128
    GiantsFanDan
    What's BL :confused:
  9. May 19, 2018 at 10:25 AM
    #129
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    If you are serious about it, get the nmo mount with it.
  10. May 19, 2018 at 10:32 AM
    #130
    Erichudgins
    Eric
    Murfreesboro, TN
    Just looking into it, all I saw was their 305 70 listed as their 35? And I found them for 233 a piece also so that's looking to be the route I'm gonna go. Gonna do the Bmc just to have the extra clearance. Pretty much the only reason I was considering 35's
  11. May 19, 2018 at 10:55 AM
    #131
    GiantsFanDan
    When I do it, I am going to get the mount too.
    GodlessPro[QUOTED] likes this.
  12. May 19, 2018 at 11:18 AM
    #132
    GodlessPro
    Matthew
    NorCal
    :thumbsup:
  13. May 20, 2018 at 11:05 AM
    #133
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Bed Light/Backup Light lol
  14. May 20, 2018 at 12:52 PM
    #134
    GiantsFanDan
    LOL
  15. May 23, 2018 at 8:10 PM
    #135
    GiantsFanDan
    New wheels and tires are on. Slight rubbing on body mount so the alignment is going to be adjusted tomorrow.
  16. May 23, 2018 at 8:13 PM
    #136
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Have you done a BMC?
  17. May 23, 2018 at 8:17 PM
    #137
    GiantsFanDan
    No, I've been told it's not needed with 295/70/18 tires. Chatted with Bryan and he said the caster needs to be adjusted since I had smaller tires on when everything was installed. He's going to make the adjustment tomorrow for me.
    dcsleeper408 and GodlessPro like this.
  18. May 23, 2018 at 8:20 PM
    #138
    GodlessPro
    Matthew
    NorCal
    I'm sure Bryan can fix you up with the alignment, but I say just chop it.
  19. May 23, 2018 at 8:23 PM
    #139
    GiantsFanDan
    I need to find a place to do it and time I can be without my truck again.
  20. May 23, 2018 at 8:50 PM
    #140
    GodlessPro
    Matthew
    NorCal
    @dcsleeper408 knows a guy
  21. May 23, 2018 at 8:50 PM
    #141
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It can be "fixed" with alignment but you're sacrificing caster. I would save the money for the alignment and do the BMC instead, but that's just me.
  22. May 23, 2018 at 8:53 PM
    #142
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Bet you the 4x4 shop in Livermore can do them. JP has some Relentless plates he’s not going to use. Actually you can pick mine up and I’ll get them from jp. Better than sacrificing caster.
  23. May 23, 2018 at 8:56 PM
    #143
    BlueBottle
    '16 Platinum 4x4
    See fine print
    ...that knows a guy...
    I’m w everyone here and just do it right and go under the knife. I’m getting mine done in a few weeks.
  24. May 23, 2018 at 9:13 PM
    #144
    Vizsla
    Vizsla 2 = 2.5
    :anonymous:If the body mount is the issue, aligning it to clear is a win. You gain caster. Moves bottom ball joint forward.
  25. May 23, 2018 at 9:19 PM
    #145
    GiantsFanDan
    In the end I will do the bmc. Just can't do the bmc now.
    Can someone explain the pluses and/or negatives of getting the caster adjusted?
    GodlessPro likes this.
  26. May 23, 2018 at 9:54 PM
    #146
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks for the correction, makes sense. For some reason I was thinking the top of the spindle moved forward but that's obviously not true cause the caster adjustment is in the LCA.
  27. May 23, 2018 at 10:19 PM
    #147
    TheBeast The Beach
    damn ! looking good with new shoes....starting to look like @joonbug twin...
    Sunnier and GodlessPro like this.
  28. May 23, 2018 at 10:19 PM
    #148
    TheBeast The Beach
    oh and let's not forget..:spending::spending:
  29. May 31, 2018 at 5:58 PM
    #149
    GiantsFanDan
    Some house work done on some plastic today. Had slight rub while in reverse after caster was changed. All fixed now
    Marks on the body mount were from before the caster adjustment was done
  30. May 31, 2018 at 6:02 PM
    #150
    TheBeast The Beach
    time to chop the cab mount :)
