Dan's Mid Travel Overlander Build
Discussion in '2.5 Gen Builds (2014-2021)' started by GiantsFanDan, Apr 12, 2018.
  1. Nov 11, 2018 at 1:51 PM
    #481
    Casper421
    In the woods
    06 DC
    Great idea with the spare mount!
  2. Nov 14, 2018 at 1:17 PM
    #482
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Dan if your Waterport is the same side that your tent folds over you'll have to mount it as low as possible otherwise they will hit.
  3. Nov 14, 2018 at 2:00 PM
    #483
    TheBeast The Beach
    looking good. need some line X in that bed to make it bomb proof
    joonbug likes this.
  4. Nov 14, 2018 at 2:35 PM
    #484
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I would watch that Waterport Mount. I mounted it in a similar manner to my bed-rails (using only top two holes) and after my first serious offroad trip, the mount bent!!
    joonbug and GodlessPro[QUOTED] like this.
  5. Nov 14, 2018 at 2:37 PM
    #485
    GodlessPro
    Matthew
    NorCal
    I'm really concerned about it and might end up leaving it home. Dan said that mounting to the rack is a lot more sturdy than the rail, but hanging off of the bottom like I have it might be just as bad.
    joonbug likes this.
  6. Nov 14, 2018 at 2:45 PM
    #486
    TheBeast The Beach
    with the 4 holes being bolted it would be better.
    joonbug likes this.
  7. Nov 14, 2018 at 3:09 PM
    #487
    GodlessPro
    Matthew
    NorCal
    The holes don't line up and it would be too high. If I have time and motivation tomorrow I might swap sides with my Maxtraks and drill new holes.
    joonbug likes this.
  8. Nov 14, 2018 at 3:13 PM
    #488
    DividedSky
    Jeff
    Any way you can get a piece of thick metal that you could put behind the mount? Then drill it for all four mounting holes? That might work...
    I ended up cutting a 4x4 so that the bottom of the mount conforms to the shape of the truck bed below the bed-rails. It could theoretically bend UP still, but it can't bend down any more.
    GodlessPro likes this.
  9. Nov 14, 2018 at 3:21 PM
    #489
    Stewie
    Stewie New Member
    2016 Crew Max
    @GodlessPro Matt, I have the same issue. The way my Waterport is installed on the bed rack, it will interfere when deploying the RTT. I’m just gonna remove the tank from the mount when RTT is up.
    OR18TRD, joonbug and GodlessPro like this.
  10. Nov 14, 2018 at 3:22 PM
    #490
    TheBeast The Beach
    are those racks the 10" height low profile types ?
  11. Nov 14, 2018 at 5:09 PM
    #491
    GodlessPro
    Matthew
    NorCal
    I think I'm just going to leave it off for this trip. Maybe I'll be able to make it work later on.
    joonbug likes this.
  12. Nov 14, 2018 at 5:16 PM
    #492
    GiantsFanDan
    GiantsFanDan [OP] New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    I'd swap sides or maybe could you change the tent to open up on the other side? Or don't fill the tank till you need to use it.
    joonbug likes this.
  13. Nov 14, 2018 at 5:22 PM
    #493
    GodlessPro
    Matthew
    NorCal
    Yeah I can swap sides with my maxtracks. How many bolts did you use on your Waterport bracket?
    joonbug likes this.
  14. Nov 14, 2018 at 5:35 PM
    #494
    GiantsFanDan
    4 total.
    GodlessPro[QUOTED] likes this.
  15. Nov 14, 2018 at 5:39 PM
    #495
    GodlessPro
    Matthew
    NorCal
    Getting all 4 corners bolted down would make it nice and secure, but it didn't look like the holes would line up. Once I realized that it would be too tall, I didn't spend a ton of time on it, if I swap sides I'll try to line it up.
  16. Nov 14, 2018 at 6:28 PM
    #496
    GiantsFanDan
    Not 4 corners but it’s solid. Think the key is having the whole plate mounted flat. We will see though
  17. Nov 14, 2018 at 7:26 PM
    #497
    GiantsFanDan
    RCI Transfer case and Transmission skid plate installed.
    Tepui Ayer Sky 2 should be here tomorrow. Just in time for Death Valley trip with the rest of the BASTRDS and SGU guys. Going to be an epic trip!! Can’t wait:mudding:
  18. Nov 14, 2018 at 7:55 PM
    #498
    GodlessPro
    Matthew
    NorCal
    That looks good.
  19. Nov 14, 2018 at 8:14 PM
    #499
    TheBeast The Beach
  20. Nov 14, 2018 at 8:41 PM
    #500
    GiantsFanDan
    Thanks
  21. Nov 14, 2018 at 8:46 PM
    #501
    GiantsFanDan
    I just noticed you have the real version of my wheels. Not the MB knock offs I have hahaha
    TheBeast and Erichudgins like this.
  22. Nov 19, 2018 at 9:58 PM
    #502
    GiantsFanDan
    November 16th to 19th Death Valley Trip.
  23. Nov 19, 2018 at 10:03 PM
    #503
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    Get that video posted!
  24. Nov 19, 2018 at 10:05 PM
    #504
    GiantsFanDan
    Tomorrow for sure. I'm beat and want to sleep now LOL
  25. Nov 20, 2018 at 10:36 PM
    #505
    GiantsFanDan
    Death Valley Video's
    First video is a bit long. GoPro shot from inside the cab
  26. Nov 22, 2018 at 7:38 PM
    #506
    GiantsFanDan
    Exhaust flange is now fixed after Death Valley trip broke it.
    And RTT installed
  27. Nov 22, 2018 at 8:28 PM
    #507
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Great build man! Keep pushing!
  28. Dec 2, 2018 at 9:59 AM
    #508
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Really sick build and thread!!!
    GiantsFanDan[OP] likes this.
  29. Dec 2, 2018 at 11:33 AM
    #509
    TheBeast The Beach
    so no RTT for the trip but one after ? did they persuade you ? :)
  30. Dec 2, 2018 at 11:39 AM
    #510
    GiantsFanDan
    Thanks!
    It didn't show up on time for the trip :(
    TheBeast[QUOTED] and Erichudgins like this.
