D3's Black 18' Crewmax Tundra Build
Discussion in '2.5 Gen Builds (2014-2021)' started by D3Tundra, Sep 11, 2018.
  1. Jan 8, 2020 at 8:35 AM
    D3Tundra
    D3Tundra [OP] New Member
    Dennis
    Atlanta, GA
    2018 Midnight Black Tundra Limited 4x4 CM
    Rigid fog lights Interior Led light upgrade Spray in Bedliner CRUX Avity-01 VIM Bypass module 5% tint all the way around 50% on the windshield Wireless charger arm rest mod Amp Research Steps Bak Revolver X4 Tesla Style Headunit Procomp 4" lift Toyo M/T's 35x12.5xR22 Fuel Maverick D538 wheels 22x10 -24 offset
  2. May 26, 2020 at 6:00 PM
    Dannyboy34
    Dannyboy34 New Member
    @D3Tundra looking to do the power fold mirror mod my truck is a 15 sr5, trying to figure out what wire to tap into for the power fold and my plug where my switch goes has only 7 pins
  3. Aug 12, 2020 at 11:42 AM
    XPTUNDRA
    XPTUNDRA New Member
    North MS
    2016 Tundra Limited
    4" Pro Comp Lift 35x12.50x20 Toyo RT's 20x9 +20 Fuel Mavericks Rough Country soft tri-fold bed cover LED headlight and Fogs with LEDs throughout the cab as well
  4. Feb 22, 2023 at 11:55 AM
    Getoffmylawn
    Getoffmylawn New Member
    Taylor
    Thank you for this helpful writeup on how to install the power fold and puddle lamps...I'm doing the exact same thing on mine right now. I've run into a weird one, where both puddle lamps work properly, and the drivers side power fold works as it should with those wires going to the back of the switch, but the passenger side isn't folding at all. I thought it might be an issue with the passenger side wires being T-tapped into the drivers side wires, so I pulled the drivers side wires from the back of the switch harness, and put the passenger side wires into the switch harness but still no fold. So looks like I need to test the passenger side mirror to make sure the power fold motor isn't dead.
    My question is about your tester above...I'm assuming you just clamped the black to a ground on the vehicle somewhere, and the red to the positive terminal on your battery, and then plug the black pin into terminal 5 on the back of the mirror, and then used the red pin to touch each of the other pins individually to see what does what?
  5. Feb 23, 2023 at 9:41 AM
    D3Tundra
    Dennis
    Atlanta, GA
    Thats correct.
  6. Feb 23, 2023 at 9:42 AM
    Getoffmylawn
    Taylor
    Awesome, thanks! I ended up figuring out the issue with the passenger side power fold...the two pins needed to be pushed about another 1/8" into the back of the plug and that sorted it out. Thanks again for the writeup...no way I would have taken this project on without reading this first!
    D3Tundra[OP] likes this.
