CV Joint or U-Joint?
Discussion in '1st Gen Tundras (2000-2006)' started by 06tundralongbed, Apr 2, 2021.
  1. Apr 2, 2021 at 9:20 AM
    06tundralongbed
    06tundralongbed [OP] New Member
    06 tundra longbed
    I have an '06 Tundra, 6 cyl. and need to know if it has CV or U joint. How can I tell?
  2. Apr 2, 2021 at 9:24 AM
    Professional Hand Model
    Hand Protectors
  3. Apr 2, 2021 at 11:20 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Likely it has a double cardan joint. Basically 2 u-joints put together and sometimes called a CV joint on driveshafts.
    If you think it needs replaced try a heavy truck shop and drop the driveshaft off with them. They'll have the tools necessary to rebuild it without you having to buy an entire new shaft.
  4. Apr 2, 2021 at 3:46 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I think 2004-2006 is 4.0L V6. 3.4L ended in 2003? CV joints are out of my league also as I'm one wheel peel.
    I have no clue on the 4.0 Liter engine in general.
    I'm going with @Festerw here.
  5. Apr 3, 2021 at 8:56 AM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    U joint usually do not need cover boots. CV do.
  6. Apr 3, 2021 at 9:45 AM
    Rear drive shaft is all U-joints. Front driveshaft between transfer case and front diff has U-joints. Front half shafts from differential to wheels have CV joints. There's a tiny U-joint on the steering shaft also. Not sure where on the vehicle you're referring to, or which model you have.
    rock climber likes this.
