Cv axle replacement
Discussion in '1st Gen Tundras (2000-2006)' started by Freebird, Jun 29, 2025.
  1. Jun 30, 2025 at 10:37 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Thanks for the info. Good to know, I'll stick with OEM then, the place I was going to take it in was trying to encourage me to go aftermarket extended travel for around the same price--but I'd always must rather have oem if given a choice
  2. Jun 30, 2025 at 10:41 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    See my thoughts below on the Trakmotive "extended travel" axles:
    Dblock500[QUOTED] and shifty` like this.
  3. Jun 30, 2025 at 11:38 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I would recommend just rebooting your OEM axles. I've done two of my own now and it is not bad at all, just a little messy. I'm going to try out the porsche boot mod on my spare axles that I'm about to reboot. My tip is to buy oem used axles off ebay and reboot them. I've bought them with a return policy and for $100 or less each.
  4. Jun 30, 2025 at 5:47 PM
    Shit. You're right. My bad.
    If it's just loose and not torn, simply re-clamp it. It's typical for them to kick out grease after lifting, specifically, but if the issue is that the boot popped off the clamp site, re-clamp. The diameter is printed on the clamp (like this), and here's a list of NORMA clamps that are good for the job.
  5. Jun 30, 2025 at 5:49 PM
    When parts are fully discontinued, you can't even load them up at the national Toyota parts site. The fact they're still in the system there suggests they have limited availability at the moment.
    Dustdog[QUOTED] likes this.
