Cutting hole in Skid Plate
Discussion in '1st Gen Tundras (2000-2006)' started by robabeatle, May 8, 2025.
  1. May 10, 2025 at 9:50 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Ditto.
    BubbaW[QUOTED] likes this.
  2. May 10, 2025 at 6:38 PM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    My experience with changing the oil and filter on my back in the driveway is that is is not too difficult to remove the skid plate, but can be challenging to get the bolts started during installation with limited space and no way to see the threaded holes.
    WILLINH likes this.
  3. May 10, 2025 at 6:47 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    You hook the front in, then start a bolt in a socket with an extension attached in the rear. Then you start the other rear bolt before starting the fronts. I use hand tools, so i only used half an ugga. Wrist tight.
    the skidrow stuff isnt worth pulling every 5k, but i bet i pull it off once a year or so.
    G_unit3000, Fragman and Jack McCarthy like this.
  4. May 10, 2025 at 7:19 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    For the first screw, you can also see the screw and the hole if you look at the plate from the side at the rear. Just insert and hold the screw in hole in the plate as you lift it up. Makes it much easier to line the screw up. Once that one is in, everything else is cake.
  5. May 10, 2025 at 8:27 PM
    Jack McCarthy
    Bill
    North of Boston
    I just hook myself in the front, hold up the ass end with one hand while I feel for the hole in the darkness to insert my screw. :rolleyes:
    chunk and FrenchToasty like this.
  6. May 11, 2025 at 5:15 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I recall reading something very similar in Dr. Ruth's Romance for Dummies :facepalm:
  7. May 11, 2025 at 6:53 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I agree it makes sense to take the skid plate off. My problem has been broken bolts. I'm terrible at broken bolt extraction. When I sold my Tacoma, it was hanging on by two bolts. First time I did an oil change on the Tundra, one was already broken and I broke another. So I'm just frustrated with the skid plate and would rather not deal with it.
    I'm off road all the time and leaving it off isn't an option.
    If I could get back to baseline, with 5 new bolts and all the broken bolts cleared out, I think I'd be happy to take it off each oil change. My Tundra has the added complexity of the rubber side wings. I was going to get rid of them since they're pretty stripped out too, but I really like the extra splash guard, especially in the winter.
    Every time I change my oil I think "damn, some day I need to just fix all these stripped and broken bolts and holes, and this would be so much less frustrating". Then I forget about it until my next oil change...
    rouxster70 likes this.
  8. May 11, 2025 at 7:14 AM
    Jack McCarthy
    Bill
    North of Boston
    Cover the bolt threads in used oil. It's worked for me over the last 23 years. Bolts are still original.
  9. May 11, 2025 at 12:52 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
  10. May 11, 2025 at 2:23 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    Fix your skid bolts, drill and extract. Chase the threads and install new bolts. The skid stuff is 101, remove , work, replace. These are high enough to not even need a jack. Spray some lube if stuck or not turning. If 5 minutes is that valuable, perhaps you may need to farm this out. I’ve f-ed up my share of fasteners, correcting screw ups is what it’s all about. Also I don’t have much of a life outside of working on my junk. As far as thread chaser are concerned, buy a kit or individually, only 3-4 metric sizes for most threads on your Toyotas. Oem filter and Napa(valvoline) oil, be like $35 otd. Cheaper than jiffy and you know you can prevent a fuck up. Bring old oil to whatever auto store easiest for ya.
    NewImprovedRon likes this.
  11. May 26, 2025 at 6:33 AM
    Jedgar
    Jedgar New Member
    2006 SR5 Double Cab 4WD, V8, forest green w/ topper
    None (no lift, don't want one), Bilstein 4600 shocks soon. Bigger Michelin tires soon.
    Would love to see some actual test data showing 1+ mpg better with skid plate on. I run with mine off (installed a front hitch), and have never noticed any appreciable mpg difference. I could reinstall it, but would mod to get to il filter and to fit around hitch.
  12. May 26, 2025 at 10:41 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I just changed my oil a couple of days ago, skid plate off and back on, easy peasy.
  13. May 26, 2025 at 1:22 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    My 2000 has the fiberglass skid plate. I remove it every oil change. 8 bolts but easy job. Only issue was PO must. Have used an impact and screwed up the M-8 x1.25 threads but a thread chaser and new bolts fixed that.
