Customizing alternator charging profile for Odyssey AGM batteries?
Discussion in 'Performance and Tuning' started by goffredo, Dec 10, 2019.
  1. Jan 13, 2020 at 11:35 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Putting it in the wrong way had the battery light on.
    Thanks.
  2. Jan 13, 2020 at 12:47 PM
    blizz86
    blizz86 New Member
    Would the gm diode just plug into an add a fuse with the stock fuse as well?
  3. Jan 13, 2020 at 1:00 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    No, w/ an add-a-fuse you are left with a pigtail for your new fused accessory, which then behaves as two separate fused accessories. You wouldn’t be able to tie the added fuse into anything using the pigtail, if you get what I’m saying...
  4. Jan 13, 2020 at 1:22 PM
    blizz86
    blizz86 New Member
    That makes sense. I was confused because I’ve been reading threads where people are making their own. Is there any apparent danger to just using the gm diode without a fuse?
  5. Jan 13, 2020 at 1:29 PM
    Jrharvey02
    Probably a bit...
    blizz86[QUOTED] likes this.
  6. Jan 13, 2020 at 1:52 PM
    blizz86
    blizz86 New Member
    Bought the HKB off ebay.
    For the others reading: $50 shipped to us.
  7. Jan 13, 2020 at 4:30 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    The GM diode IS a fuse too 7.5amp I believe. I don't have one at the moment to check.
  8. Jan 13, 2020 at 4:47 PM
    Vizsla
    Vizsla 2 = 2.5
    I have the $24 one from EBay, no complaints.
  9. Mar 24, 2020 at 9:57 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I'm glad to have found this thread. On the way to work I stopped off for gas and my truck barely started back up. I ordered a Northstar 31A and a mk4 adjustable.
  10. Mar 24, 2020 at 12:38 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I'm torn.
    I've been running a northstar 27f for a little over a year now. I mainly got one, because i know the factory batteries are just a ticking timebomb, and i dont want to get stranded anywhere.
    Learning about this now has me curious. On one hand, if it aint broke, dont fix it....and on the other, i want this battery to last.....maybe i'll email northstar.
    RitcheyRch and TruckyTruck like this.
  11. Mar 24, 2020 at 12:41 PM
    TruckyTruck
    Gary
    From what I read, you may be fine with the diode fuse. I bought the adjustable one since I pull a camper a lot. The camper batteries take a charge from my truck.
  12. Aug 13, 2020 at 9:03 AM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    Did you ever email Northstar? If so, what did you find out? I just ordered a Northstar 27F today, so I'm curious...
    Dave
  13. Aug 13, 2020 at 9:54 AM
    Danimal86
    Daniel
    Sacramento, CA
    I didn't, i ended up getting the diode to go in the Alt-s fuse location and it upped my charging voltage a half a volt.
    SouthWestGA likes this.
  14. Sep 6, 2020 at 9:13 PM
    Danimal86
    Daniel
    Sacramento, CA
    Just pull the trigger now before the stock one leaves you stranded
  15. Sep 6, 2020 at 9:18 PM
    Danimal86
    Daniel
    Sacramento, CA
    Very good idea. I pulled my factory battery at about 6mo old (there was a group buy at the time, that may have helped a little) after reading about the factory batteries.
    With the noco, youll be good
  16. Sep 23, 2020 at 9:22 PM
    ttime4four
    ttime4four New Member
    West Linn, OR
    '20 Tundra Limited DC TRD Offroad
    Awesome info and great thread. I purchased my diode from Mouser Electronics for $11.20 ($3.21 + $7.99 2-day shipping). Slight trim and it fit right into the ALT-S slot. Here are the voltmeter readings:
    Before - 13.88 VDC
    After - 14.34 VDC
    I put it in backwards at first and the BATTERY light remained on after start. Switched it around and the battery light turned off. For my 2020 Tundra, the correct orientation of the "arrow" on the diode points forwards.
    R65, 619Tundra and blackoutt[QUOTED] like this.
  17. Sep 24, 2020 at 7:48 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Awesome. I will order one tonight.
  18. Sep 24, 2020 at 8:04 PM
    619Tundra
    Looks like HKB has 3 different ones. 5.0A, 7.5A, and a charger.
  19. Dec 4, 2021 at 8:10 PM
    #49
    AZTundra
    Paul
    Phoenix, AZ
  20. Dec 4, 2021 at 8:11 PM
    #50
    SouthWestGA
    SouthWestGA New Member
    I installed a GM diode after reading Tacoma and 4Runner forums . It’s much cheaper and is the same thing
    AZTundra likes this.
  21. Dec 4, 2021 at 8:13 PM
    #51
    AZTundra
    Paul
    Phoenix, AZ
    Thanks for the quick response. I was looking at that option also and just might go that route for now. For checking the voltage are you just using the multimeter while the engine is idling?
  22. Dec 4, 2021 at 8:15 PM
    #52
    e30cabrio
    I have the 7 amp in my Sequoia with the Battery plus Northern AGM
  23. Dec 4, 2021 at 8:36 PM
    #53
    SouthWestGA
    Yes i checked it that way and also ran a digital volt meter into the cab for a few weeks .
    AZTundra[QUOTED] likes this.
  24. Dec 4, 2021 at 8:40 PM
    #54
    AZTundra
    Paul
    Phoenix, AZ
    Perfect, thanks!
  25. Dec 5, 2021 at 12:02 AM
    #55
    R65
    R65 New Member
    2021 Tundra double cab
