Custom Under-Seat Storage (crewmax)
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1_thirsty_tundra, Dec 5, 2019.
  1. Dec 5, 2019 at 5:47 AM
    1_thirsty_tundra
    1_thirsty_tundra [OP] The Thirsty Tundra
    Jay
    Alberta Canada
    2019 SR5 Off-Road Crew Max
    Spintech custom exhaust Bilstein 6112 / 5100 Coachbuilder shackles / shims Vled LED interior Winjet tails Pacer high 5 cab lights Fuel Contra 20x10-18 wheels Wireless Apple Carplay/ Android auto Custom Pioneer stereo system Custom Crewmax underseat storage
    Built my own under seat storage for my crew max. Added some LED lights which are triggered by the dome light circuit. Then had it professionally bed lined for impact, water resistance and a better overall look.
    Cost me around $200 CAD for everything including some new tools.
    Boxes are slightly larger than the ESP one and that bed liner makes it far more durable.
    Approx. box sizes are as follows:
    Passenger 9.5” x 13” x 4.5”
    Center 13” x 13” x 4.5”
    Driver 11.5” x 13” x 4.5”
    Also if you look close I cut down the interior box sides which gives me one large box around the perimeter. This is handy for long thin items like a snow brush or collapsed fishing pole etc ...
    I couldn't be happier !!
  2. Dec 5, 2019 at 5:53 AM
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    Looks good! It must be pretty heavy with it being wood and lined.
  3. Dec 5, 2019 at 5:55 AM
    1_thirsty_tundra
    Jay
    Alberta Canada
    Oh my god no lol, not at all !! Not even half a sheet of ply wood and the coating is only a few mm thick. Id say less than 20 pounds for sure. I easily carried it with one hand and little effort.
    tundra_20, Outbound, GODZILLA and 3 others like this.
  4. Dec 5, 2019 at 5:59 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Looks great! I like the added blue LED's
    1_thirsty_tundra[OP] likes this.
  5. Dec 5, 2019 at 6:00 AM
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    I meant relative to the ESP one.
    Looks great with a custom touch.
  6. Dec 5, 2019 at 6:04 AM
    Spakylpm
    Spakylpm New Member
    2024 Tundra
    Wow man, that looks awesome great craftmanship! Are the lights battery powered? You should sell those I would buy one
  7. Dec 5, 2019 at 6:09 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Great job man!
  8. Dec 5, 2019 at 6:10 AM
    1_thirsty_tundra
    Jay
    Alberta Canada
    Thanks.... lights are wired to dome light circuit. Come on when doors are opened.
    Shipping wouldnt make these profitable sorry.
    4x4_Angel likes this.
  9. Dec 5, 2019 at 6:11 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Functional beauty! Well done sir!
  10. Dec 5, 2019 at 6:12 AM
    1_thirsty_tundra
    Jay
    Alberta Canada
    Thanks and yes for sure as the ESP is plastic. I could throw chain in mine tho which im not sure Id try with a plastic one. :monocle:
  11. Dec 5, 2019 at 6:23 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    WOW - Nice work man...:thumbsup:
  12. Dec 5, 2019 at 6:25 AM
    whiskeydrink
    whiskeydrink Asst to the Regional Manager
    West TN
    2019 QS SR5 Offroad
  13. Dec 5, 2019 at 6:31 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    That’s look great, awesome job.
  14. Dec 5, 2019 at 6:31 AM
    Riggs711
    Riggs711 New Member
    2018 Limited Crewmax
    That looks awesome
  15. Dec 5, 2019 at 6:31 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    That looks outstanding!! Nice work!
  16. Dec 5, 2019 at 6:37 AM
    Rockranger77
    Rockranger77 New Member
    Alabama
    19 platinum
  17. Dec 5, 2019 at 6:41 AM
    THEMrs.J
    THEMrs.J New Member
    Lori
    2020 Cement Tundra SR5 Crewmax TRD
    Looks great!! Kinda jealous.....:D
  18. Dec 5, 2019 at 6:55 AM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    Sell me one? I like it, very nice work!
    What I like is you make better use of the vertical going up higher than the ESP one.
    The only other suggestion I'd have (not that you need to do anything to it at all) but if you can figure out how to add some sort of tray where the two seat supports are (the high spots) just to place small things and prevent them from rolling/sliding into the larger areas maybe? OR do the ESP mod to remove those brackets altogether then you'd have one large space you could use dividers to create whatever size space you needed?
    The sad part to all of this is the MAJOR waste of space Toyota has given us in lieu of some worthwhile storage!
  19. Dec 5, 2019 at 8:06 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    That looks great. You do a better job of using available space and the integrated lighting is very clever.
    It is true that reproduction using wood might make the shipping and your labor cost prohibitive, but you could consider this:
    pull the 5.7 emblems and make a fiberglass cast(s).
    That would be tough, light, and the end user could choose a finish and put their own desired emblem in (consider that some folks have the smaller engine).
    Just something to consider if you did want to reproduce these and possibly make some coin. I think you would have a lot of takers.
    I for one will be modifying my ESP unit and adding leds, shamelessly borrowing from your ingenuity!
    If you did make plastic or fiberglass blanks at a competitive price, I would probably be in that line....
    :spending:
  20. Dec 5, 2019 at 8:26 AM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
  21. Dec 5, 2019 at 8:40 AM
    TundraXPLover
    TundraXPLover New Member
    Clif
    NC
    2018 CM 4x4 XP
    That right there is awesome!
    You could probably patent that idea!
  22. Dec 5, 2019 at 8:46 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    By far the best DIY one I’ve seen yet. Nicely done!
  23. Dec 5, 2019 at 8:48 AM
    KnuckleHD
    And a great way to reuse the stock emblems. I still have mine laying around in a box somewhere...Would the “Tundra” logo fit on the sides or is too long?
  24. Dec 5, 2019 at 9:04 AM
    Honestly, I'd buy the plans for this so I could build one myself. This is spectacular.
  25. Dec 5, 2019 at 10:42 AM
    1_thirsty_tundra
    Jay
    Alberta Canada
    Tundra was too long for my design. I tried lol
    KnuckleHD[QUOTED] likes this.
  26. Dec 5, 2019 at 10:52 AM
    1_thirsty_tundra
    Jay
    Alberta Canada
    Thanks everyone for the kind words!!
    :canada::cheers:
  27. Dec 5, 2019 at 10:55 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Any chance you'd be willing to provide a detailed cut sheet with diagram? I am sure there are many of us who would be willing to pay for the plans to replicate this. I am just not handy or confident enough in my ability to tackle this on my own without screwing it up and paying for twice the amount of materials needed
    blizz86, Outbound, tbutler and 2 others like this.
  28. Dec 5, 2019 at 10:57 AM
    I'm in a similar boat, but I also know two master carpenters that I could probably get to build it for me for some Mountain Dew and Doughnuts. :D
  29. Dec 5, 2019 at 10:58 AM
    1_thirsty_tundra
    Jay
    Alberta Canada
    I really appreciate that but I was just measuring and designing as I went. I didnt write anything down other than some rough measurements. Its really easy to just take a tape measure and go to your truck and plot it all out. Make a cardboard template first and that way you wont waste material. Sorry I cant be more helpful ....
    sf319 and BravoDeltaRomeo like this.
  30. Dec 5, 2019 at 11:00 AM
    1_thirsty_tundra
    Jay
    Alberta Canada
    A half assed carpenter could make these, I wouldnt even waste a master carpenters time lmao
