Custom Leaf Springs Input-Alcan & Dakar only?
Discussion in 'Suspension' started by Tslyjr, Dec 15, 2021.
  1. Jan 14, 2022 at 10:25 AM
    #211
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    If you're adding a leaf at the bottom, then shouldn't be a problem. If you're inserting the leaf in between the pack, then the pack will expand when you remove the center pin. If your clamp doesn't allow it to expand enough, then it might not be as easy to get the leaf in.
    Punisher29073[QUOTED] likes this.
  2. Jan 14, 2022 at 10:28 AM
    #212
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    Let’s pray they are on the bottom.
    Cruzer likes this.
  3. Jan 14, 2022 at 10:30 AM
    #213
    Cruzer
    Cruz
    Sunnyvale, CA
    Lew will tell you where it goes.
  4. Jan 14, 2022 at 11:19 AM
    #214
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah I kinda sorta hoped the same but it wasn't lol
  5. Jan 14, 2022 at 11:23 AM
    #215
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    When I inserted my AAL, I pulled the pack, separated the top 4 leaves and held them together with the clamp using a screwdriver to keep the holes lined up. For the bottom part of the pack I used the "old" bolt to keep them lined up.
    Unfortunately, the leaf he sent me was too long so I "modified" it (the ends were hitting the retainer rivets on either side of the pack)
  6. Jan 14, 2022 at 12:23 PM
    #216
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    These were add a leafs to Alcan spring packs? How many AALs did you add? How many springs did yours have?
  7. Jan 14, 2022 at 12:27 PM
    #217
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    1.
    From top to bottom it went between leaves 4 & 5. I was gonna dremel the retainer bolt holes because the bolts wouldn't quite slide through due to the pack being thicker but I ended up clamping down enough to get the bolts through.
    I had 8 now I have 9
  8. Jan 14, 2022 at 2:05 PM
    #218
    They are installed. Yes, they look basically flat across with minimal arch but maybe it's because of the Toytec shackles? From bottom of the flare to the ground was 41 1/4 and after was 41 3/4.
    Compress_20220114_170332_2607.jpg Compress_20220114_170332_2817.jpg Compress_20220114_170332_2072.jpg Compress_20220114_170334_4927.jpg Compress_20220114_170335_5340.jpg Compress_20220114_170334_4694.jpg
  9. Jan 14, 2022 at 2:08 PM
    #219
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Looks great dude! I couldn't get my sway bar back on after I added the leaf. Ordered longer links so will see if I can get it back on once they arrive
  10. Jan 14, 2022 at 2:11 PM
    #220
    Thanks. So the "flat" look is okay? Those fkers are heavy when you're working by yourself. Gonna test drive shortly.
  11. Jan 14, 2022 at 2:36 PM
    #221
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You ain't lyin. I swear 9 leaves is close to 100#
    I think with the amount of leaves you have, minimal lift, you shouldn't expect much arch.
  12. Jan 14, 2022 at 2:39 PM
    #222
    BayRunner
    2017 Tundra Platinum
    ^^^This. You had them built to 1/2” lift, plus the additional 1.5” from the Toytec shackles. They look as I would expect them to.
  13. Jan 14, 2022 at 2:41 PM
    #223
    Thanks @texasrho83 and @BayRunner. You guys are more familiar with the leaf spring design on the Tundras more than I am.
    texasrho83 likes this.
  14. Jan 14, 2022 at 2:46 PM
    #224
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yw. Let us know what you think of the ride.
    Also, can you take a pic of your shackle from the rear? Specifically where it bolts onto the leaf. I'm curious about somethin...
  15. Jan 14, 2022 at 2:55 PM
    #225
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    troofff.
  16. Jan 14, 2022 at 2:56 PM
    #226
    Will do.
  17. Jan 14, 2022 at 3:38 PM
    #227
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The CB shackles don't hug the leaf bushings like the Toytecs do...
  18. Jan 14, 2022 at 4:59 PM
    #228
    Ride was nice. I went over some large speed bumps at 25 mph and it felt like the ride over them was softer.
  19. Jan 20, 2022 at 9:20 AM
    #229
    Any of you guys know what would cause a pop when reversing? From what I can tell, it only does it in the morning when I am backing out of the driveway.
    texasrho83 and AggiePhil like this.
  20. Jan 20, 2022 at 9:43 AM
    #230
    Cruzer
    Cruz
    Sunnyvale, CA
    Are you moving in reverse when it pops or when you put the transmission into reverse?
  21. Jan 20, 2022 at 9:51 AM
    #231
    Moving. It does if after 6 or 7 feet roughly.
  22. Jan 20, 2022 at 10:34 AM
    #232
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Mine does this too. Factory suspension. Hate it.
  23. Jan 20, 2022 at 12:16 PM
    #233
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I noticed it too. I'm curious if the aftermarket shackles are to blame.
  24. Jan 20, 2022 at 2:01 PM
    #234
    Cruzer
    Cruz
    Sunnyvale, CA
    Try taking video of your leaf springs, shackles, or 3rd member. Might take a few mornings to capture what it is.
  25. Jan 20, 2022 at 2:56 PM
    #235
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Just got the leaf springs but prob won't be able to work on it for another few weeks. I noticed some slight chipping from the powder coat. Idk if it is worth mentioning to Lew or not. Also, on both leaf springs, the second leaf seems to be pushed out slightly compared to the others. Is this normal?
  26. Jan 20, 2022 at 3:01 PM
    #236
    Cruzer
    Cruz
    Sunnyvale, CA
    It's normal for leafs to twist out of position, just bang it back in place with a hammer. Don't overtighten that center pin thinking it'll hold it in place. It's not powder coating, they dip the whole thing in some sort of coating for rust protection, which doesn't really stay on there - it'll start to eventually peel. UPS guy probably didn't like carrying it and let it scrape.
  27. Jan 20, 2022 at 3:03 PM
    #237
    YotaBro
    Calvin
    FL
    Thanks man! Should I just spray it with some Rustoleum before I install it? Do I need to loosen the center bolt then hammer it into position or just try hammering it into position as is?
    TheBeast likes this.
  28. Jan 20, 2022 at 3:05 PM
    #238
    Cruzer
    Cruz
    Sunnyvale, CA
    Do not loosen the center pin. Just hammer it as is, it'll move easily. Definitely rattle can it.
    YotaBro[QUOTED] likes this.
  29. Jan 20, 2022 at 3:05 PM
    #239
    YotaBro
    Calvin
    FL
    Thanks, brotha!
  30. Jan 20, 2022 at 3:27 PM
    #240
    Mine looked the same. I have to touch them up still. Be very careful of the ABS wire when you lift them over the axle.
    YotaBro[QUOTED] and Cruzer like this.
