Custom Leaf Springs Input-Alcan & Dakar only?
Discussion in 'Suspension' started by Tslyjr, Dec 15, 2021.
  1. Feb 7, 2022 at 6:06 PM
    #331
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    There is a ton of thick black paint on these that's for sure
    cowboyjack and Mrf1987[QUOTED] like this.
  2. Feb 8, 2022 at 6:51 AM
    #332
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    9/16" is your u-bolt size?
  3. Feb 8, 2022 at 6:56 AM
    #333
    Yes
  4. Feb 8, 2022 at 6:58 AM
    #334
    Right now my ubolts are at 90 ft lbs, rear shackle is at 65 ft lbs, and forward spring mount is at 90 ft.lbs.
  5. Feb 8, 2022 at 8:52 AM
    #335
    BayRunner
    2017 Tundra Platinum
    Look at what showed up today. UPS driver wanted nothing to do with them. Knocked on the door and said “I’ve got some springs in the back of my truck.” Translation: come get your crap out of my truck, I’m not touching them.,
  6. Feb 12, 2022 at 4:44 AM
    #336
    What shackles are you running and what are they torqued to?
  7. Feb 12, 2022 at 4:44 AM
    #337
    Haven't looked at it yet but the pop stopped again after 2 days. :notsure:
  8. Feb 12, 2022 at 6:16 AM
    #338
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Weather change? Springs settled?
  9. Feb 12, 2022 at 6:27 AM
    #339
    Weather has been up and down lol.
  10. Feb 12, 2022 at 8:03 AM
    #340
    cowboyjack
    cowboyjack New Member
    Alcan shackles. Don’t know torque spec.
  11. Feb 12, 2022 at 8:05 AM
    #341
    Mrf1987
    Mrf1987 New Member
    2020 Trd sport tundra
    coming on here complaining about it weekly and not getting under the truck isn't going to solve the issue but I'm sure you know this by now haha. "Its Okay I can be guilty of the same". Like I've said previously, I'm sure its the leaf springs themselves. The thick rubber type coating they put on them is sticky between the leafs. Until it wears out of there its going to make noise. When its warmer out it got worse for me and you could feel the coating was sticky as it rubbed off. When my deavers were new It happened every time i took off from a light or moved my truck for the first time in the morning. Now that I've gotten some miles on them and really cycled the suspension it is almost gone. It may do it every once in a while but it is 95% better than when they were new. I fully expect my alcans to do the same. You could jack the truck up and separate each leaf at its contact point and spray some lube in there but the better option seems to be turn the radio up and go flex that thing out haha.
    texasrho83 and cowboyjack like this.
  12. Feb 12, 2022 at 9:10 AM
    #342
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    99.9% of the sounds we bitch about can be solved by turning up the radio :p
    cowboyjack likes this.
  13. Feb 12, 2022 at 9:14 AM
    #343
    Mrf1987
    Mrf1987 New Member
    I used to be so concerned about the noises my rig made....Now the only noise that really makes me cringe a little is the sound of tree branches freddy crugering their way down the sides of my paint lol. Even then.......after 5 beers I forget all about it.
  14. Feb 12, 2022 at 12:09 PM
    #344
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Amen :cheers:
  15. Feb 28, 2022 at 1:17 PM
    #345
    BayRunner
    Well got the Alcan’s installed today.
    • +800 lbs
    • 8 leafs per pack
    • Ordered 1.5” lift in the springs + .5” from shackles = 2” lift
    • Rear height after springs is nearly 3”
    Currently sitting with nearly a 3” rake. I may have to raise the front a bit, but before doing so did anyone with Alcans see any settlement? If so, how much did they settle?
    COTundra23 likes this.
  16. Feb 28, 2022 at 2:13 PM
    #346
    What did you torque everything to? I still have popping.
  17. Feb 28, 2022 at 2:15 PM
    #347
    BayRunner
    Sorry, don’t know. I had a local off road shop do the install.
    Did your springs settle any?
  18. Feb 28, 2022 at 2:18 PM
    #348
    I'll measure them after I find my measurements that I wrote down.
  19. Mar 6, 2022 at 3:47 PM
    #349
    cowboyjack
    Yes. I would say mine settled 3/4” to 1.0” and softened just slightly. Or maybe I just got used to them.
  20. Mar 6, 2022 at 4:27 PM
    #350
    BayRunner
    Sounds good. How long did it take to settle? Just wondering how long to wait befor I adjust my front height.
  21. Mar 6, 2022 at 5:08 PM
    #351
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    That's a ton of settling imo
  22. Mar 6, 2022 at 5:32 PM
    #352
    I still need to check mine. This popping is driving me crazy now....I'll look at it next weekend.
  23. Mar 6, 2022 at 5:48 PM
    #353
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You sure it's from the leaves?
  24. Mar 6, 2022 at 5:52 PM
    #354
    BayRunner
    No popping from mine. Hope you figure it out
  25. Mar 6, 2022 at 5:54 PM
    #355
    Has to be the shackles or rear sway bar. :notsure:
  26. Mar 6, 2022 at 5:57 PM
    #356
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Do you have different shackles you can try out? I have my stocks if you need em
  27. Mar 6, 2022 at 6:01 PM
    #357
    I still have my stock shackles. I haven't messed with it but it could be a torque issue. The pop starts as soon as you take your foot off the brake when in reverse.
  28. Mar 6, 2022 at 6:20 PM
    #358
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Have you checked your u-joints?
  29. Mar 6, 2022 at 6:21 PM
    #359
    No but I would doubt ujoints going bad already.
  30. Mar 6, 2022 at 6:22 PM
    #360
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Worth looking into. One more thing checked off the list. At the least I'd swap shackles.
