Custom Battery Hold Down Brackets for 1st Gen
Discussion in '1st Gen Tundra Parts Marketplace (2000-2006)' started by Coupe, May 12, 2020.
Thread Status:
Not open for further replies.
  1. Aug 4, 2020 at 6:06 PM
    #61
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    pic isn't working?
  2. Aug 4, 2020 at 6:27 PM
    #62
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Here is my 06 DC. Please excuse the dust, just got back from the cabin
  3. Aug 4, 2020 at 6:29 PM
    #63
    Coupe
    Coupe [OP] New Member
    James
    Houston, Texas
    2008 Toyota X-Runner
    TRD S/C, headers, APR X1, T56 Magnum 6 spd, NST pullies, Stptech Big Brake Kit, dropped, leather
    That looks like Flyfishers.
    imDementeD likes this.
  4. Aug 4, 2020 at 6:31 PM
    #64
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    It does. Guess we have an upsweep on ours
  5. Aug 7, 2020 at 2:48 PM
    #65
    Coupe
    James
    Houston, Texas
    I need to add to the list what type of hold down you have. It is either a straight version or an upswept version.
    0. Coupe, textured black with gloss white TRD - straight
    1. delz05, textured black with gloss red TRD - straight
    2. speedtre, satin/brushed aluminum with gloss red TRD - upswept
    3. empty_lord, textured black with gloss red TRD -straight
    4. imDementedD, textured black with gloss white TRD - straight
    5. flyfisher, satin/brushed aluminum with black TRD - upswept
    6. CodyP, textured black with gloss white TRD - upswept
    7. RR60, textured black with gloss white TRD - straight
    8. jImmegart, textured black with gloss white TRD - straight
    9. Tundra2, satin aluminum with NO TRD - straight
    Tundra2 likes this.
  6. Aug 7, 2020 at 2:57 PM
    #66
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Straight here
  7. Aug 7, 2020 at 4:21 PM
    #67
    imDementeD
    my 03 tundra side view with redtop.
  8. Aug 7, 2020 at 6:40 PM
    #68
    Coupe
    James
    Houston, Texas
    I am going to take some dimensions off the upswept model and we will figure out whether you need a straight or an upswept model. Or you can use the spacer under the optima and use a straight version.
  9. Aug 7, 2020 at 6:41 PM
    #69
    imDementeD
    Yea I'll do a straight and shim up as needed.
  10. Aug 10, 2020 at 6:10 AM
    #70
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Straight version for me... 05 Access Cab...
  11. Aug 10, 2020 at 7:54 AM
    #71
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    2003 tundra and mine is also straight
  12. Aug 14, 2020 at 7:23 PM
    #72
    Coupe
    James
    Houston, Texas
    Just an update.
    I am in the process of machining the straight ones and I am machining a prototype of the upswept model.
    flyfisher and empty_lord like this.
  13. Aug 14, 2020 at 8:26 PM
    #73
    Coupe
    James
    Houston, Texas
  14. Aug 19, 2020 at 2:36 PM
    #74
    Professional Hand Model
    Hand Protectors
    Couple of pics for everyone which have been posted in that link above. Sent to me free for feedback was a prototype basic Aluminum finish. I sprayed the TRD Red and then Clear Coated the entirety with Aluminum Wheel Clear Coat all of which is readily available from your corner auto parts store.
    The Hold Down Bracket is high quality and looks good. Stoked!
    empty_lord likes this.
  15. Aug 26, 2020 at 9:45 AM
    #75
    Coupe
    James
    Houston, Texas
    I am giving a little update.
    I have the straight models machined and ready to go to the powdercoater.
    I have asked the people with the straight versions for money. You can send me a deposit of $30 now and the balance of $65 when I am ready to ship. I expect to ship the straight versions in about 2 weeks.
    The up swept model is being machined this week. I still need to do a test fit before I can make a run. I expect this to happen pretty soon.
    Tundra2 and empty_lord like this.
  16. Aug 26, 2020 at 12:36 PM
    #76
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Thanks for the update and for staying after this project! Looking forward to the result.
  17. Sep 6, 2020 at 7:54 AM
    #77
    Coupe
    James
    Houston, Texas
    I have shipped most of the straight versions this week. In the kit, there is a round black spacer that goes under the front mount (if you need it). It depends on the height of your battery. If you have a tall battery, you may need to use this spacer. If not, then do not use it.
    I shipped these with a button head screw for the front mount (instead of a hex bolt). These have slightly lower head height.
    I also shipped these with a slight longer J bolt for the rear. This was to give you a little wiggle room for different height batteries. You need to check your hood clearance on the j-bolt length and the front mount, especially if you are using the black spacer under the front mount. DO NOT SLAM YOUR HOOD DOWN UNTIL YOU CHECK YOUR CLEARANCES.
    If you need to cut back the j-bolt, it is easily done with a hack saw.
    Tundra2 likes this.
  18. Sep 6, 2020 at 7:58 AM
    #78
    Coupe
    James
    Houston, Texas
    Here are a couple of pics of the upswept prototype.
    FirstGenVol, imDementeD and Tundra2 like this.
  19. Sep 7, 2020 at 12:28 PM
    #79
    delz05
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Installed and looks great! Thank you for taking the time!
  20. Sep 7, 2020 at 12:53 PM
    #80
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    Coupe does incredible work. Can't wait to get mine.
  21. Sep 7, 2020 at 1:26 PM
    #81
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    wait, I haven't paid anything yet I don't think have I? @Coupe
  22. Sep 7, 2020 at 1:27 PM
    #82
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    I have the upswept design. He hasn't asked for money yet on that design. I think he is still working it out, but it looks close to being done.
    CodyP likes this.
  23. Sep 10, 2020 at 5:23 PM
    #83
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    Thank you @Coupe ! No complaints, Only thing is I could not find an allen that fit the four on the bottom. All my hex are mixed though and I just used a wrench instead.
    imDementeD and Coupe[OP] like this.
  24. Sep 10, 2020 at 6:45 PM
    #84
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    Just received upswept design. Beautiful. Clever design, well made, and takes only a few minutes to install. Thanks coupe for making these available!8D3351B8-0D7A-42E6-8EB8-6FD712AFBD29.jpg7DED0443-E4D9-44C7-9E5D-9011CCD3A78D.jpg 521F34B9-A089-4BFA-9D28-C92C38D5B15C.jpg
  25. Sep 12, 2020 at 8:15 AM
    #85
    Coupe
    James
    Houston, Texas
    I am machining the rest of the upswept design this next week.
    When I am ready to go to the powdercoater I will ask for the money for the upswept versions.
    I made a few extra of the straight model for those of you that did not get in on the group buy.
    I have them in textured black with red TRD and raw aluminum.
  26. Sep 15, 2020 at 1:39 PM
    #86
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What year did they go to the upswept design?
  27. Sep 15, 2020 at 2:41 PM
    #87
    Coupe
    James
    Houston, Texas
    I believe that is only on the Double Cabs.
  28. Sep 15, 2020 at 5:22 PM
    #88
    empty_lord
    05 rollover special
    Pretty sure only double cabs. The core support is taller. That’s also why my radiator didn’t fit.... because it was for a double cab... 1” taller rad
  29. Sep 30, 2020 at 5:24 AM
    #89
    Coupe
    James
    Houston, Texas
    I am ready to take parts to the powdercoater for the Upswept model. I have pmed people on the list for the upswept model for money.
    I made a few extra, so if you did not get on the list and are interested in buying one, shoot me a PM.
    I also have a few extra of the straight version. I have these in raw aluminum and textured black with gloss red in stock.
  30. Oct 9, 2020 at 1:51 PM
    #90
    Coupe
    James
    Houston, Texas
    Besides having a few extra of the straight versions, I also have a few of the upswept version.
Thread Status:
