Cup Grip
Discussion in '3rd Gen Tundras (2022+)' started by shorenetworks, Apr 22, 2023.
  1. Apr 22, 2023 at 7:30 PM
    shorenetworks
    shorenetworks [OP] New Member
    East coast California DBA New Jersey
    2023 Tundra self destruct edition
    So in my 2023 Limited the cup holders are a bit of a joke my taller coffee cups want to tip over and out. I spotted this on EBay and ordered anyone have experience with it.?
    Chris.
    Descend likes this.
  2. Apr 22, 2023 at 10:54 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
  3. Apr 23, 2023 at 12:03 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Mine arrives Monday. Tired of the wife’s big ass cup bouncing all over the place…
  4. Apr 23, 2023 at 4:57 AM
    shorenetworks
    One big downside to that one on Amazon is it's a 3d printed part made from PLA a biodegradable plastic. The cup grip one looks to be injection molded so it should age better. Good find though,
  5. Apr 23, 2023 at 9:07 AM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    I had the Cup Grip for a short time in my Limited before trading up to a Platinum. It worked well at the time. It is held in by pressure which was concerning as it may work it's way back out. Like I said, short time experience with it.
  6. Apr 23, 2023 at 11:19 AM
    raylo
    raylo not so new member
    Frederick, MD
    My cups tip over in turns, too. What a PITA. I think I'll design my own one of these and 3D print it. Looks simple enough.
  7. Apr 23, 2023 at 6:34 PM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    I got it off of Etsy for $20 and love it. Works great, prevents my mug from tilting on turns
  8. May 6, 2023 at 6:42 AM
    raylo
    Frederick, MD
  9. May 6, 2023 at 7:02 AM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    raylo[QUOTED] likes this.
  10. May 6, 2023 at 7:20 AM
    TSS Army Green
    TSS Army Green New Member
  11. May 6, 2023 at 8:09 AM
    raylo
    Frederick, MD
    Sorry, not anytime soon. We don't use the rear cup holder and the necessary iterative design process is too much of a PITA and too time consuming to take on for "fun".
  12. May 6, 2023 at 8:15 AM
    TSS Army Green
    I understand
  13. May 6, 2023 at 2:03 PM
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    I'm going to print this in a little while (once my current print completes), and I'll see how it fits up in the rear cupholder and perhaps make a modified .stl file for the rear. Stay tuned (won't be likely until tomorrow).
  14. May 6, 2023 at 2:19 PM
    raylo
    Frederick, MD
    I just tried the printed piece in the rear cup holder and it doesn't fit perfect but it works. The printed spacer is a little too long in the long axis for the rear holder by maybe 5-7mm (I didn't measure) so it doesn't go all the way down. And the wings on the printed piece are a bit too wide for the rear protrusion in the cupholder. It goes over but will be a little loose fit.
    Bottom line is that it will work as is, but would fit a lot better if you would shorten the long axis by some % or mm in your slicer so the piece will insert all the way and bottom out in the holder. Would take trial and error to get it right. As for the wingspan not matching the rear protrusion in the holder, that would be more difficult to fix... would have to resize one end somehow or add some features to the design to close up the gaps... and really isn't necessary. The front fits snug and if you make it just snug in the long axis it will be plenty solid.
  15. May 7, 2023 at 3:01 PM
    SpackJarrow
    SpackJarrow New Member
    2023 Black Tundra 1794
    Anyone seen a cupgrip or equivalent that would work with 1794 edition?
  16. May 7, 2023 at 3:14 PM
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    Sweet, I've been looking for one of these so my cup holder expander would stay in place better.
  17. May 7, 2023 at 7:17 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    I've got the opposite problem: Nalgenes won't fit, which is ridiculous. I could fit 2 Nalgenes in the front cup holders in the 4Runner...
  18. May 8, 2023 at 6:49 AM
    nimbus
    nimbus New Member
    I ordered the cup grip and it arrived within a few days. It works as advertised and highly recommended.
  19. May 8, 2023 at 7:40 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Printed up the spacer as provided by raylo.
    Lol, a little overkill on my end in quality as I had CF ABS in the printer…
    Perfect, now my Yeti fits, sits nice and level, and stays right where it should.
    Thanks for sharing.
    raylo likes this.
  20. May 8, 2023 at 7:42 AM
    raylo
    Frederick, MD
    After testing my front cup spacer in the rear cupholder again it looks pretty close so I believe I can do this in just 1 or maybe 2 iterations. Draft printing test #1 now. This version is just a few mm shorter in length and a few mm taller than the original. I wonder if those commercially available ones might work in both holders, which would mean that the front one would fit a little loose. In any case check back here later today and I should have something for you.
    4genRunner likes this.
  21. May 8, 2023 at 8:00 AM
    War Machine
    War Machine SSEM # 5 3MW
    This one works in that spot on mine.
    https://www.etsy.com/listing/1395121849/
  22. May 8, 2023 at 9:38 AM
    roboots21
    I scaled the . STL down to 95% in Prusa Slicer and it fits perfectly in the back cupholder. Also printed I full size for the cupholder and attached photos of both.
  23. May 8, 2023 at 10:20 AM
    raylo
    Frederick, MD
    That's pretty much what I am doing but back in Tinkercad to make it shorter natively by 4mm... and I made it a little taller to come up higher on the rear of the cupholder. I'll post the link to that file when I am sure I have the scaling correct.
  24. May 8, 2023 at 1:44 PM
    raylo
    Frederick, MD
    OK, I just posted up the rear version at the same link. It may not appear there for a little while because sometime Thingiverse is slow to update saves. I made the rear one a few mm taller and I snugged up the wings in the back to eliminate the little bit of lateral movement when using the shortened front holder spacer in the rear holder. Not sure why Toyota made the rear holder with such small differences from the front one... but they did.
    2022+ Toyota Tundra cup holder spacer by raylo32 - Thingiverse
  25. May 8, 2023 at 2:22 PM
    TSS Army Green
    Thank you for doing this.
  26. May 8, 2023 at 2:36 PM
    raylo
    Frederick, MD
    No problem, the changes from the front piece were minimal and took me about 5 minutes to make. Enjoy! Remember, the rear one has a front and back. Should be pretty obvious.
  27. May 9, 2023 at 10:12 AM
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    I wish someone would make one of these that for a Platinum.
  28. May 9, 2023 at 10:13 AM
    raylo
    Frederick, MD
    Platinum has different cupholders?? How about posting a picture.
  29. May 9, 2023 at 10:30 AM
    Twin2turbo
    Pacific NW
    The cup holders are front to back instead of side by side. The space between them is also wider. 20230509_102742.jpg 20230509_102734.jpg
  30. May 9, 2023 at 10:32 AM
    raylo
    Frederick, MD
    Looks pretty much the same to me, just rotated 90 degrees. Try one and see.
