csuviper's Rock Warrior Build
Discussion in '2nd Gen Builds (2007-2013)' started by csuviper, Jan 6, 2014.
  1. Sep 22, 2017 at 10:04 AM
    #1171
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2012 Rock Warrior 5.7L 4X4
  2. Sep 22, 2017 at 12:50 PM
    #1172
    csuviper
    Broomfield, CO
  3. Sep 28, 2017 at 12:24 PM
    #1173
    csuviper
    Broomfield, CO
    Just ordered my black lugs from Wheelers. Went with the BLACK CHROME LUG NUTS, 14MM X 1.5, 13/16″ HEX
  4. Sep 28, 2017 at 12:25 PM
    #1174
    csuviper
    Broomfield, CO
    Also just ordered the McGard 24216 Chrome/Black Cone Seat Wheel Lock Set
  5. Oct 4, 2017 at 7:28 AM
    #1175
    csuviper
    Broomfield, CO
    Just completed my oil change and collected the sample for blackstone lab. Hoping for good results.
    TRD-ROCKWARRIOR likes this.
  6. Oct 4, 2017 at 7:38 AM
    #1176
    JC303
    JC303 Here so I won't get fined
    Justin
    2012 Tundra 5.7
    What does the blackstone lab test the oil for? I have never heard of this.
  7. Oct 4, 2017 at 7:52 AM
    #1177
    csuviper
    Broomfield, CO
    https://www.blackstone-labs.com/
    Oil analysis is a quick, nondestructive way to gauge the health of an engine by looking at what's in the oil. People use oil analysis for different reasons: to see if there are any problems developing, to see if their oil is working well in the engine, and to see if they can run longer oil changes.
    Spectral exam:
    In the spectral exam, we take a portion of your oil sample and run it through a machine called a spectrometer. The spectrometer analyzes the oil and tells us the levels of the various metals and additives that are present in the oil. This gives us a gauge of how much your engine is wearing. To learn more about the elements we look at and where they come from in your oil, go to our Report Explanation page.
    Insolubles test:
    The insolubles test measures the amount of abrasive solids that are present in the oil. The solids are formed by oil oxidation (when the oil breaks down due to the presence of oxygen, accelerated by heat) and blow-by past the rings. This test tells you how good a job the oil filter is doing, and to what extent the oil has oxidized.
    Viscosity test:
    The viscosity measures the grade, or thickness, of the oil. Whether it's supposed to be a 5W/30, 15W/40, or some other grade, we will know (within a range) what the viscosity should be. If your viscosity falls outside that range, there's probably a reason: the oil could have been overheated or contaminated with fuel, moisture, or coolant.
    Flash Point test:
    The Flash Point test measures the temperature at which vapors from the oil ignite. For any specific grade of oil, we know what temperature the oil should flash at. If it flashes at or above that level, the oil is not contaminated. If the oil flashes off lower than it should, then it's probably been contaminated with something. Fuel is the most common contaminant in oil.
  8. Oct 4, 2017 at 6:53 PM
    #1178
    csuviper
    Broomfield, CO
  9. Oct 5, 2017 at 6:10 PM
    #1179
    Thegr8punkin
    Thegr8punkin A God Damn Millenial
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
  10. Oct 9, 2017 at 8:37 AM
    #1180
    csuviper
    Broomfield, CO
    Rears installed. Fronts later this week
    SoCalDave, Sean266 and TheBeast like this.
  11. Oct 9, 2017 at 8:49 AM
    #1181
    TheBeast New Member
    2012 CM 4x4 TRD
    Kings, TC, Methods, Toyos R/T, StopTech
    I see a lonely bolt ready for a TRD sway bar :)
    TruckyTruck likes this.
  12. Oct 9, 2017 at 9:29 AM
    #1182
    csuviper
    Broomfield, CO
    Na, im happy with how the truck handles. Have alot of other stuff i would rather spend the money on.
    TheBeast and zcarpenter92 like this.
  13. Oct 12, 2017 at 9:03 AM
    #1183
    csuviper
    Broomfield, CO
    TheBeast likes this.
