csuviper's Rock Warrior Build (VENOM) - TRADED IN
Discussion in '2nd Gen Builds (2007-2013)' started by csuviper, Jan 6, 2014.
  1. Sep 6, 2016 at 9:04 AM
    #811
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Pics from my recent camping trip to Middle St. Vrain Trail in Lyons, CO.
    Some trail damage i endured.
  2. Sep 20, 2016 at 8:48 PM
    #812
    csuviper
    Broomfield, CO
    I gave in and will be adding the baja design fog lights.
    Medic likes this.
  3. Sep 20, 2016 at 8:51 PM
    #813
    csuviper
    Broomfield, CO
  4. Sep 21, 2016 at 4:45 AM
    #814
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Nice. Clear or yellow lenses?
  5. Sep 21, 2016 at 10:52 AM
    #815
    TheBeast The Beach
    time to get some of those new RCI armors.
    T-Rex266 likes this.
  6. Sep 21, 2016 at 1:53 PM
    #816
    olsin6
    olsin6 New Member Vendor
    Joey
    Mesa, AZ
    2010 White DCSB Tundra
    35" Toyo MT w/ 17" Method Standards Body Mount Chop SDHQ Sliders
    We have all the Baja Designs in stock! Good choice in going with Baja.
  7. Sep 21, 2016 at 8:15 PM
    #817
    csuviper
    Broomfield, CO
    Def considering. Think i need to start with the lowest part on the truck....rear diff.
    TheBeast[QUOTED] likes this.
  8. Sep 21, 2016 at 8:16 PM
    #818
    csuviper
    Broomfield, CO
    Clear lenses. Went with just the sport to save some money. Driving combo. 1,800 lumens instead of the 4,800 lumen ones you have.
    TruckyTruck[QUOTED] likes this.
  9. Sep 21, 2016 at 9:36 PM
    #819
    TruckyTruck
    Gary
    You may like that better... I definitely have to turn mine off with oncoming traffic. It would be nice to keep mine on, but I need the light. At 330 this morning, on the way to work, I saw 5 separate deer that I wouldn have seen without the light. I'd really like to keep my truck and myself from hitting one.
    2cID and NewImprovedRon like this.
  10. Sep 22, 2016 at 2:14 AM
    #820
    csuviper
    Broomfield, CO
    Do you have the squadron pro or squadron-R pro?
  11. Sep 22, 2016 at 8:00 PM
    #821
    TruckyTruck
    Gary
    The squadron pro
  12. Sep 26, 2016 at 2:25 PM
    #822
    csuviper
    Broomfield, CO
    Just picked up my @Baja Designs Squadron Sport lights and 07-13 Fog light brackets.
    Thank you @ToyTec Lifts for custom ordering the brackets and saving me shipping costs since your local.
    2cID, T-Rex266, aperezsh and 3 others like this.
  13. Sep 26, 2016 at 3:14 PM
    #823
    TruckyTruck
    Gary
    Brian, I had to reverse the wiring polarity in the plugs for the adapter on one end for both adapters. I hooked them up and they didn't work. Got my multimeter out and saw I was getting power from the wiring, so I switched the word and they worked. I let Baja know and he said they would pass it to the supplier. So if yours don't fire up after you install them, that's why.
    T-Rex266, TheBeast and NewImprovedRon like this.
  14. Sep 27, 2016 at 7:55 PM
    #824
    csuviper
    Broomfield, CO
    Installed one
    Before
    After
    TruckyTruck, TheBeast and T-Rex266 like this.
  15. Sep 27, 2016 at 10:37 PM
    #825
    csuviper
    Broomfield, CO
    Yep I had to reverse the polarity on the plugs as well.
  16. Sep 27, 2016 at 10:38 PM
    #826
    csuviper
    Broomfield, CO
    Here is the comparison of stock vs BD Squadren Sport.
    TruckyTruck likes this.
  17. Sep 27, 2016 at 10:39 PM
    #827
    csuviper
    Broomfield, CO
    Just headlights on
    BD and headlights. What you don't see in this pic is there are houses in the background that the lights reached. This pic is deceiving because it almost appears that it has less light around. What it really did was add a lot more light straight out in front with the spot lights.
    TruckyTruck and olsin6 like this.
  18. Sep 28, 2016 at 7:25 AM
    #828
    TruckyTruck
    Gary
    That match your headlights perfectly!
  19. Sep 28, 2016 at 9:08 AM
    #829
    TheBeast The Beach
    they are nice. I'm gonna put them on my list. plug and play right ?
  20. Sep 28, 2016 at 9:22 AM
    #830
    csuviper
    Broomfield, CO
    Yes they are plug and play.
    Sledmonster likes this.
  21. Sep 28, 2016 at 9:24 AM
    #831
    csuviper
    Broomfield, CO
    They throw out so much light even for being the lower lumen ones. I really dont think i can drive with them on like i was hoping to with oncoming traffic.
    Definable wont be able to with the pros @TruckyTruck
  22. Sep 28, 2016 at 1:05 PM
    #832
    TruckyTruck
    Gary
    Think pointing the down a little would help?
  23. Sep 28, 2016 at 1:17 PM
    #833
    csuviper
    Broomfield, CO
    They are pointed down as much as they would allow. Its just how they throw the light.
  24. Nov 22, 2016 at 7:01 PM
    #834
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    hey brian,are those fog lights bright enough to drive with only them on,no headlights? is the flood pattern/spot pattern good. i'm thinking of maybe getting the sport in the yellow lense
  25. Nov 22, 2016 at 9:26 PM
    #835
    swede78
    Lars
    westminster co
    Nothing yet
    can you turn the light 180 so the spot beam is on the bottom,not sure if that would change the beam pattern
  26. Dec 24, 2016 at 10:37 PM
    #836
    csuviper
    Broomfield, CO
    Sorry for not responding on this in a timely manner.
    They are too bright with the driving combo. I am going to try the wide cornering lenses to cut the height of the pattern down a bit to see if it will help not blind others.
    Great lights. They are bright.
  27. Dec 24, 2016 at 10:37 PM
    #837
    csuviper
    Broomfield, CO
    Never thought of that but the light goes way up so a few inches down probably wont do anything.
  28. Dec 25, 2016 at 2:00 AM
    #838
    swede78
    Lars
    westminster co
    Nothing yet
    let me know what you think of the wide cornering lenses, i'm thinking about those in the yellow
  29. Jan 8, 2017 at 9:23 PM
    #839
    csuviper
    Broomfield, CO
    Ordered and they are ready, just haven't picked them up yet. Will let you know.
  30. Jan 8, 2017 at 9:30 PM
    #840
    csuviper
    Broomfield, CO
    Purchased the NorthStar Ultra High Performance AGM 27F Battery from gpcaraudio.com. Will receive it next Tuesday or Wednesday.
