csuviper's Rock Warrior Build (VENOM) - TRADED IN
Discussion in '2nd Gen Builds (2007-2013)' started by csuviper, Jan 6, 2014.
  1. Dec 25, 2015 at 5:10 PM
    #571
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  2. Dec 26, 2015 at 12:04 PM
    #572
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    When you installed the Hypertech Speedo Calibrator did you have to disconnect/reconnect battery?
  3. Dec 26, 2015 at 1:51 PM
    #573
    csuviper
    Broomfield, CO
    some say you should but i did not.
  4. Dec 26, 2015 at 4:57 PM
    #574
    csuviper
    Broomfield, CO
  5. Dec 27, 2015 at 5:58 PM
    #575
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Were your headlights made from Toyota housings or are they aftermarket? If aftermarket are you happy with the quality? Hid's high and low beam? You happy with them? Anything you would do different? Sorry for the question bomb but think this is gonna be my next project.
  6. Dec 27, 2015 at 6:30 PM
    #576
    csuviper
    Broomfield, CO
    I got the headlights from @Sean266. He had them laying around after he traded in his 2nd gen. He had problems with them from the start. Halo went out and I think other items. I could be wrong but I thought he returned the first set he got. The brand is Eagle Eyes. The link is in the OP.
    I fixed some wiring to get the halo to work again. Haven't had any issues so far. They are CFL and are bright. Can be seen during the day. Heard the led version are dim and can't be seen at night.
    I have the stock halogens in the high beams.
    No complaints. Don't use high beams much.
    I have the 35 watt DDM tuning HIDs in the low beams. Had one bulb that was in there from Sean go out recently. Purchased new bulb but haven't replaced yet.
    The low beams have a projector but it is low quality. Nothing like the true projectors that retrofit source sells. I think the brightness of the bulbs are cut down a bit from the low quality lense.
    Overall I like them. Time will tell how the hold up.
  7. Dec 28, 2015 at 2:00 PM
    #577
    csuviper
    Broomfield, CO
    Well it wasn't the hid bulb that went out. It was actually the error eliminator. Don't need it though. No errors without it.
  8. Dec 30, 2015 at 10:12 AM
    #578
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    How is the swing case working out? Do you happen to know the weight rating. I have been looking for something to keep things organized. Thanks
  9. Jan 2, 2016 at 9:55 PM
    #579
    csuviper
    Broomfield, CO
    Haven't had time to mess with it, just to install. Currently empty. It will get filled soon and then I will let you know.
  10. Jan 2, 2016 at 9:59 PM
    #580
    csuviper
    Broomfield, CO
    Received the map light switches I ordered on Amazon. Not much info on them but decided to order anyway in hopes they fit.
  11. Jan 3, 2016 at 10:02 AM
    #581
    csuviper
    Broomfield, CO
    Received the Amazon switch too.
  12. Jan 3, 2016 at 10:03 AM
    #582
    csuviper
    Broomfield, CO
    Fits perfect
    TruckyTruck likes this.
  13. Jan 3, 2016 at 10:10 AM
    #583
    Weldcar
    Weldcar New Member
    2013 rock warrior
    I like how the tires look with the spacers.
  14. Jan 8, 2016 at 6:57 AM
    #584
    csuviper
    Broomfield, CO
    These switch's worked. :woot:
    Existing switch is on the left, new on is on the right. Worked just fine when plugged in.
    Medic likes this.
  15. Jan 8, 2016 at 8:31 AM
    #585
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Nice, like it when things go smoothly and work out on the first attempt.
  16. Jan 27, 2016 at 3:45 PM
    #586
    GTABurnout
    GTABurnout New Member
    How much was the switch. The Air on Board switches are going to kill me.
  17. Jan 27, 2016 at 8:27 PM
    #587
    csuviper
    Broomfield, CO
    19.99 on Amazon, free shipping
    AOB ones are 28 + shipping.
  18. Jan 28, 2016 at 7:36 AM
    #588
    csuviper
    Broomfield, CO
  19. Jan 28, 2016 at 7:37 AM
    #589
    csuviper
    Broomfield, CO
  20. Jan 31, 2016 at 3:58 PM
    #590
    csuviper
    Broomfield, CO
    Installed 800 lumen LEDs in the bed bed/Cargo light.
    So much brighter.
  21. Jan 31, 2016 at 4:15 PM
    #591
    Virgils12
  22. Jan 31, 2016 at 4:36 PM
    #592
    csuviper
    Broomfield, CO
  23. Feb 1, 2016 at 2:56 PM
    #593
    csuviper
    Broomfield, CO
  24. Feb 4, 2016 at 7:36 AM
    #594
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Love the snow pics!
  25. Feb 4, 2016 at 4:44 PM
    #595
    csuviper
    Broomfield, CO
    Thanks Patrick
  26. Feb 14, 2016 at 11:08 AM
    #596
    csuviper
    Broomfield, CO
    Look what the wife got me for Valentine's Day.
    She knows I miss my Tacoma....
    but love my tundra
  27. Feb 14, 2016 at 11:34 AM
    #597
    applesquirel
    applesquirel New Member
    james
    Clarksville Tn
    2012 platinum tundra!!!
    none yet
    i just found this build man and its amazing!!! i have read every post and looked at almost all the mod links lol. i have nothing better to do so figured might as well! keep up the good work!
    zcarpenter92 likes this.
  28. Feb 14, 2016 at 11:52 AM
    #598
    csuviper
    Broomfield, CO
    Thank you James
  29. Feb 14, 2016 at 9:34 PM
    #599
    csuviper
    Broomfield, CO
    Ok guys what are your thoughts on adding a gunmetal grey hood vinyl in the groove on the hood. The color would match my wheels. Thinking is a real possibility.
  30. Feb 15, 2016 at 8:00 AM
    #600
    Medic
    Medic New Member
    Ontario, Canada
    Go for it, I think it would look great.
