csuviper's Rock Warrior Build (VENOM) - TRADED IN
Discussion in '2nd Gen Builds (2007-2013)' started by csuviper, Jan 6, 2014.
  1. Aug 30, 2015 at 6:52 PM
    #421
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    That's good to know. I installed on my 07 Tacoma and it was a pain in the ass to remove the long bolt. No room to just pull it out.
  2. Aug 30, 2015 at 6:56 PM
    #422
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    You just have to remove the battery on the drivers side and move wire bundles around on both sides, but easy to do. You probably already know, but just in case, after you unbolt the spindle bolt to the uca, just whack the spindle arm with a hammer a couple times and the ball joint will separate easily on its own.
  3. Aug 30, 2015 at 7:07 PM
    #423
    csuviper
    Broomfield, CO
    Yep, did that plenty of times on the Tacoma :)
    TruckyTruck likes this.
  4. Aug 30, 2015 at 7:29 PM
    #424
    csuviper
    Broomfield, CO
    Good to know about the battery removal, thank you.
  5. Aug 30, 2015 at 7:42 PM
    #425
    TruckyTruck
    Gary
    Do you still have the hypertech programmer plugged in?
  6. Aug 30, 2015 at 7:47 PM
    #426
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Lmk when u want it aligned ;)
  7. Aug 30, 2015 at 7:51 PM
    #427
    csuviper
    Broomfield, CO
    Yes. No codes for a while.
    I will be taking it to you for sure.
    TruckyTruck[QUOTED] likes this.
  8. Aug 30, 2015 at 7:51 PM
    #428
    TruckyTruck
    Gary
    I keep meaning to give my opinion on this... So I think you should leave them one color, either silver or all black. Not so much because of the color itself, but rather how it makes your rim to tire ratio look. With the silver wheel and black ring, it makes the rim look tiny and like you are running huge tires. I like a big tire, but the rim should look proportionate. Just my opinion though. I love your truck and it will look bad ass no matter what you do there.
  9. Aug 30, 2015 at 7:54 PM
    #429
    TruckyTruck
    Gary
    That's good man! Do you run it without the throttle module? My mpg took a nice hit from installing 35s... I'm considering another tuner for my next purchase. Guess I shouldn't have sold it!
  10. Aug 30, 2015 at 7:55 PM
    #430
    csuviper
    Broomfield, CO
    I had someone ask if I had 12" wheels on there one time. Thats why I have been thinking about taking the rings off for a bigger wheel look. Almost want to buy 18s or 20s but lack of funds at the moment are keeping me from it. Eventually I will and eliminate the wheel spacers in the process.
  11. Aug 30, 2015 at 7:56 PM
    #431
    csuviper
    Broomfield, CO
    Yes without it.
  12. Aug 30, 2015 at 8:25 PM
    #432
    TruckyTruck
    Gary
    Well I really like the look of those wheels, but if you decide to sell, I'm sure you can recoup quite a bit of the cost of new ones.
  13. Sep 2, 2015 at 3:16 PM
    #433
    csuviper
    Broomfield, CO
    T-Rex266 likes this.
  14. Sep 2, 2015 at 5:17 PM
    #434
    csuviper
    Broomfield, CO
    Great condition
  15. Sep 2, 2015 at 6:17 PM
    #435
    csuviper
    Broomfield, CO
    Installed in ~20-30 min because I had to remove my ammo box and front unistrut rail. Rail just needs to be shortened and then I can reinstall. Easy install. Looks awesome.
    Will try to find a home for the ammo box. Might have to be on the floor of the bed.
    Now I know what to do with the light @Sean266 gave me.
  16. Sep 5, 2015 at 7:35 PM
    #436
    csuviper
    Broomfield, CO
    Doing a little touch up
  17. Sep 5, 2015 at 7:44 PM
    #437
    I was hoping @csuviper would donate them to me for my new lift. Oh well..........
  18. Sep 5, 2015 at 7:44 PM
    #438
    csuviper
    Broomfield, CO
    Lol, no way
  19. Sep 5, 2015 at 7:51 PM
    #439
    How hard it is it to install the ToyTec Diff drop? Can't be to difficult. Don't want to hijack thread.
  20. Sep 5, 2015 at 10:05 PM
    #440
    csuviper
    Broomfield, CO
    Easy. Not much to it.
  21. Sep 5, 2015 at 10:07 PM
    #441
    Basically removing existing bolts an inserting spacers and using the longer bolts to proper torque (whatever that is)?
  22. Sep 5, 2015 at 10:09 PM
    #442
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    When I installed mine, the only difficult part was getting the nuts started. Very tight place and little room .
    Black Wolf likes this.
  23. Sep 5, 2015 at 10:10 PM
    #443
    csuviper
    Broomfield, CO
    Yep
  24. Sep 5, 2015 at 10:19 PM
    #444
    That's good to know. At least I won't be surprised. Very tight and a little room isn't always a bad thing, heh heh
  25. Sep 5, 2015 at 10:40 PM
    #445
    Giggity giggity.
  26. Sep 8, 2015 at 6:47 PM
    #446
    csuviper
    Broomfield, CO
    Decent pic from the other day
    Black Wolf and T-Rex266 like this.
  27. Sep 8, 2015 at 7:59 PM
    #447
    You have the BAM's right?
  28. Sep 8, 2015 at 8:08 PM
    #448
    csuviper
    Broomfield, CO
    BA Muffler, yes. 6"
  29. Sep 8, 2015 at 8:11 PM
    #449
    Clearly, I'm still thinking about my exhaust. I need to hear yours up close. Maybe when I get my OME goodies installed at Insain you can accidentally show up along with Sean. 1 or 2 weeks wait I guess.
  30. Sep 8, 2015 at 8:12 PM
    #450
    csuviper
    Broomfield, CO
    I'm sure we can plan something. Need to get insain to do my cab mount chop.
