Cryo rotors/TRD brake kit worth it?
Discussion in 'Towing & Hauling' started by running214, Jun 20, 2023.
  1. Jul 11, 2023 at 8:36 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    all you need is to find a panel that pops out, run the wire and double sided tape it to the location.
    nasher75 likes this.
  2. Jul 11, 2023 at 11:06 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I didn’t catch what year your truck is, but this is a nice way to install an aftermarket Tekonsha P3 in a Tundra.
    ESP Truck Accessories TP3MNT Brake Controller Dashboard Mounting Kit for Tekonsha P3 Brake Controller in 2014-2019 Toyota Tundra Pickup Truck Models https://www.amazon.com/dp/B06XJNCMZC
    Tekonsha 90195 P3 Electronic Brake Control , silver, Single https://a.co/d/aWwbZkc
    Tekonsha Trailer Brake Controller Harness, Compatible with Select Toyota Tacoma, Tundra https://www.amazon.com/dp/B0781KTCPT
    https://youtu.be/wjAJcICxem4
    In my opinion, you’ll be pretty hard pressed to find a nicer controller that is this simple to use. It’s been around for a long time and is still at the top of the game.
    MedCityMoto likes this.
  3. Jul 12, 2023 at 5:02 AM
    Saab95v6
    Saab95v6 New Member
    I have a 2020 Platinum with 20k miles , I don't tow and travel mostly flat roads daily and my front brakes shimmy a (crazy) lot during normal braking , I think I need to put new rotors and brake pads with SS brake lines ,
    I would love to install a BBK , but I don't think they make it for my model year .
  4. Jul 12, 2023 at 6:42 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    They absolutely do make kits for you. Anything from what, 2007-2021 is all cross-compatible. But you're going to drop a minimum of $3500 on the setup and then install, if you elect to have a shop do the work.
  5. Jul 12, 2023 at 7:50 AM
    Saab95v6
    Saab95v6 New Member
    I just called Keith @dirtydeeds and ordered his deal 4 Frozen rotors and EBC Yellow pads , plus I don't mind giving small business and a member here my money !!!
  6. Jul 12, 2023 at 1:01 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    When I ordered my Alcon BBK, they needed to know if it was pre or post 2014. Sounds like a set of fasteners may have changed size, but the rest was samesies.
    But yeah. A BBK is available all the way to 2021 fer sure.
    MedCityMoto[QUOTED] likes this.
  7. Jul 15, 2023 at 11:05 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Chad did you get the full alcon front and rear...or just the front
  8. Jul 15, 2023 at 3:34 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Full meal deal, my man. This mod is as beneficial as new gears. Maybe better…
    I did briefly consider fronts only, but I tow a lot. Recent investigation has also revealed that my truck is a fat pig and overweight. That said, it stops on a dime.
  9. Jul 15, 2023 at 4:04 PM
    19PlatinumCrew
    Dave
    Did you buy direct from Alcon or do you have a inside source...juice worth the squeez....yea my girl is heavy and I also tow a 6800 lb travel trailer. Planning an Alaska trip in a couple years would like better better brakes, I know you get what you pay for but that's serious coin
  10. Jul 15, 2023 at 5:29 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Direct from Alcon. Shoot me a PM and I’ll forward Chris’s contact info. I did receive a discount for being a firefighter, not sure if you may qualify for any price breaks.
    They’re expensive as all get out, but that’s a short time problem to a long time solution.
  11. Dec 9, 2024 at 6:01 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Never buy drilled rotors. Looking cool is not helping braking robustness. They just promote cracking even on high performance applications... I'm not even convinced 95% of us need slotted rotors. I'm a believer in cryo treated rotors on our big heavy trucks.
