Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. May 7, 2021 at 7:47 AM
    #211
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    What a badass build. 39's look right at home.
    Cruzer[OP] likes this.
  2. May 7, 2021 at 8:01 AM
    #212
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
  3. May 7, 2021 at 9:29 AM
    #213
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Cruz did I just see if you in this parking lot ?
  4. May 7, 2021 at 9:55 AM
    #214
    Sunnier
    Sunny
    San Diego, CA
    Must be over at @dcsleeper408 ‘s for a little trim.
    TheBeast and dcsleeper408 like this.
  5. May 7, 2021 at 10:33 AM
    #215
    Cruzer
    Cruz
    Sunnyvale, CA
  6. May 8, 2021 at 4:13 PM
    #216
    Cruzer
    Cruz
    Sunnyvale, CA
    Yet another interesting thing about the 39s:
    With the HP Tuner you can adjust the tire radius and enter your gear ratio so that that the speedometer displays the correct speed. When I had the 37” Yokohama X-MTs I used the radius of a 37” tire and the speedo was spot on with my GPS. Which was a surprise because most tires are typically a 1/2 inch smaller than what they claim it to be. With the 39” KM3 I had to enter the radius of a 38” tire to get the speedo correct. So it makes me think is it really a 38” tire? And if it is then any dreams for an easy upgrade to a proper 40” tire (39.5” actual) just went up in flames :(
    831Tun and SC_TRD like this.
  7. May 8, 2021 at 4:29 PM
    #217
    Vizsla
    Vizsla 2 = 2.5
    The guy that makes/owns HP Tuning says that it will not correct the speedometer. Mines definitely off a little, but maybe something changed. Would use the actual tire diameter from BFG for tuning.
    https://forum.hptuners.com/showthread.php?78762-Tundra-speedometer-calibration
  8. May 8, 2021 at 4:41 PM
    #218
    Cruzer
    Cruz
    Sunnyvale, CA
    Interesting read. I must be tripping then cuz I test drove it earlier and the speed matched up with my GPS. I better put my glasses on and try again :rofl: these old eyes are jacked.
    831Tun likes this.
  9. May 8, 2021 at 4:58 PM
    #219
    Trdwillie14
    Billy
    2014 trd off road
    That being said you may wanna see the actual size I know the km3 is not a true 37 it’s like a 36 . 6 or something but I hate bf the company so I don’t buy their product lol
  10. May 10, 2021 at 8:00 AM
    #220
    Cruzer
    Cruz
    Sunnyvale, CA
    Put my glasses on a looks like you were correct. I changed the tire radius for 37" and the speedo is still 3mph off. I'm feeling better already. Guess I'll use my speed calibrator since it's already installed.
    Rica25 and Sunnier like this.
  11. May 10, 2021 at 11:06 AM
    #221
    Cruzer
    Cruz
    Sunnyvale, CA
    Damn it! I took the passenger side CV axle off and guess what? I thought it broke because the tire no longer spins, even with lockers on, but it appears to be fine :annoyed:
    Anyone have an idea why I can only go in 3 wheel drive? ABS sensor and wire are intact and appear fine. I don't hear any clunking or grinding sounds from the diff. Taking it to the shop where I got my diffs done is my last option.
  12. May 10, 2021 at 11:18 AM
    #222
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sorry, can't "like" your post. The only thing I can think of is damage to the diff. Splines on the CV are still good?
  13. May 10, 2021 at 11:20 AM
    #223
    Cruzer
    Cruz
    Sunnyvale, CA
    Yeah splines were good. Didn’t see any loose pieces of metal.
  14. May 14, 2021 at 1:47 PM
    #224
    Cruzer
    Cruz
    Sunnyvale, CA
    I now have a theory of what's wrong with my front diff - I am thinking that my differential clutch sleeve may have broke. The (ADD) actuator is still attached to the clutch sleeve and is able to slide it back and forth making it think that it can go in to 4wd but it's not really connecting the shaft together.
    This video of a Tundra drivetrain helped me out a lot in understanding how the front diff works. Now I just need to figure out how to take the diff apart to take a look, fix, and put it back together :sawzall:
    This thin sleeve is what keeps the passenger side wheel in gear, so to speak. It's clearly the weakest link on the passenger side.
    https://www.youtube.com/watch?v=47m7QAPrpsI
  15. May 14, 2021 at 7:42 PM
    #225
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Funny, I was wondering earlier how you were making out with this issue. So, I started looking at videos of front diffs. Unfortunately didn't get far before I had to go to work. I look forward to watching the one you posted.
  16. May 15, 2021 at 8:26 AM
    #226
    Yzed608
    Yzed608 New Member
    Wisconsin
    That's a cool video, I think it should almost be put in a sticky somewhere just for info.
    Cruzer[QUOTED][OP] and Rica25 like this.
  17. May 15, 2021 at 12:30 PM
    #227
    Cruzer
    Cruz
    Sunnyvale, CA
    Brake time.
  18. May 16, 2021 at 3:44 PM
    #228
    Cruzer
    Cruz
    Sunnyvale, CA
    Took the front diff actuator off to take a peek at the clutch sleeve and to my dismay it was intact. I was able to slide the sleeve with my finger, engage the shaft, rotate the passenger side axle, and see the shaft and sleeve rotate, which means the problem is now somewhere with the gears. Messing with gears is beyond my comfort level so now I really have to take it to the shop :(
    831Tun and Trdwillie14 like this.
  19. May 16, 2021 at 3:55 PM
    #229
    Trdwillie14
    Billy
    2014 trd off road
    You see my gear fear lol
    Cruzer[QUOTED][OP] likes this.
  20. May 16, 2021 at 4:17 PM
    #230
    Cruzer
    Cruz
    Sunnyvale, CA
    I'm thinking of picking up a front diff at the junk yard and practice taking that one apart.
  21. May 16, 2021 at 4:49 PM
    #231
    Cruzer
    Cruz
    Sunnyvale, CA
    Found one in Rancho Cordova and purchased it for $217!
    Sunnier, Rica25 and Trdwillie14 like this.
  22. May 24, 2021 at 8:55 AM
    #232
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    It looks like the crossmember bracket is contacting with the brake lines - have you had any issues with this? (Did you just bend the lines back to give clearance?)
    831Tun and Rica25 like this.
  23. May 24, 2021 at 9:53 AM
    #233
    Cruzer
    Cruz
    Sunnyvale, CA
    From that angle they look like they touch but they don’t. It’s really close though so I just pushed the lines in just a little just now.
    831Tun likes this.
  24. May 24, 2021 at 10:04 AM
    #234
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Thanks, Cruz - this is very helpful. (Placing my order with ButBuilt today. :yes:
  25. May 24, 2021 at 1:19 PM
    #235
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    How they workin’?
  26. May 24, 2021 at 1:32 PM
    #236
    Cruzer
    Cruz
    Sunnyvale, CA
    The front brakes work great! Just the other day I had to stomp on the brakes while going 60mph and the first thing that popped into my head was "holy shit these brakes work good!" I'm very happy with them.
  27. May 24, 2021 at 1:57 PM
    #237
    Hightide
    Abalama
    Magic School Bus
    :thumbsup:
    They’ll make you grin when needed.
    831Tun, Sunnier and Rica25 like this.
  28. May 25, 2021 at 7:42 PM
    #238
    Cruzer
    Cruz
    Sunnyvale, CA
    :sadviolin:Monday morning I dropped the truck off at the shop to see what's going on with the front diff. It's already the end of day today and they haven't even started. The waiting around is killing me and might even mess up my road trip next week :mad: This will be the last time I take my front or rear diffs to the shop for repair.
    Hightide and Rica25 like this.
  29. May 25, 2021 at 7:53 PM
    #239
    Rica25
    Ricardo
    Tulare
    Did all this start after re gearing?
  30. May 25, 2021 at 8:27 PM
    #240
    Cruzer
    Cruz
    Sunnyvale, CA
    It started when I slapped on 39s :rofl:
    831Tun, Sunnier and Rica25[QUOTED] like this.
