Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Mar 26, 2022 at 11:41 PM
    #721
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    2 wrongs don't make a right but 3 lefts do. :monocle:
  2. Mar 27, 2022 at 5:45 AM
    #722
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Wow that’s small. Is it possible to swap a 2nd gen diff? Rear too?
    des2mtn[QUOTED] likes this.
  3. Mar 27, 2022 at 6:38 AM
    #723
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    It's the same diff as Tacomas and 4Runners of the same vintage. It's pretty tight up there, so it would require some modifications to the frame to make a bigger diff work.
    The rear diff is an 8.4" but its not as weak. Plenty of testimonials of those running lockers without issue. You could swap a full 2nd gen axle and you'd also gain disc brakes, but then you need to redo shock mounts find a way to overcome the whole 5-lug vs 6-lug deal. The disc brakes on a 2nd gen axle might need some master cylinder work to play properly on a 1st gen as well.
  4. Mar 28, 2022 at 8:44 AM
    #724
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    That was exactly my point. When keeping ifs we are stuck with a platform with a few key weaknesses that simply cant be upgraded like the front diff. I was being told not to underestimate what 1st gens can do when I, just on 35s, have grenaded 3 front diffs not even with a locker. So for the kind of wheeling that Cruzer and I like to do 1st gen ifs just won't cut it. Wheras 2nd gen+ ifs has enough strength in those key components to be made work, with the right aftermarket support.
    snivilous, tundra_20 and eccracer104 like this.
  5. Mar 28, 2022 at 8:17 PM
    #725
    Cruzer
    Cruz
    Sunnyvale, CA
    It's been disheartening searching for an RCSB in good condition and reasonably priced. A lot of the ones I have found are from the rust belt.
    I then came across the SDHQ RCSB, which was an RCLB that they converted.
    :monocle: Got me thinking that I should buy a white 2014-15 RCLB (I believe 2015 is when they stopped making regular cabs) and shorten it myself :yes: This way I can restore my CM back to stock form by trading the suspension, front fenders, axles, bumpers, and wheels. The only thing I would have to buy is another 5.5' bed to put on the CM.
    How hard can it be to :sawzall: the frame and :welder::monocle: Would need to run new hard brake lines. New drive shaft. Maybe shorter e-brake cable?
  6. Mar 28, 2022 at 9:26 PM
    #726
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    I like everything about this! :popcorn:
  7. Apr 8, 2022 at 1:28 PM
    #727
    Cruzer
    Cruz
    Sunnyvale, CA
    Messing around today. My first iteration of dual slide out solar panels. Well, one for now, as I mock things up. Will tuck it up closer to the bottom of the rack.
    reywcms, saybng, pvn.beluga and 10 others like this.
  8. Apr 8, 2022 at 10:34 PM
    #728
    SAGE63
    San Diego County
    That looks great Cruz
    des2mtn likes this.
  9. Apr 15, 2022 at 1:53 PM
    #729
    Cruzer
    Cruz
    Sunnyvale, CA
    Got this done. Lunch time and on to the next.
  10. Apr 15, 2022 at 2:33 PM
    #730
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    What tire mount is that Cruz??
    eccracer104 likes this.
  11. Apr 15, 2022 at 2:44 PM
    #731
    Cruzer
    Cruz
    Sunnyvale, CA
    That’s the ADD mount. Supports up to 40x13.50 wheels.
  12. Apr 15, 2022 at 5:36 PM
    #732
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Damn that thing looks extremely beefy.
  13. Apr 15, 2022 at 7:23 PM
    #733
    Cruzer
    Cruz
    Sunnyvale, CA
    And it’s heavy AF!
    SAGE63 likes this.
  14. Apr 15, 2022 at 7:31 PM
    #734
    SAGE63
    San Diego County
    less weight available for beer in the fridge
  15. Apr 15, 2022 at 7:34 PM
    #735
    eccracer104
    San Diego, CA
    Blasphemy! :drunk:
    Cruzer[OP] and SAGE63[QUOTED] like this.
  16. Apr 15, 2022 at 7:52 PM
    #736
    Cruzer
    Cruz
    Sunnyvale, CA
    I’ll put beer in the spare tire if I have to :rofl:
  17. Apr 15, 2022 at 7:58 PM
    #737
    SAGE63
    San Diego County
    Cruz when are you leaving for T2S. I am heading out next Saturday.
    Cruzer[OP] and FrenchToasty like this.
  18. Apr 16, 2022 at 6:54 AM
    #738
    Cruzer
    Cruz
    Sunnyvale, CA
    Damnnn that’s hella early! I’m planning to get there on Wednesday. Just not sure what time exactly. It’d be nice if I can get there in the morning or by noonish to try and catch a trail run.
  19. Apr 16, 2022 at 7:36 AM
    #739
    SAGE63
    San Diego County
    Yeah taking the week off work... and plan to go on the trail leaders pre-runs....
    helidave and Cruzer[OP] like this.
  20. Apr 16, 2022 at 7:53 AM
    #740
    Cruzer
    Cruz
    Sunnyvale, CA
    Nice! I was going to suggest that you trail lead.
    SAGE63[QUOTED] likes this.
  21. Apr 17, 2022 at 6:37 PM
    #741
    Cruzer
    Cruz
    Sunnyvale, CA
    So the :ballchain: sees the tire inside the truck.
    Is that tire dirty?
    Yes.
    Are you going to wash it?
    No.
    Why not?
    Cuz it’s a spare tire. Who washes spare tires?
    You do if you want to go off-roading.
    saybng, pvn.beluga, Wes_heppy and 9 others like this.
  22. Apr 17, 2022 at 7:40 PM
    #742
    eccracer104
    San Diego, CA
  23. Apr 27, 2022 at 4:31 AM
    #743
    Cruzer
    Cruz
    Sunnyvale, CA
    After 9 months or so of waiting I finally got my new plate. So if you saw this truck somewhere and weren’t sure it was mine, now you know :D
    TexasTundra27, TG705, des2mtn and 3 others like this.
  24. Apr 27, 2022 at 8:44 AM
    #744
    des2mtn
    SW
    Tonto cover
    Whale NFL Size
    eccracer104 and Cruzer[OP] like this.
  25. Apr 27, 2022 at 9:31 AM
    #745
    Cruzer
    Cruz
    Sunnyvale, CA
    :monocle::rofl:
    des2mtn[QUOTED] and eccracer104 like this.
  26. May 1, 2022 at 6:29 PM
    #746
    Cruzer
    Cruz
    Sunnyvale, CA
    Just made it home from another smashingly successful T2S event. I smashed my travel time making it home in under 11 hours.
    I got to trail lead Smasher Canyon. It was just me + 1 brave soul with lockers and 37s. The trail description I wrote down for Smasher Canyon was “lockers required, at least 37s, body damage likely.” Smasher Canyon lived up to its name and smashed my passenger bed side. The other truck had his bumpers smashed and ripped as well. It took us 4 hours to cover 4 miles. Thanks to @Papa Smurf for helping us fix both of our trucks.
    On a fun note I won a raffle prize: a set of 5 wheels furnished by Off Road Warehouse and a set of Kanati tires (unfortunately they only make up to 37” tires so I will soon be posting them for sale).
  27. May 1, 2022 at 6:49 PM
    #747
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Ouch!!!
    Well, at least when you sell the wheel/tire combo, it’ll be more funds !
    Are they going to be 17s?
    Cruzer[QUOTED][OP] likes this.
  28. May 1, 2022 at 6:50 PM
    #748
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
  29. May 1, 2022 at 6:52 PM
    #749
    Cruzer
    Cruz
    Sunnyvale, CA
    Yes. Keeping the wheels and I might actually keep the tires…..I just looked online and Kanati makes 39x12.50r17, not 40s but I guess I can use them as my street tires and put on my 40s only when I wheel.
  30. May 1, 2022 at 6:53 PM
    #750
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    You did just drop a bunch of dough on the new 40s!
