Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Dec 23, 2021 at 10:28 AM
    #571
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Lol I’m good. I can now max out my Baofeng at 8 watts :D
    Sunnier likes this.
  2. Jan 3, 2022 at 4:08 PM
    #572
    Cruzer
    Cruz
    Sunnyvale, CA
    Installed my new Alcan leaf springs today. That ass is up in the sky now :D
    The Orbit Eyes are supposed to allow me to flex easier/more, we shall see about that. I need to go find a place where I can flex the truck to take measurements for new rear shocks.
  3. Jan 3, 2022 at 7:26 PM
    #573
    SAGE63
    San Diego County
    Nice Cruz
    Cruzer[QUOTED][OP] likes this.
  4. Jan 3, 2022 at 7:58 PM
    #574
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    What shocks u going with
  5. Jan 3, 2022 at 8:01 PM
    #575
    Cruzer
    Cruz
    Sunnyvale, CA
    Hoping I can fit at least a 14" Fox 3.0 Piggyback. If I can fit a 16" that'll be cool.
  6. Jan 3, 2022 at 8:52 PM
    #576
    dittothat
    dittothat New Member
    Nick
    SD
    2016 MGM Platinum
    Random and dumb question: but could you use a regular socket on the bolt with the zerk fitting or have to go deep?
  7. Jan 3, 2022 at 9:23 PM
    #577
    Cruzer
    Cruz
    Sunnyvale, CA
    Regular socket would work. I used a boxed wrench to hold the zerk fitting side and a impact gun & socket on the nut side.
    dittothat[QUOTED] likes this.
  8. Jan 3, 2022 at 9:57 PM
    #578
    Vizsla
    Vizsla ☠️☠️☠️
    Nice! Really like the orbit eyes, so far rear spring bushings are a consumable pain in the ass for me.
    Few of my friends run this or the MCM version with 12” shocks and get almost 15” travel, that’s close to the limit of stock driveshaft u-joints at full droop.
    https://camburg.com/shop/suspension...a-tundra-07-performance-rear-shock-mount-kit/
  9. Jan 4, 2022 at 8:14 AM
    #579
    Cruzer
    Cruz
    Sunnyvale, CA
    So Dave it sounds like I need to spend more money :(:rofl:
    You know I haven’t even thought about the limitation of the U-joint. I have those Camburg mounts just haven’t installed yet. The Deaver packs that the mounts work with have a 2-2.5” lift. The Alcan stack gives me 5” so in theory I could stick a 14” shock in there if the new lower shock mounts are welded lower (like the stock ones), then clock the pinion angle, and use a limit strap to stay within the U-joint limits until I upgrade the drive shaft with a slip yoke. Do you think that’ll work?
  10. Jan 4, 2022 at 2:00 PM
    #580
    Cruzer
    Cruz
    Sunnyvale, CA
    Dealing with RCV warranty via e-mail sucks. RCV warranty over the phone is a whole lot better. I spent November waiting for email responses that I rarely got. Called RCV in early December to warranty my CV axle clicking. They immediately sent me a shipping label, which I ended up shipping the axle a week later. Today I got the axle back. That’s pretty good turnaround time I would say.
    I think I’ve figured out why I’ve been destroying axles lately - too much caster with the new LCAs. My axles look like a zigzag -\_ with the axle shaft so far forward that the outer joint has to turn a considerable amount just for the wheels to be straight. So when I turn full lock they just end up binding.
    alb1k, 2mchfun, TG705 and 1 other person like this.
  11. Jan 5, 2022 at 1:10 PM
    #581
    rochmpr
    rochmpr New Member
    Krister
    Walnut Grove, CA
    2020 CrewMax
    Lifted, sliders, 35 X 12.5's, Evo Corse and more stuff coming
    Wow, they are still making Orbit Eye springs. I had a set on an old rock crawler back in 2003. Those flexed like mad. I put a set of +1,000# Alcan's on my Tundra, made a big difference.
  12. Jan 5, 2022 at 1:15 PM
    #582
    Cruzer
    Cruz
    Sunnyvale, CA
    By looking at the pictures can you tell if they are the same as before or have they changed it up?
    I’ve seen them on small jeeps and yotas. Not sure how they’ll hold up with the big boys.
  13. Jan 5, 2022 at 1:37 PM
    #583
    rochmpr
    rochmpr New Member
    Krister
    Walnut Grove, CA
    2020 CrewMax
    From what I can see, it looks pretty much the same. Alcan acquired the Orbit Eye from AOR Offroad way back when and built the springs for AOR. This picture is with the Orbit Eye's on the front of the springs, look at all that travel. The 14" shock is maxed out.
    jomikepa, Downytide, ATV25 and 4 others like this.
  14. Jan 5, 2022 at 1:50 PM
    #584
    Cruzer
    Cruz
    Sunnyvale, CA
    That’s some mad flex right there!
    rochmpr[QUOTED] and eccracer104 like this.
  15. Jan 5, 2022 at 4:27 PM
    #585
    Sunnier
    Sunny
    San Diego, CA
    Look at THIS! Now there’s guest porn in Cruzer’s thread. :cool:
  16. Jan 5, 2022 at 5:38 PM
    #586
    SAGE63
    San Diego County
    Porn what where....
  17. Jan 13, 2022 at 10:48 AM
    #587
    Cruzer
    Cruz
    Sunnyvale, CA
    Did some measurements and it looks like I need to clock my rear axle up by 4 degrees. Ordered 4 degree shims, new U-bolts, and new center pins. Should be able to install it before heading down to KOH.
  18. Jan 13, 2022 at 10:54 AM
    #588
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k Supercharged 2008
    Here's how to add an atlas :D
  19. Jan 13, 2022 at 11:11 AM
    #589
    Cruzer
    Cruz
    Sunnyvale, CA
    Damn that's nuts! I wonder what it looks like underneath.
    eccracer104 likes this.
  20. Jan 16, 2022 at 5:55 PM
    #590
    Cruzer
    Cruz
    Sunnyvale, CA
    So Project 17 kicked off today. Project 17 is the revamp and expansion to 17 onboard cameras on the truck. I’ve been dragging my feet for so long because I hate running wires on the truck. The only reason I was able to start today was because I got my buddy to run the wires for me :D I paid him though.
    This is what 17 cameras looks like when all the wires are ran into the cab:
    I got my front cameras (1-6) mounted.
    2 in the bumper corners
    1 on center of the grill:
    2 on the LCAs:
    1 on the center of the crossmember:
    I’ve also cut out holes for cameras on the passenger side:
    Will try to finish next weekend.
    Piki, Kgfit85, porkitt and 9 others like this.
  21. Jan 16, 2022 at 5:58 PM
    #591
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    OMG, WTH, awesome, how to reply?
    FrenchToasty likes this.
  22. Jan 16, 2022 at 6:11 PM
    #592
    SAGE63
    San Diego County
    Damn thats nuts...what control unit gor all those video inputs
  23. Jan 16, 2022 at 6:27 PM
    #593
    Cruzer
    Cruz
    Sunnyvale, CA
    It's basically a front camera system, like FRAC or the Beatsonic, that I modified with my own switch.
    SAGE63[QUOTED] and Sunnier like this.
  24. Jan 16, 2022 at 6:50 PM
    #594
    Trdwillie14
    Billy
    2014 trd off road
    You have more cameras in your truck then I do on my house and I’m a locked and loaded nut
    TheBeast, Kgfit85 and eccracer104 like this.
  25. Jan 16, 2022 at 7:31 PM
    #595
    SAGE63
    San Diego County
    getting ready for KOH. to watch the rocks go under you
  26. Jan 22, 2022 at 5:20 PM
    #596
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Damn these cameras! Love that as most of my wheeling is alone
  27. Jan 22, 2022 at 5:21 PM
    #597
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Would you mind more details on the cameras? After a front, I want one on each side pointing fore for side clearance
  28. Jan 24, 2022 at 10:57 AM
    #598
    Cruzer
    Cruz
    Sunnyvale, CA
    I use various cameras depending on where I position them.
    I use this one the most because it has a 135 degree viewing angle, which means you have a more focused view compared to wider angle cameras.
    Works great on bumpers (since they can be flush mounted) and anywhere under the truck. I think this would be best for your situation.
    https://www.amazon.com/gp/product/B083SF5VVN?ie=UTF8
    If you're going for a true side of the truck shot like this, then I would recommend a flush mounted forward facing camera with a 170 degree viewing angle. I installed the camera above with the 135 degree viewing angle and found out it was not wide enough. If I am up against a tree or rock wall, then that super wide angle would be perfect for those very close up situations.
    I use this camera for inside the cab or up on the center of the grill. It has a 145 degree viewing angle. I put one inside the cab near the base of the back window so that I can see my dogs since they like to curl up right behind the front seats.
    https://www.amazon.com/gp/product/B078ZZSKQ2?ie=UTF8
    I installed these reverse only cameras here because they have a built in light. Haven't tested it out yet though. The hole saw that it comes with is garbage.
    https://www.amazon.com/gp/product/B085SZP3BG?ie=UTF8
    eccracer104 and Sunnier like this.
  29. Jan 24, 2022 at 2:55 PM
    #599
    Trdwillie14
    Billy
    2014 trd off road
    My wife could use these for parking my truck :rofl::rofl:
    Kgfit85 and Cruzer[QUOTED][OP] like this.
  30. Jan 24, 2022 at 6:22 PM
    #600
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Thanks bro!
