Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Sep 13, 2021 at 9:23 AM
    #391
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Cruzer[OP] and Rica25 like this.
  2. Sep 13, 2021 at 9:26 AM
    #392
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    That'll do! can't wait to see videos of this truck in action , how heavy you recon each tire weight?
    Hightide, Cruzer[OP] and Rica25 like this.
  3. Sep 13, 2021 at 9:30 AM
    #393
    Rica25
    Ricardo
    Tulare
    5 mpgs?
    2mchfun, Cruzer[OP] and Hightide like this.
  4. Sep 13, 2021 at 9:32 AM
    #394
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Wheel & tire are 130lbs each. Putting the spare tire inside the cab takes work :militarypress:
    Hightide likes this.
  5. Sep 13, 2021 at 9:33 AM
    #395
    Cruzer
    Cruz
    Sunnyvale, CA
    I'll find out when I drive down to San G in a couple weeks :D
  6. Sep 13, 2021 at 10:02 AM
    #396
    Cruzer
    Cruz
    Sunnyvale, CA
    Been trying to get the truck ready for San G:
    Working on my electrical to utilize the secondary battery.
    Built this waterproof 12 relay tray that I tucked underneath the bed, which has a hinge that lets it swing down so that I can access the back (top) side of it. Trying to get all of the electrical done so that I don't have to add anything else to it later on.
    I also installed my Redarc 1225D next to the battery, along with a contactor switch (a big ass solenoid to connect the primary and secondary batteries together, in parallel, if I ever need to jump start, use the winch, or use the 2000w inverter), a fused protected section for the rock lights, and bus bars for the solar panel connection into the Redarc.
    Repainted the bumper and trimmed the rear fender. Bumper bolted right back up. Plenty of room now.
    Had to round out some metal pieces that were sticking out
  7. Sep 13, 2021 at 11:03 AM
    #397
    Rica25
    Ricardo
    Tulare
    Oh nice. I will be there as well. Me and @Kdogg77 have been wanting to check out your Rig.
    Cruzer[QUOTED][OP] likes this.
  8. Sep 13, 2021 at 12:25 PM
    #398
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Does that fit in the garage ?
    Hightide and Rica25 like this.
  9. Sep 13, 2021 at 12:29 PM
    #399
    Cruzer
    Cruz
    Sunnyvale, CA
    Hell naw. I'd have problems getting in there with a regular car. Might be able to get in the garage but you'll never get out of the car :rofl:
  10. Sep 15, 2021 at 10:16 AM
    #400
    Cruzer
    Cruz
    Sunnyvale, CA
    Just found out that coupon code COLINSMITHSLO for 10% off works on practically anything on polyperformance.com site. Just bought the Total Chaos boxed stock length LCAs and replacement Delta Joints for my ICON UCAs, with free shipping. Shopping to kick my San G blues :anonymous:
    :yes:..... :spending:....:(...:benchpress:...:yes:
  11. Sep 15, 2021 at 11:27 AM
    #401
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Dude! I'm about to buy the TC LCAs too! let me know how you like them
    Rica25 and Cruzer[QUOTED][OP] like this.
  12. Sep 15, 2021 at 11:33 AM
    #402
    Cruzer
    Cruz
    Sunnyvale, CA
    Will do. That 10% off and free shipping helped out a lot.
    TG705[QUOTED] and Rica25 like this.
  13. Sep 15, 2021 at 11:35 AM
    #403
    TXTundra2722
    2015 Black Tundra
    What's the benefits from staying with the stock length arms.... unless you're adding the shock hoop and bypass? Call me crazy.... but I thought these cost just as much as buying the long travel lowers?
    Rica25 likes this.
  14. Sep 15, 2021 at 2:18 PM
    #404
    Cruzer
    Cruz
    Sunnyvale, CA
    I have several reasons:
    1. I want to keep my width to a minimum. I mean we're already fat beezies on the trails so I don't want to get any wider with LT. I don't do any of the fast stuff the LT guys do, I mean I'll do the occasional 50mph runs on desert (no whoop) roads, but I prefer the rock crawling shit that I may need to squeeze into.
    2. I also want it for the smooth articulation. If you've ever removed the LCA you'll know that it's pretty stiff in that it will not swivel on it's own. I was VERY surprised that I could hold up the truck when I had my floor jack underneath the LCA with no wheels and shocks attached, which tells me that it's quite hard to get it to travel. So when I'm crawling I want the wheels to easily travel downwards to make contact with the ground/rocks and with the uniballs it is less likely to bind. I'm thinking (not sure yet) if it will help with up travel in that the suspension will have a little more give so that it travels up without pushing the body/frame up with it.
    3. When I rolled my truck I think the driver side LCA bushing got damaged, could be other things, but that's about the only thing I can think of that was able to give because I've been having trouble keeping my wheels aligned. Sure I could buy replacement bushings or a replace it with a new stock LCA but that's no fun.
    4. I already bought and waited a million years for stock length RCV axles. I'm not ready to go through that again for LT axles.
  15. Sep 16, 2021 at 9:58 AM
    #405
    Cruzer
    Cruz
    Sunnyvale, CA
    Been wondering why my truck sagged to the rear driver side. I knew it was related to rolling the truck but couldn’t quite pinpoint it. Replaced the shackles - nope not it. I knew the driver side leaf pack was a bit twisted but still couldn’t see the problem until my friend pointed out that it was actually flatter than the passenger side.
    So I used the Poly coupon code again to buy an Icon RXT pack last night, then drove down to SLO this morning, picked them up, and am now driving back to go to work.
    eccracer104, Rica25 and Hightide like this.
  16. Sep 16, 2021 at 1:15 PM
    #406
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    Did your lowers ship yet? Just ordered mine haha! I want to install my spindles but would be nice to do them together
  17. Sep 16, 2021 at 1:58 PM
    #407
    Cruzer
    Cruz
    Sunnyvale, CA
    No, they’re on back order. But I’m in no rush to get those on. Our trucks are gonna look like twinsies! :rofl:
    Rica25 and TG705[QUOTED] like this.
  18. Sep 16, 2021 at 2:27 PM
    #408
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    Damn it!! haha did you get an ETA?
    Rica25 and eccracer104 like this.
  19. Sep 16, 2021 at 2:29 PM
    #409
    Cruzer
    Cruz
    Sunnyvale, CA
    Poly just said a "few weeks until they receive more from TC."
    Edit: would be nice if I can get it before T2S though.
    TG705[QUOTED], Rica25 and eccracer104 like this.
  20. Sep 16, 2021 at 2:30 PM
    #410
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    :anonymous:
    TG705[QUOTED], Rica25 and Cruzer[OP] like this.
  21. Sep 16, 2021 at 2:51 PM
    #411
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    :rofl::(
    Rica25 and eccracer104[QUOTED] like this.
  22. Sep 29, 2021 at 7:38 PM
    #412
    Cruzer
    Cruz
    Sunnyvale, CA
    :monocle:
    Hmmmm not sure where I'm going with this yet but I just ordered the Camburg rear shock relocation kit - just the perches. I know I want longer shocks to try and get more flex but have no idea what size I need until I get these on.
  23. Sep 29, 2021 at 7:40 PM
    #413
    Trdwillie14
    Billy
    2014 trd off road
    @831Tun
    Sunnier and Rica25 like this.
  24. Sep 30, 2021 at 6:12 AM
    #414
    TXTundra2722
    2015 Black Tundra
    :popcorn:
    Rica25 likes this.
  25. Sep 30, 2021 at 7:05 PM
    #415
    Slickrick73.
    Slickrick73. New Member
    Richard M Angulo
    2018 Tundra SR5 Double Cab
    Wheels tires and Tiger running boards
    Sick build man!!
    Sunnier, Cruzer[OP] and Rica25 like this.
  26. Sep 30, 2021 at 9:32 PM
    #416
    13TundraRW
    13TundraRW New Member
    Kyle
    San Diego, CA
    2013 White Tundra CM RW
    MCM UCA, MCM Shackles, 2.5 ADS C/O, Durobumps Front, Deaver U748, 2.5 ADS Bypasses, Wheelers/Timbren bumps rear, SoftTop
    Would be careful trying to get new shocks right now. Lead times are a dooooooozy.
  27. Sep 30, 2021 at 9:51 PM
    #417
    Cruzer
    Cruz
    Sunnyvale, CA
    True and good point. Just interested to see if I actually need these new perches or if I can get away with just longer shocks on the stock mount.
    Rica25 likes this.
  28. Sep 30, 2021 at 9:57 PM
    #418
    13TundraRW
    Kyle
    San Diego, CA
    Yeah maybe mock mount then to get your numbers then order shocks. Then maybe in a year when the shocks come in you can mount them.
    Rica25, Sunnier and Cruzer[OP] like this.
  29. Oct 1, 2021 at 11:00 AM
    #419
    Downytide
    GTA
    Ouch, that touches a nerve with me lol, ordered suspension in July, delivery is now in December.
    so 42"s are next?
  30. Oct 1, 2021 at 11:21 AM
    #420
    Cruzer
    Cruz
    Sunnyvale, CA
    :spy: I did catch myself looking at the Mickey Thompson Baja Pro XS 15/43-17LT (43"x15")
    I think I'm good at 40s although I do want them wider than the 13.5"
    But you ordered an entire suspension kit though right? Not just individual shocks?
