Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Jun 7, 2021 at 11:39 AM
    #271
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    yeah, I am very familiar with the BDS setup... the mainline is easy to find as well as the return, the left and right lines are easy to sort out they are the two hard lines attached to the rack. I guess in theory you could pull from those two and use a proportioning valve to send fluid to a ram. I can check the rack I have in my barn of spare parts. BTW if you ever need any BDS parts let me know I still have my full kit sitting in the barn too. The only issue I see is making sure the rack and pump could support the ram, I don't see why not, you would also need to have a larger resi, which if you check my thread I did that a while back as well as adding a cooler which IMO is a requirement for anyone running 35's or larger. the added stress turns into an increased effort by the pump and rack increasing heat. The heat is what I think blows out the seals in the rack. We can talk bout this more if you like. Shoot me a PM. I'm always up for problem-solving. I would like to disassemble a blown rack to take a look at the internals to see how to do it. If you still have the old rack let me know.
    831Tun and Sunnier like this.
  2. Jun 7, 2021 at 1:03 PM
    #272
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I had to give my damaged rack back to Napa auto parts to get my core deposit back but I do have an OEM spare that I picked up from the junkyard a few weeks back. I know the 2 hard lines you're talking about - that makes it much easier to tap into. BDS parts? :yes: I'll take take both crossmembers and knuckles if you still have them. I've already bent my crossmembers before so having spares would be nice and will probably need to gusset the shit out of the knuckles. I'll let you know when I'm heading down south again we can trade.
    With the info you've provided I can now start inquiring with PSC and similar manufacturers to see what my options are.
  3. Jun 7, 2021 at 1:18 PM
    #273
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    glad I can help and yeah sounds good, shoot me a PM and we can exchange #'s
    831Tun likes this.
  4. Jun 11, 2021 at 5:17 PM
    #274
    Cruzer
    Cruz
    Sunnyvale, CA
    Damage was not too bad given that the truck rolled onto its driver side.
    Left and right shackles bent. I bought these cheap 2" lift shackles off of eBay because the ProForm Fab shackles I ordered were back ordered. If they were more rigid then I'd probably have worse issues.
    Because the shackles gave way, the whole rear axle shifted passenger side:
    The bumper took it like a champ. Little body damage on the bed side, rack, and rifle case.
    Got a new tail light on Amazon.
  5. Jun 11, 2021 at 5:20 PM
    #275
    rochmpr
    rochmpr New Member
    Krister
    Walnut Grove, CA
    2020 CrewMax
    Lifted, sliders, 35 X 12.5's, Evo Corse and more stuff coming
    Park that passenger side out and no one will notice.
    Rica25 and Cruzer[OP] like this.
  6. Jun 12, 2021 at 12:33 AM
    #276
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Well, I've got some fiberglass panels when you're done denting your metal stuff. Glad it wasn't worse.
  7. Jun 18, 2021 at 11:01 AM
    #277
    Cruzer
    Cruz
    Sunnyvale, CA
    I ordered RCV axles back on 5/5. Found out it's another 5-6 weeks out:annoyed:so I had to postpone the Rubicon run cuz at the rate I'm going I'd need to bring a shit load of spare CV axles. Wheeling hard this summer is pretty much sidelined :( .... overlanding it is :p
    Rica25, 831Tun and Sunnier like this.
  8. Jun 18, 2021 at 11:17 AM
    #278
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    You went from :burnrubber::mudding:
    To
    :turtleride:
    Darn lead times! :smash::angrygirl:
    Rica25, 831Tun, Sunnier and 1 other person like this.
  9. Jun 18, 2021 at 11:46 AM
    #279
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Glad you figured this one out. I was going back to dig through my pictures but normally you have to pry that stub out, much like you had to pound out the remaining splined portion. This does seem like a weak spot in the design, especially after you get beefier CV's.
    For your apparent level of mechanical aptitude regearing should be no problem! Way to get up the kahunas to crack the clam open after seeing a shop waste your time. Honestly I'd rather regear the front than the 10.5. Here's my write up on it although hopefully you never need it: https://frugalfill.com/diy-2nd-and-3rd-generation-toyota-tundra-differential-regear/
  10. Jun 18, 2021 at 12:24 PM
    #280
    Cruzer
    Cruz
    Sunnyvale, CA
    Nice write up! I’m already on 5.29s but since you’ve brought it up I’m currently annoyed by the rear diff whining when I hit 65-70mph. Never noticed it until I got quieter tires. Thinking of cracking open the rear diff and poking around.
  11. Jun 18, 2021 at 1:03 PM
    #281
    blackoutt
    Indy
    OEM+
    I wouldn't advise chasing it down. For my 5.29s I opened the rear back up a handful of times, replaced bearings twice, ran at high and low spec for backlash. Perfect patterns. Still whines, nitro says it's normal. Just let er eat.
    eccracer104 and 831Tun like this.
  12. Jun 18, 2021 at 1:14 PM
    #282
    Cruzer
    Cruz
    Sunnyvale, CA
    That's what I've been reading - ok you've convinced me not to:hattip: I can't wait to get meatier tires to drown out the whine.
  13. Jun 18, 2021 at 1:20 PM
    #283
    Sunnier
    Sunny
    San Diego, CA
    Drive faster?! :p
  14. Jun 18, 2021 at 1:25 PM
    #284
    Cruzer
    Cruz
    Sunnyvale, CA
    The GF complains when I do. Next week will be the first time she will ride in my truck since I went 39s, which she hasn't noticed yet, but she will notice the whining and start asking questions. I'll be like "What? What noise? I can't hear you cuz of all this whining!" :rofl:
  15. Jun 18, 2021 at 1:34 PM
    #285
    Sunnier
    Sunny
    San Diego, CA
    Haha! You could suggest she change the battery in her hearing aid… :rofl:
  16. Jun 18, 2021 at 6:32 PM
    #286
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Sounds like you need speakers.
    Rica25 and eccracer104 like this.
  17. Jun 18, 2021 at 8:49 PM
    #287
    rochmpr
    rochmpr New Member
    Krister
    Walnut Grove, CA
    2020 CrewMax
    There's this knob on the dash labeled "Volume", put on the favorite tunes and turn liberally in the clockwise direction, problem solved. Just sayin'
  18. Jun 18, 2021 at 9:36 PM
    #288
    Cruzer
    Cruz
    Sunnyvale, CA
    There you are! Haven’t heard from you in a while. :rofl:2 Live Crew that shit lol!!
    Rica25 and Trdwillie14[QUOTED] like this.
  19. Jun 18, 2021 at 9:37 PM
    #289
    Cruzer
    Cruz
    Sunnyvale, CA
    Lol the ole lady complains about that too. You know we’re that far apart in age lol.
    Rica25 likes this.
  20. Jun 18, 2021 at 9:49 PM
    #290
    Trdwillie14
    Billy
    2014 trd off road
    I know I’ve been Mia lol my bad I would say let’s go wheel but it looks like a semi hit your truck lol
  21. Jun 20, 2021 at 9:24 PM
    #291
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    This may be an odd thing I noticed.
    I had my diffs sent to ken/zuk , its cryo and rem'd , during break in I used toyota fluid, no noise except tiny bit during decel, but since I bought that giant boxe of nitro fluid I decided to put them in after break in, no noise in decel but now I get the whine on higher speed.
    Then I saw this post and makes me wonder if it's fluid related.
  22. Jun 20, 2021 at 9:32 PM
    #292
    Cruzer
    Cruz
    Sunnyvale, CA
    I’ve got the heavier Lucas 85/140 gear oil in mine, made no difference. I used to have some sort of synthetic in there that the shop put in.
    Rica25 likes this.
  23. Jun 21, 2021 at 5:40 AM
    #293
    blackoutt
    Indy
    OEM+
    I talked to Ken about this too. I think the rem polish and cryo may have made more of a difference (plus Ken's top notch setup quality!) but we agreed the heavy Nitro oil may be TOO heavy. I'm going use up mine over warmer months and run the lighter synthetic the rest of the time. I noticed no difference in whine between the weights though.
    I didn't notice a difference either. Gears will be gears.
    Rica25 likes this.
  24. Jun 21, 2021 at 7:44 AM
    #294
    Downytide
    GTA
    May be I should change the exhaust to louder, the x-pipe quiet it down a lot.
    Rica25 and blackoutt[QUOTED] like this.
  25. Jul 2, 2021 at 11:50 AM
    #295
    Cruzer
    Cruz
    Sunnyvale, CA
    What a week! Picked up BDS parts from Bruce. Then I sold my old bumpers and just now I finally sold the Yokohama X-MTs to a fellow Tundra owner
    :yes:
  26. Jul 14, 2021 at 11:10 AM
    #296
    Cruzer
    Cruz
    Sunnyvale, CA
    I've been getting quite lazy sitting around waiting for my damn RCV axles to be made and shipped that I decided to fix my hood bulge. I installed an LED bar inside the bulge and by doing so made the hood bulge very flimsy. That black faux grill insert actually made it rigid. When I drove to Moab back in March it was really windy, so windy that my hood bulge popped out of its mounts and was flapping around like crazy so I had to duct tape it. Turns out the 2 of the mounts where bolts are screwed at the corners broke off and only the center bolt was holding it down.
    Ordered a new bulge. Bought a 1"x3' aluminum bar at Lowes and slid it underneath the gap of the plastic mounts - fit perfectly in there:
    I then drilled 6 holes on the hood that were big enough so that zip ties could easily slide through:
    I then slid long zip ties under the aluminum bar and positioned them to line up with the holes:
    I then routed the zip ties through the holes and pulled them tight:
    In hindsight I should've left a little piece of these end mounts (which I cut off because they were hitting the LED bar) so that I could slide a zip tie underneath and then secure onto the ends of the LED bar - oh well, next time, which I hope there is no next time.
    The hood bulge is more stiff now so hopefully it'll be able to handle highway speeds and strong headwinds. I'll find out when I drive to Vegas on Friday :D
  27. Jul 28, 2021 at 9:56 AM
    #297
    Cruzer
    Cruz
    Sunnyvale, CA
    RCV axles are supposedly 2 weeks out now. Geez that's going to be 14 weeks + 1 week to ship :transformer:
    Time to get back into truck building mode.
    - I ordered the 12" rack from Vicotry4x4 - hopefully I can get that before the San Gorgonio trip.
    - Ordered a 120ah second battery with a Redarc BCDC1225D charger and a Renogy 100w solar panel
    - Ordered a cheapy fridge from Amazon to keep my brewskies cold AF!
    :benchpress:
  28. Jul 28, 2021 at 10:01 AM
    #298
    eccracer104
    San Diego, CA
    :ohsnap::cheers:
    Cruzer[QUOTED][OP] likes this.
  29. Jul 28, 2021 at 12:15 PM
    #299
    rochmpr
    rochmpr New Member
    Krister
    Walnut Grove, CA
    2020 CrewMax
    Cheap fridge keeping something so important cold. If there is one place to never skimp! Everything else can be hobbled together, but warn beer..................
    eccracer104 likes this.
  30. Jul 28, 2021 at 12:30 PM
    #300
    Cruzer
    Cruz
    Sunnyvale, CA
    Lol my tree can only grow just a little bit of money at a time. We’ll see how long this fridge lasts. If it can survive the Sedona trip I’ll be happy. Now you got me thinking. Maybe I’ll bring my RTIC cooler to Sedona just in case. Not sure how long I’ll survive in the woods with warm beer.
